View Poll Results: which bios are you currently using on ya P5Q dlx with a Q9... series CPU ?
Voters
19. You may not vote on this poll
  • 0803 or lower
    7 36.84%
  • higher than 0803
    10 52.63%
  • modded bios
    2 10.53%
Results 1 to 25 of 29
Thread: Collective Q9450 and P5Q series thread issue thread
Threaded View
    I am Xtreme
    Sep 2006
    Collective Q9450 and P5Q series issue thread -- SOLVED BY 1406 BIOS
    LATEST 1406 BIOS SOLVED ALL TILL KNOW ALL KNOWN ISSUES WITH Q9450 OR OTHER YORK CPU'S -- IF YOU STILL ENCOUNTER PROBS PLZ USE A PM MESSAGE -- NEW BIOSSES ARE ALREADY IN THE WORKS
    K After reading numerous posts of users with this hardware combination, I think it will be more easier to find users with the same issue(s) if we have one collective thread on the matter... users with other 45nm quads also can pop in... This is easier for the Asus tech to dig in...
    Plz fill in the following info and vote in the poll plz
    P5Q ... (type) made in (Taiwain or China)
    daily OC used :
    Voltage settings used :
    CPU Voltage:
    CPU GTL Voltage Reference (0/2):
    CPU GTL Voltage Reference (1/3):
    CPU PLL Voltage:
    FSB Termination Voltage:
    DRAM Voltage:
    NB Voltage:
    NB GTL Reference:
    SBridge Voltage:
    PCIE SATA Voltage:
    Load Line Calibration:
    CPU Spread Spectrum:
    PCIE Spread Spectrum:
    CPU Clock Skew :
    NB Clock Skew :
    if bios later than 0803 : which setting for CPU enhancement... :
    Operating System used :
    RAID : (yes or no) in case of Yes type of RAID
    Drivers from Cd : (yes or no) in case of no : plz fill in the version
    Issue encountered : (brief description) if no issues plz state so...
    counteracts taken : eg bios reflash, hardware swap, cmoss reset, format, other drivers, other OS,...
    CURRENT STATS :
    Influenced boards :
    P5Q Dlx Total 4 out of 6 not solved : Taiwanese model seems to be influenced (4 issues till now)
    CPU's :
    Q9450 : 3 out of 6 : 3 issues solved with Performance EDIT : other 3 now with 1406 bios (user confirmed)
    Q9550 : solved with performance setting
    QX9650 : 1 out of 2 not solved : still multiplier issues
    Question : Why do some overclockers switch into d*ckmode when money is involved
    Remark : They call me Pro Asus Saaya yupp, I agree
