Page 1 of 2 12 LastLast
Results 1 to 25 of 41
Thread: How does Advance Clock Calibration work?
    Oct 2005
    What does it do and how does it really work. Is it helpful in overclocking at all?
    Jul 2005
    Magic, I don't know and yes.
    Oct 2005
    Quote Originally Posted by MrMojoZ View Post
    Any idea how to use it?
    Xtreme X.I.P. Particle's Avatar
    Apr 2008
    Kansas
    Nobody really knows how it works. The leading guess is that it adjusts running parameter tolerances. Yes, it's generally helpful in overclocking so long as it is properly implemented by a motherboard and its BIOS.
    How to use it? You get a range of positive and negative values. You tweak the values for each core until you find the sweet spot that allows the greatest stable overclock--too much and too little are equally bad. Positive values help OC.
    Particle's First Rule of Online Technical Discussion:
    As a thread about any computer related subject has its length approach infinity, the likelihood and inevitability of a poorly constructed AMD vs. Intel fight also exponentially increases.
    Rule 1A:
    Likewise, the frequency of a car pseudoanalogy to explain a technical concept increases with thread length. This will make many people chuckle, as computer people are rarely knowledgeable about vehicular mechanics.
    Rule 2:
    When confronted with a post that is contrary to what a poster likes, believes, or most often wants to be correct, the poster will pick out only minor details that are largely irrelevant in an attempt to shut out the conflicting idea. The core of the post will be left alone since it isn't easy to contradict what the person is actually saying.
    Rule 2A:
    When a poster cannot properly refute a post they do not like (as described above), the poster will most likely invent fictitious counter-points and/or begin to attack the other's credibility in feeble ways that are dramatic but irrelevant. Do not underestimate this tactic, as in the online world this will sway many observers. Do not forget: Correctness is decided only by what is said last, the most loudly, or with greatest repetition.
    Rule 3:
    When it comes to computer news, 70% of Internet rumors are outright fabricated, 20% are inaccurate enough to simply be discarded, and about 10% are based in reality. Grains of salt--become familiar with them.
    Remember: When debating online, everyone else is ALWAYS wrong if they do not agree with you!
    Random Tip o' the Whatever
    You just can't win. If your product offers feature A instead of B, people will moan how A is stupid and it didn't offer B. If your product offers B instead of A, they'll likewise complain and rant about how anyone's retarded cousin could figure out A is what the market wants.
    May 2007
    Colorado Springs
    It works by taking the voltage and breaking the molecules down into much smaller particles before injecting them into the CPU's intake bus. This makes the CPU more efficient so it can burn more Voltage easier.
    (Ooops. Too many car analogies for me.)
    Many people believe it is just a form of clock skewing.
    Basically you turn it on... and it works. It can be fine tuned also as Particle mentions. But it can easily add 300Mhz to an overclock.
    FX-8350, Powercolor ATI R9 290X LCS, OCZ Vertex 4, Crosshair V Forumula-Z, AMD Radeon DDR3-2133 2x8Gb, Corsair HX1000W, Thermaltake Xaser VI, Xonar D2X, Water Cooling 140.3
    Banned
    Jun 2008
    Somewhere Up to my Ears in Ye Yo
    al it is is a clock skew, as mentioned above,
    nothing that boards 10 years ago werent using, just re hashed for the masses in 2008,
    like everything i suppose,
    and yes it works, but only on CPU's with week tolerances lol
    Jul 2005
    Needs more angst.
    Banned
    Jun 2008
    http://en.wikipedia.org/wiki/Clock_skew
    I wonder why AMD was being so secretive about this, refusing to explain how it works... Could this maybe also benefit intel cpu's?
    Apr 2008
    Somehow I doubt it takes 6 pins to achieve clock skewing. Gotta be something more to it.
    May 2007
    Colorado Springs
    Quote Originally Posted by Miss Banana View Post
    Actually the fact that they released it and are still secretive....
    That makes me wonder if this is only half of the whole. Is the SB750 going to do even MORE with the Deneb??
    (And apparently many Intel motherboards DO have clock skew settings.)
    Banned
    Jun 2008
    Needs more angst.
    repoted for flame baiting
    Quote Originally Posted by dirtyd View Post
    i would say differant, six pins sounds just right, to enable some type of skew
    Jan 2008
    Vancouver,British Columbia, Canada
    The 6 pins on the CPU previously "unused" are hocked up to the sb750.
    I've also heard something about JTAG interface.
    Setting wise seems like auto works best for my 9600be.
    My Asus M3a with SB600 has options for "AI clock screwing" or something
    like that and the most I could get with Win xp64 was 2500mhz
    The same cpu (9600be) with the same OS (x64) is now running ~2.9ghz on
    the DFI 790gx so I would say it does work.
