Page 1 of 2 12 LastLast
Results 1 to 25 of 28
Thread: DFI 790FXB-M2RSH Rocks
    Jul 2008
    Hit over 3.3 GHz on my 9850 BE CPU with AMD overdrive, Did hit 3.4 but got BSOD after 10 mins so I think I need a bit more voltage. Will try more tests when I get time.
    I have had 3.3 GHz with the settings I have posted and also got 3.3 GHz whith just CPU multiplier and bus set to 200 Hz.
    On my old motherboard I got between 2.9 to 3.0.
    http://valid.x86-secret.com/show_oc.php?id=436303
ID:	87454   Click image for larger version.
    AMD Phenom II 940 BE (CACZC AC 0903FPAW)
    CPU cooler: Water (EK-Supreme block & Thermochill PA 92.2 radiator)
    Case: XG Dragon
    Fans: 120mm at bottom, 120mm at top and small fan blowing onto northbridge area.
    Mobo: DFI DK 790FXB-M2RSH (Bios R7SD421)
    Ram: 2 x 2GB DDR2 1066MHz OCZ Gold 5-6-6-18
    Graphics: Asus HD4850
    Power: 700W storm PSU
    Hard drives:1 x 750GB 2 x 300GB SATA and 2x 320GB SATA
    CD/DVD drives: 1 x muti Burner and 1 x muti reader
    OS: Windows Vista Ultimate 32bit/64bit
    Feb 2008
    nice
    you seemingly do not have temperature problems with the nb or pwm heatpipe...
    1. ASUS Sabertooth 990fx | FX 8320 || 2. DFI DK 790FXB-M3H5 | X4 810
    8GB Samsung 30nm DDR3-2000 9-10-10-28 || 4GB PSC DDR3-1333 6-7-6-21
    Corsair TX750W | Sapphire 6970 2GB || BeQuiet PurePower 450w | HD 4850
    EK Supreme | AC aquagratix | Laing Pro | MoRa 2 || Aircooled
    Aug 2006
    54 degrees in the chipset :O, under stress and load, mine didn`t go over 42 ( i have a asus m3a79-T)
    Jul 2008
    yes I know the board temps are a little high, but this board works, unlike the last Asus I got that just gave me BSOD all the time. BSOD I can not fix, but board temps I can.
    Case: XG Dragon
    Jan 2008
    Texas
    thats pretty impressive speed considering the voltage you're at. Whats your NB speed running?
    AMD Phenom X4 9850BE
    ZeroTherm Nirvana 120 cpu cooler
    MSI K9A2 Platinum Bios P.0J
    4GB Mushkin (2x2) DDR2 1066 (PC8500) CL5-5-5-15 2v
    Sapphire Toxic edition Radeon HD3870
    2 x 320GB Seagate Barracuda 7200.10 in Raid 0
    80GB Western Digital Caviar IDE For driver and file backups.
    Raidmax RX-700SS 700w psu (possible weak link in OC equation)
    Apr 2008
    I have the same board on my new setup i just built.. i played far cry 2 alot last night but afterwards i was like "hey i forgot to overclock this" because i just built it yesterday. So i got into AOD and started tweaking.. i got to 3.4 without raising any voltages. Just after that i ran a stability test and failed it i quickly added a few volts and w00t!! its running perfect at 3.4 without any ram tweaking and just a basic overclock.
    Computer #1
    Phenom X4 II 965
    8 GB DDR3
    Nvidia GTX 295
    300 GB Velociraptor
    28" LCD
    52" HDTV
    D.F.I Pimp Daddy
    Jan 2007
    Still Lost At The Dead Show Parking Lot
    Can anyone Confirm that these Temps are Accurate on these New D.F.I 750 Boards please?
    SuperMicro X8SAX
    Xeon 5620
    12GB - Crucial ECC DDR3 1333
    Intel 520 180GB Cherryville
    Areca 1231ML ~ 2~ 250GB Seagate ES.2 ~ Raid 0 ~ 4~ Hitachi 5K3000 2TB ~ Raid 6 ~
    Jul 2008
    Hit 3.4GHz
    Uped the voltages a bit and hit 3.4GHz, then got BSOD with 3.5GHz, but still have lots of room with my voltages and not hit 60°C yet on air so still have room to play.
    http://valid.x86-secret.com/show_oc.php?id=436889
    Also downed clocked my ram to 3:5 set the CPU bus to 240 Hz and got to 3.360 Ghz, got BSOD at 3.480 Ghz after 10 mins.
    This has all been done running on Vista 32bit.
ID:	87528   Click image for larger version.
    Case: XG Dragon
    Xtreme X.I.P. Particle's Avatar
    Apr 2008
    Kansas
    Nice results, man. I'm glad you're seeing such a nice jump.
    Particle's First Rule of Online Technical Discussion:
    As a thread about any computer related subject has its length approach infinity, the likelihood and inevitability of a poorly constructed AMD vs. Intel fight also exponentially increases.
    Rule 1A:
    Likewise, the frequency of a car pseudoanalogy to explain a technical concept increases with thread length. This will make many people chuckle, as computer people are rarely knowledgeable about vehicular mechanics.
