Lapping a 120 eXtreme
Considering lapping my 120 eXtreme but i have a question that is probably going to sound dumb but here goes. If i lapped my 120 eXtreme and my CPU, would it make any difference to the pressure of it sitting on the CPU? If you lapp your settup you take off a thin layer from the CPU and HS-is it enough to lessen contact pressure?
Since i have an Antec 1200, my heatsink sends the heat upwards directly to the 19cm top fan. i have been concerned about the weight of the heatsink and possible flexing. I know the screws are tight but not overtightened. If i was to lapp my rig i would need to be sure i wasnt adding to the issue of the weight of the heat sink.
Well there is my noob question for the day, go ahead and rip into it!
My Self-Built, Custom PC
-E8500 @ 4Ghz
-Ultra-120 eXtreme with 120mm Silverstone Fan
-4 X 1GB Corsair Dominator XMS2, 1066, 5-5-5-15, DDR2
-DFI LANParty X48-T2RS Dark Edition
-Xpert Vision Sonic ATI 4870, 813/1050, 512 DDR5
-2 X Seagate 250GB, 7200rpm, 32MB Cache S-ATA
-1000W TruePower Quattro ATX PSU
-Antec 1200 ATX Tower, 7 X 12cm fans + 19cm 'Bigboy'
Vista 32- bit, SP1
- You may not post replies
- You may not edit your posts
Forum Rules