    My 9850be got killed either by the board (above) with ACC or by AOD - maybe both (conspiracy?) I don't know.
    World Community Grid's mission is to create the world's largest public computing grid to tackle projects that benefit humanity.
    Our success depends upon individuals collectively contributing their unused computer time to change the world for the better.
    Sep 2008
    All DFI boards that i know of have the DOS Skew control settings, but all that does is handle EMI interference generated by noise from voltage going through the board. Way way back when in the before pentium era that setting actually did something. With better filtered power supplies and better manufacturing process for motherboards, there isnt a need for this setting any more. I highly doubt that the ACC aforementioned is this skew control. Hooking pins up to a south bridge, to me that sounds more like bull since the south bridge functions as the link to the lower buses on the board the pci slots, pcie slots, then the north bridge is the traffic cop that directs things from the upper buses and built in connectors to the back of the board. With AMD the memory controller is on the chip so the NB all it does is regulate traffic of data from inputs to the cpu and outputs to the SB chipset.
    I really dont see how hooking up 6 unused pins to a south bridge chipset did anything. I cant blame AMD for wanting to keep this newfound thing quiet, but maybe it is something that is enabled in the bios and they tied it to boards with the SB750 chipset to sell more motherboards. I think it is great that ACC gives good performance boosts in overclocks, but i think they are feeding a load of crap to the general public that has no idea how the internals of a computer works. Maybe later on they will release and disclose what exactly is the real cause of making the boards with SB750s oc so much better.
    May 2008
    NorCal
    like that
    Must do it differently in the great white north!
    Oct 2005
    Quote Originally Posted by daseto View Post
    Hmmm I am inclining to share the same notion.
    When I was trying to make the failing core stable, I increased the ACC to +2 for that core and it worked perfectly BUT then the next core would start to fail when it was not failing before. For instance, my ACC is set to 0,0,0,0. During overclocking, core 1 kept failing. I then set ACC values of 0,2,0,0 BUT THEN, core 2 started failing instead. The next set of values that seemed logical for me to try were 0,2,2,0 = Core 2 failed. I am going around in circles 0,2,4,0 = core 2 failed. 0,4,2,0 = core 2 failed again. I am lost.
    KEY:
    ACC values corresponding to Core 0, Core 1, Core 2, Core 3 are 0,0,0,0 respectively for the above example.
    Apr 2008
    Kansas
    Try raising them in synchronized steps to start with, such as 0000 to 1111 to 2222.
    Also, I might have missed this, but what motherboard do you have? I know that at the very least, the ASUS M3A78-T does NOT have properly functional ACC while some other SB750 boards do. Perhaps yours falls into that list of problematic ACC implementations.
    Rule 1A:
    Rule 2:
    Rule 2A:
    Rule 3:
    Jan 2008
    Quote Originally Posted by RiverRicer View Post
    You don't want to know
    Anyone else heard that Nvidia is going to support ACC in the "near" future?
    Read it on some site, that collects a bunch of news bits together - forget the name
    Why would AMD not be secretive about it? It's not like Intel is sending their
    HighK Metal Gate Hafnium etc. formula to anyone interested.
    I set the DQS clock sqew to 255 on my NF4 expert,it supposed to help with high HTT/Ram speeds and afaik the "traditional clock sqewing" is just for that - to help deal with "high speed" (ddr1 mostly) ram and cpu intimate relations.
    It also has a page full of "spread spectrums" etc, ....don't think it's related.
    Anyhow looks like the ACC "mystery" remains - as nobody knows exactly
    what and how, just why and hey - why not
    edit*
    For the guys saying that 6 pins is "bs"- why does ACC only work for Phenoms and not X2's ?
  18. #18
    Oct 2005
    Well, leaving it on AUTO does help OCing but I want to maximise its use. Perhaps it could be a useful tool. It seems so because the core which was failing for me consistently wasn't failing anymore when I ACCed it by 2%. But then, another one starts failing
    Leaving it on AUTO does require less vCore to sustain the OC though.
  19. #19
    Apr 2008
    Quote Originally Posted by Particle View Post
    I was not aware that it did not function properly on that board. Can you provide a link with details as I am curious now. I have seen others with good results using it so i am curious as to what the problem may be.