    Rule 2:
    When confronted with a post that is contrary to what a poster likes, believes, or most often wants to be correct, the poster will pick out only minor details that are largely irrelevant in an attempt to shut out the conflicting idea. The core of the post will be left alone since it isn't easy to contradict what the person is actually saying.
    Rule 2A:
    When a poster cannot properly refute a post they do not like (as described above), the poster will most likely invent fictitious counter-points and/or begin to attack the other's credibility in feeble ways that are dramatic but irrelevant. Do not underestimate this tactic, as in the online world this will sway many observers. Do not forget: Correctness is decided only by what is said last, the most loudly, or with greatest repetition.
    Rule 3:
    When it comes to computer news, 70% of Internet rumors are outright fabricated, 20% are inaccurate enough to simply be discarded, and about 10% are based in reality. Grains of salt--become familiar with them.
    Remember: When debating online, everyone else is ALWAYS wrong if they do not agree with you!
    Random Tip o' the Whatever
    You just can't win. If your product offers feature A instead of B, people will moan how A is stupid and it didn't offer B. If your product offers B instead of A, they'll likewise complain and rant about how anyone's retarded cousin could figure out A is what the market wants.
    Jun 2007
    Wayne NJ
    Hmm maybe its just me but i havnt found any "AutoXpress" feature in the BIOS.
    Its lame always have to start AOD to enable it.
    Anyone knows how to enable AutoXpress from BIOS?
    AMD Phenom II 1090T @ 4GHz Asus Crosshair IV
    HD6970
    LSI Megaraid 9260-4i 4xMomentus XT
    OCZ Vertex 3@SB850
    8 gig Patriot Viper 7-7-7-24 T1
    Swiftech Watercooling
    Filco Majestouch 2
    Zowie EC1
    Jan 2007
    Brisbane, Australia
    Ocing 9950BE
    Hi all, recently bought this board and so far it is doing very well. However I am having trouble OCing my 9950BE.
    Here is a Screenshot from AOD http://img120.imageshack.us/my.php?i...dscreenxz4.jpg
    As you can see I am running the NB at 2.4ghz thats no prob (have not changed any NB volts over stock). However whenever I set the Mutli to 15 for 3ghz it BSOD's. I have ACC on an set to 4% all cores and I am on the 09/19 Bios. I am on water (Dtek Fuzion) so temps are not a problem. Setting CPU Vid Special Add in the Bios to +150mv for high 1.45v has not seen any change in the BSODs. I feel like im missing one setting that's holding me back but cannot think what, any help appreciated. Thanks!
    Under construction
    Jun 2008
    You might have to play around with the ACC a lot more.
    I suggest switching it from auto then turning all cores up to 4 or 6 and then run prime95 and see which cores drop (or if the system hangs completely,) and then make adjustments from there.
    I wouldn't recommend turning all cores as high as 8 though, I did that and it caused data corruption.
    Feb 2008
    kanata
    mine barely breaks 43C after an hour of Warhead. i should fire up something better to stress the system though.
    Quote Originally Posted by Brother Esau View Post
    DFI 790FXB-M2RSH bios 09/19/2008
    9950 BE rev. dr-b3 3.2Ghz 1.3125v
    TT Big Typhoon VX
    4GB Buffalo Firestix PC2-8500
    2x Palit 4850 crossfire
    BenQ FP222WH
    SB xfi extreme gamer
    Logitech z5500
    2x Seagate 7200.10 500GB sata2
    Pioneer DVR 212D sata
    Antec P-180
    PC Power & Cooling Quad 750
    Jan 2008
    Athens -> Hellas
    Quote Originally Posted by nuts24 View Post
    Very nice results...Have you tried to run stable with tighter ram timings?
    Jul 2008
    Yes my ram is running at 5-5-5-15 now and still no problems between 3.0GHz and 3.4GHz.
    I don't think I can push the ram any more as its cheap & I can not find a spec sheet any for my sticks. they have Emartbuy on them.
    Case: XG Dragon
    Jul 2007
    Melbourne
    I got one now and I've been testing memory with memtest and I found something way odd with the bandwidth numbers
    Memtest86+ v2.01:
    1. 13.0 x 254 = 3302, L1:27067, L2:6725, MEM:4299 (MB/s)
    2. 13.5 x 246 = 3321, L1:27223, L2:6764, MEM:2821
    3. 13.0 x 256 = 3328, L1:27280, L2:6778, MEM:4333
    I ran sisoft mem bandwidth test on the number 2. setting and got a bunch of varying numbers but they seem to settle around about roughly 4600MB/s for float and integer with the buffering setting disabled - I think that it is low.
    Gonna have to check the 3. setting.
