10-22-2008, 03:18 PM
#1
Xtreme Family
Gigabyte EP45-UD3P - out of the box and almost auto setting -> boot @ 620FSB easy.
__________________
Mojo
Family
Biostar TP55 XE - Core i7 860(ES) @ 4.2ghz - CNPS10X Extreme - G.SKILL 1600 - Galaxy GTX275 - Velociraptor 300GB x 2 - Zippy TypeR 600w
Criminal
Biostar X58A - 920~Gulf - G.SKILL2000CL8 - GTS250 - Hitachi 40gb 7200 - Giga-EZ 1000w
Kids
P4GD1 - Pentium M 740 - XMS Xpert400 - Gladiac 7900GTX - Raptor 36GB - Aopen 560w
10-22-2008, 03:32 PM
#2
Wow very nice!
You got guts, When I booted into windows at 500 FSB and looked at easytune and saw what the voltages they set me at I was too uncomfortable to keep using auto. Those are some very nice clocks though! Maybe I will have a few shots later tonight and then go for it LOL
__________________
E8400 @ 4.2 Ghz (525x8)
Gigabyte EP45-UD3P
Corsair Dominator 4GB (2 x 2GB) PC2 8500 2.1V
PowerColor 4870x2
150GB Western Digital Raptor
500GB Western Digital 5000AAKS
Westinghouse LVM-37w3 1080p Monitor
Vista64
Cooling: CPU-OCZ Vendetta2+Scythe S-FLEX SFF21F 120mm, Silverstone TJ09 case with 4 120mm yate loons.
10-22-2008, 03:38 PM
#3
Awesome effort there. Watch those auto volts they can crank it up as you can see the CPU VID:1.25 but CPU-z shows 1.408v. Have a look in EasyTune6 to what the rest of the volts are doing. Manual control is a bit better so you now where everything is.
10-22-2008, 04:01 PM
#4
Xtreme Family
here guys
voltage @ auto
well ,the voltages are not bad for XS ^^
__________________
Mojo
Family
Criminal
Kids
10-22-2008, 04:07 PM
#5
Hope your not planning on using those volts 24/7 lol!
__________________
E8400 Q15A @ 8.5x500=4250Mhz with 1.28 vcore -- TRUE 120 with Scythe Ultra Kaze in push pull
ASUS P5Q Deluxe 1702 Bios -- PC Power & Cooling Silencer QUAD Crossfire 750w
2x1GB Crucial Ballistix PC6400 (16FD5) & 2x1GB Crucial Ballistix PC8500 (16FD5) @ 1000mhz 4-4-4-12 PL9 @ 2.17v real with Corsair Dominator Active Cooling
ATI HD4870x2 Cat 9.1 - Custom modded ASUS TOP Bios 832/1000
2 x Samsung F1 1TB + 1 x Samsung F1 320GB -- X-Fi Xtreme Music -- Logitech G15 v2 + Razer Lachesis
Dual Boot XP 32 SP2 + Vista 64 Ultimate SP1 -- Samsung T220 22" Monitor (Samsung Panel) + Samsung LEA656 40" 1080p TV
10-22-2008, 04:09 PM
#6
xtreme member
Iv'e been using 1.85v PLL on 65nm for many months without issue..but 45nm...nice clocks anyway!
10-22-2008, 04:11 PM
#7
Xtreme Family
hehehehe
440 x 10 @ 1,27v is enough for me ^^
__________________
Mojo
Family
Criminal
Kids
10-22-2008, 04:28 PM
#8
Xtreme Family
thx man
well ,PLL @ 1,61 is enough for 620fsb
but i need to set the CPU termination higher than 1,5v  (still auto)
__________________
Mojo
Family
Criminal
Kids
10-22-2008, 04:30 PM
#9
...you two characters
sweeeeeeeet man
increase your vMCH as well
should give you more FSB
__________________
Team.AU
Got tube?
Originally Posted by Gautam
In the old days, LN2 benching was "cheating". Then LOD was "cheating". And so on and so forth...
10-22-2008, 04:34 PM
#10
Xtreme 3D Team
That's great PcCI2iminal!
With a bit of tweaking you may go even higher
__________________
10-22-2008, 08:45 PM
#11
Xtreme Guru
you got any good settings for a quad around 475-500fsb??? Not too many people around here with quads and this board
10-22-2008, 08:47 PM
#12
Curious as to your:
CPU Clock Skew (ps).......................: ps
MCH Clock Skew (ps).......................: ps
You can get a BIOS template for the EP45T, it may have most of your options (if not all) and may help, post 16:
http://www.clunk.org.uk/forums/revie...html#post31353
Excellent effort there.