    "You make a living by what you get. You make a life by what you give." --Winston Churchill
    3DMark Vantage - 19,552 -- 3DMark06 - 25,066 -- 3DMark05 - 31,688 -- 3DMark03 - 114,287 -- CPU-Z - 4800MHz
    Denb vs. Agena - Clock for Clock & Deneb Overclocking Results
    My Water Dragon:
    CPU: Phenom II 965 BE X4 (CACYC AC 0931DPMW)
    CPU Cooler: Swiftech Apogee GTZ (Custom H2O)
    MotherBaord: ASUS M3A79-T Deluxe
    Bios: 0701
    Graphics: 3x VisionTek 4870 512MB
    Display: HP w2007
    Memory: G.SKILL 4GB(2 x 2GB) DDR2 1066
    Power: Ultra X3 1000W
    Case: COOLER MASTER Centurion 590
  20. #20
    Sep 2008
    Quote Originally Posted by SocketMan View Post
    edit*
    Well if all ACC is is a form of skew control then it is possible to tie the bios of the mobos to only enable certain functions with certain chips plugged in. Not all boards have skew controls in the bios that you can change. DFI is one that has had it in the past, dont know if they have that on a SB600 board, might be fun for someone that has one to let us know and fiddle with it and see if they can get similar results as on a sb750 just by messing with the skew control.
  21. #21
    Apr 2008
    Kansas
    As I recall, the K8s are missing (2 of the?) pins required to do ACC.
    Quote Originally Posted by Ben_Brown View Post
    Are you sure that you aren't thinking about the M3A79-T? That one does work wonderfully while the 8 (790GX) does not.
    Rule 1A:
    Rule 2:
    Rule 2A:
    Rule 3:
  22. #22
    May 2008
    NorCal
    I am lost.
    Welcome to the ever-growing club of AMDers that are trying to tweak ACC. My experience is identical to your own, Sandeep. Try to help the weak core and...boom...there goes a different core. Without the ingredients for the ACC 'secret sauce', we'll never get a handle on it. I gave up and set the damn thing back to 'auto' after two evenings of repeated attempts to find some sort of consistency with various settings. Consistant it ain't!
  23. #23
    Apr 2008
    Ah yes, over site on my part. Thanks for clearing that up.
    My Water Dragon:
    Bios: 0701
    Display: HP w2007
  24. #24
    Banned
    Jun 2008
    be carefull on this forum, with comments like that ...lol, youll be an outcast before you can say, intel what?
    lol, i totaly agree with you, some of the rubbish that AMD has been spewing is beyond me, the whole release of boards with the SB600 chipsets, to then release the exact same boards with a SB750 chipset is pure robbery.
    in fact i would suggest that they would be liable for recycle issues from varios councils and law makers, purely in the fact the didnt offer an 'upgrade' option, like BFG or EVGA, to comply with ROHS standards
    but hey i am hated here so my opinion will mean nothing, just another intel fanboy with an AMD rig ehh?
  25. #25
    Oct 2007
    UK, a small place with a big heart
    About the 6-pin link to the SB750, and the details you ,mention above regarding the NB/IMC/SB BUS controls etc....
    The one thing that is significantly different between K8 and K10 is that the clock gen for the K8's was located in the CPU NB, and there were initial problems with the K8 X2's which AMD released the Dual Core Optimiser fix for...
    But on K10 (Phenom) the Clock Gen has been removed from the CPU NB and is now situated in the motherboard NB for 7xx series chipsets...
    One of my theories about ACC is that its a combination of Clock Skew tolerance tweaking (i.e. the +/- values for the cores) ,and a new clock gen that has been incorporated into the SB750 which uses a direct link to the 6-pins on the CPU to negotiate with the cores....
    I have nothing solid to base this on other than the fact that its been reported for some time that there were issues with SB600 and also SB700 internal clock gens.... so the fixed clock gen in SB750 in combination with the tweaking of the clock skew tolerances, allows for increased OC for those CPU's that were previously shown to have one or more weak cores...!!!
    I think that ACC has been provided by AMD as a gesture of goodwill if you like as a workaround for customers who have bought Black Editin Phenoms that were sold with the intention of OC'd (hence the unlocked multi's) but that proved to be poor OC'ers as a result of the weak cores....
    This is my theory anyway...!!!!
    I have no
    Phenom II 940BE (CACVC AC 0850BPMW) @ 3.8Ghz (1.475v) on Custom h2O
    ASUS M3A79-T Deluxe - BIOS v0703 - HT @ 1.8Ghz / NB @ 2.2Ghz / PCIE @ 100Mhz
    2 x 2GB G.SKill PC2-8500 RAM @ 5-5-5-15 2T (Unganged) | 2 x GeCube HD4850's CF @ 700/1150
    2 x 160GB Samsung Spinpoints (RAID-0) | 1 x 320GB Seagate 7200.10 (JBOD)
    Thermaltake Toughpower 750W PSU | Samsung 206BW 20" LCD Screen
    Vista Home Premium 64-bit SP2 / Win7 Ultimate Beta 64-bit
    3DMark Vantage Score = P13403 - http://service.futuremark.com/compare?3dmv=791574
    3DMark06 Score = 20027 - http://service.futuremark.com/compare?3dm06=9996881
    My External LCS Mod - http://s91.photobucket.com/albums/k2...t=1f046259.flv
Tags for this Thread
