The visual difference between the Tpower P45 rev A2 and rev A3 is minimum ,the old rev came with bios ROM 0620 and the new with 0710 but i am not sure if it is a valid proof to recognize rev A3
will be necessary to remove the heatsink to check (or use cpuz ^^)
Biostar Tpower i45 5.1
AC82P45 - SLB7Z rev A2
AC82P45 - SLB8C rev A3
and about OC?well,A3 should be better than A2.. Intel can not possibly revise a product and make it worse ^^
Biostar Tpower i45 flying on air,this board is the legend and at mainstream price 2 ^^
Tpower i45 P45(revA2) Bios 0710
max post @ 645FSB
into windows @ 620FSB
max fsb 662FSB
****** EDIT -- wrong screen ******
Tpower i45 P45(rev A3) Bios 0710
max post @ 655FSB
into windows @ 640FSB
max fsb 674FSB
No worries about overclockability as bios optimization has been able to yield OC of more than 660fsb for both but the new revision seems to be better than A2 ^^.
CPU - E8500 Q820A599
Cooler - Gigabyte G-PowerII @ full load
MB - Biostar Tpower i45 5.1 - P45 revA2 & P45 revA3
NB Cooling - stock + 60mm @ 23CFM
Ram - Team Group 1066 1024mb x 1
VGA - HD4870 X2
PSU - Giga-EZ 1000w
Bios
Over-Clocking Navigator [Manual OverClock]
Intel(R) SpeedStep(tm) : Disabled
Ratio CMOS Setting : ×6.0
CPU Frequency Setting : 620(revA2) & 640(revA3)
Over Clock Retry Count : 1
FSB Finetune : Enable
FSB(Bsel) To NorthBridge Latch : 1333
DRAM Frequency : DDR2-1240(revA2) & DDR2-1280(revA3)
DDR2 Enhance Mode : Disabled
DRAM Timing Configuration
DDR2 RCOMP Configuration : 1
Configure DRAM Timing by SPD : enable (5-6-6-18)
Clock Gen Configuration
PCIE Frequency Setting : 100
CPU Clock Skew Control : 200ps
(G)MCH Clock Skew Control : Auto
CPU Clock Driving Control : Auto
Voltage Configuration
CPU Voltage : +0.1
DDR Voltage : +0.700v
Chipset Voltage : +0.700v
FSB Voltage : +0.3500v
CPU Core1 GTL Ref Voltage : 0.63*VTT
CPU Core2 GTL Ref Voltage : 0.63*VTT
MCH GTL Ref Voltage : Auto
CPU PLL Voltage : 1.7v
can you make the pics smaller tho please
It makes your post pretty hard to read
Saaya yupp, I agree