10-22-2008, 08:49 PM
#13
Phazers on Stun
Q9650
__________________
HEAT
10-22-2008, 11:23 PM
#14
nice~ FSB
A nice guy
10-23-2008, 03:03 PM
#15
Xtreme Guru
Originally Posted by systemviper
Q9650
Viper, can you post your voltages? thanks
__________________
10-23-2008, 05:38 PM
#16
Q9650
Yes your settings would be iteresting you could use that BIOS template link I posted.
10-23-2008, 06:39 PM
#17
Xtreme Mentor
I must point out that setting the bios options to "Auto" in bios does NOT set the voltages to standard settings, Auto will INCREASE the voltages...sometimes by a very large margin and dangerous levels. MCH and CPU PLL voltages WILL be raised, this can be tested and verified by Everest and other programs. The only way to ensure standard/default voltages is to set ALL voltages options to "Normal" or set items manually. I'm an EP45-DQ6 user with F12 bios and this board uses very similiar bios.
__________________
Gigabyte EP45-DQ6 - rev 1.0, F13a bios | Intel Q9450 Yorkfield 413x8=3.3GHz | OCZ ProXStream 1000W PSU | Azuen X-Fi Prelude 64MB X-RAM| WD VelociRaptor 74HLFS-01G6U0 16MB cache 74GB - 2 drive RAID 0 64k stripe | ASUS 9800GT Ultimate 512MB RAM (128 SP!!) | G.SKILL PC2-8800 4GB kit @ 1100MHz | OCZ ATV Turbo 4GB USB flash | Scythe Ninja Copper + Scythe 120mm fan | BenQ M2400HD 24" 16:9 LCD | Plextor 716SA 0308; firmware 1.11 | Microsoft Wireless Entertainment Desktop 8000 | Netgear RangeMax DG834PN 108mbps; firmware 1.03.39 + HAWKING HWUG1 108mbps USB dongle | Digital Doc 5+ | 7 CoolerMaster 80mm blue LED fans | Aopen H700A tower case | Vista Home Premium - 32bit, SP1
10-23-2008, 07:40 PM
#18
Phazers on Stun
So what is "dangerous levels" 4 a 45nm quad and only benchies
Vcore
vMCH
__________________
HEAT
10-24-2008, 02:27 AM
#19
Xtreme Family
i agree ,never use auto when you are going to overclocking the system, not for 24/7.
anyway mine needs some serious voltage to ran 600+
Vcore
vMCH
air
vcore -> 1,55v
vMCH -> 1,7v+
you can go much higher ,depends on cooling ^^
__________________
Mojo
Family
Criminal
Kids
10-24-2008, 02:48 AM
#20
Xtreme Family
well ,the board is dead ,I figure something fried and one of the mosfet is toast.
All i know is that when I was runnin the prime95 at 4500MHz(10x450) @ 1,35v (PLL,vMCH,Termination @ minimum)and the systems crashed ,not booting after shutdown .
the E8600 is dead also .....
pics later
__________________
Mojo
Family
Criminal
Kids
10-24-2008, 03:14 AM
#21
pics later
same here man
my gem E8600 is dead
__________________
Team.AU
Got tube?
10-24-2008, 03:16 AM
#22
ehh board and chip fried? How is that possible
__________________
|| E8400 @ 530x8.5 = 4505MHz || EP45T-UD3P || 4GB DDR3 1700MHz CL7 ||
|| Sapphire HD4890 @ 905/1100 1.275V || Toughpower 750W || Antec P182 ||
|| 2048x1152 23" Samsung || Air cooled || Sennheiser HD580 ||
10-24-2008, 03:25 AM
#23
Xtremely Addicted
Sorry to hear about the E86's  Three of them in a few days on same boards is scary...
__________________
10-24-2008, 03:28 AM
#24
yeah doesnt sound very good
i am going to go buy a cheaper chip and shove it in for torture if the board is still alive....no sure  to see if the second one dies as well
__________________
Team.AU
Got tube?
10-24-2008, 03:38 AM
#25
Team ID - Indonesia
sorry to hear about it man  ...My UD3P and UD3R still a live until today, i'm using E8600 too with air cooling daily 450 x 10 @ 1.37v
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