    Is Everest consistent in the results it gives?
    for the the integer results from sandra mem bandwidth test in eight I got:
    3382 MB/s
    4230 MB/s
    4581 MB/s
    4528 MB/s
    4486 MB/s
    4635 MB/s
    4710 MB/s
    4556 MB/s
    all over the place
    Cheers
    AMD FX-8350 | ASUS Crosshair V Formula-Z | G.Skill F3-1866C8D-16GTX | MSI Radeon R9 280X Gaming 3GB
    OCAU
    Apr 2008
    Texas
    Quote Originally Posted by cbjaust View Post
    Memtest86+ v2.01:
    3382 MB/s
    4230 MB/s
    4581 MB/s
    4528 MB/s
    4486 MB/s
    4635 MB/s
    4710 MB/s
    4556 MB/s
    all over the place
    Cheers
    Sounds like an "odd deviser" thing going on with the memory controller with half-step multipliers (the 13.5 rather than 13.0). Didn't Athlons have an issue with that? Also it really looks like there could be a few "sweet spots" that allow the asynchronous clocks to work in better harmony around the board. Intel deliberately payed attention to this with their new Core i7 architecture. There should be a few combinations of clock speeds that produce higher bandwidth and/or lower latencies.
  18. #18
    Jul 2007
    Yes it seems,, IMC/NB contoller likes certain dividers...Viewing CPU-Z i bet that @ 13x vs 13,5x multi sets different ram Divisor...Some dividers can ,,will downclock the ram or NB . Thus affect the efficency of CPU,, even though it shows that the MHZ is the same or simalar as another divisor..
    Comes down to the way the BIOS is coded and or the IMC just likes different divisor thats all..
    Ive seen this while running Higher Divisor vs Lower Divisor and high HTT... go with the higher performance divisor or Try using non Half multis
    Its definatly a AMD balancing act. Just takes time,, find the Sweetspot and Walla performance time .Nothin new ,,Girls kinda act the same sometimes
    "AMD...Like the perfect Storm,...Everything needs to be just right"
    X555x4SuperCore@4450mhz@1.64v..........
    RYZEN 7 1800x/ ASUS ROG STRIX VEGA64/ =EK NICKEL WB, Feser THC 2x360 1x480
    X470 Gigabyte Aorus7, Patriot 3400mhz 16gb dual2x8
    SSD Samsung 970pro,,860EVO
  19. #19
    Apr 2007
    Good work man, DFI knows AMD thats for sure
    i3 2100, MSI H61M-E33. 8GB G.Skill Ripjaws.
    MSI GTX 460 Twin Frozr II. 1TB Caviar Blue.
    Corsair HX 620, CM 690, Win 7 Ultimate 64bit.
  20. #20
    Jul 2007
    Melbourne
    Quote Originally Posted by gOtVoltage View Post
    nah, it's definately CPU/7 in CPUz for both cases. I'll have a closer look at it tonight and post some pics and some mem benches from Everest which I just installed and I'll piss that other piece of junk from sisoft right off.
    Cheers
    Here are some pics I made earlier:
    13.0 x 256:
    13.5 x 246:
    The only difference, apart form the cpu multi and HT Frequency is that Max Async Latency (set to Auto in BIOS) is 8ns at 13.5x vs 7ns at 13.0x
    I also ran a quick Memtest at 14 x 236 and got CPU: 3304MHz, L1:27084MB/s, L2:6724MB/s, MEM:4302MB/s so those numbers are back on track. It makes me wonder if I am missing a bit of performance on a 4800+ I have here usings its default multiplier of 12.5x
    Cheers
    OCAU
  21. #21
    Sep 2006
    Inside an AS355F2
    Those 6000's always were a problem with ram.
    Try sticking with even multis.
    Regarding the motherboard, if anyone has an old Crosshair lying around, the PWM fan that came with it, that was supposed to be for watercooled setups fits pefectly over the pwm cooler on this board.
    My pwm temps are now ~40°c in 30° ambients.
  22. #22
    Jul 2007
    Melbourne
    Quote Originally Posted by Aussie FX View Post
    more information please re: Windsor and RAM
    Cheers
    OCAU
  23. #23
    Dec 2004
    Malaysia
    anyone here change the stock cooling on NB & mosfets? i found the temp on NB was rather high. apart from this (NB temp issue) & acc problem (i can't boot whenever i turn it on), this board is superb... rock solid + lotsa tweaking options...
    this is what i can manage so far due to temp issue...
    | AMD Ryzen 5 76000 w/ EVGA CLC 360 | ROG STRIX B650E-I GAMING WIFI | FF4D532G5600HC32DC01 | Radeon™ RX 6950 XT GAMING OC 16G | XB323QK |
    | 512GB NM760 + Crucial P3 2TB + ST2000LM015 + ST2000LX001 |
    | Creative Stage V2/HE400SE | Xonar U7 MKII | Focus GX-850 | D31 Mesh Screen Black | MK-730-GKCL1 + MM711 + MP510 |
  24. #24
    Aug 2008
    I placed (balanced atm tbh) a 60mm fan directly in front of the nb heatsink. my normal nb temp was 57.C, on low fan setting speed it is running at 30.C and on high it has dropped as low as 26.C
  25. #25
    Dec 2004
    Malaysia
    Quote Originally Posted by caveman_2 View Post
    thanks mate. can i assume that the fan is blowing upwards if you're using a tower case?
    from 57'c to 30'c, that's a drastic change...
