Results 1 to 16 of 16
Thread: 790GX built-in DDR3 128MB - GIGABYTE MA790GP DS4H OC report
Threaded View
    Nov 2004
    Currently, the most hot topic in AMD platform is the new mid-end chipset 790GX+SB750.
    790GX built-in HD3300 GPU which is more performance than HD3200 in 780G.
    I believe this chipset combines with AMD dual/triple/quad core CPU can bring the higher C/P value.
    Unlike 790FX has the advantage of CorssFire X16+X16, 790GX is positioned in mid-end.
    It only supports X8+X8 CrossFire. However, the new SB750 and GUP HD3300, 790GX is still a great choice for end users.
    This time I get is GIGABYTE MA790GP DS4H.
    After 790GX launched, 3 tier one manufacturers all announced their 790GX products.
    The price is around 160USD. As the price gap is small, the components, spec. and OC ability are the key factors.
    Package
    Accessory
    Left-Lower Corner
    2 X PCI-E X16(CorssFiieX works as X8+X8)
    3 X PCI-E X1
    2 X PCI
    1 X Floppy
    LAN Chip Realtek 8111C, Audio Realtek ALC889A, 7.1cahnnels support HD Audio
    Right-Lower Corner
    6 X SATAII(SB750)
    1 X LPT
    Dual BIOS
    Right-Upper Corner
    4 X DIMM DDRII, support 533/667/800, and 1066 Phenom
    1 X IDE
    24PIN power in
    Left-Upper Corner
    4+1 phase PWM for CPU which supports 140W Phenom CPU
    IO Interface
    4 X USB 2.0
    1 X 1394
    1 X S/PDIF fiber output
    HD3300 has 3 output interfaces : D-SUB/DVI/HDMI
    MA790GP DS4H heatpipe thermal module
