Results 1 to 6 of 6
Thread: ? For those of you that have the norco RPC-4020 case (WARNING: lots of images)
    Jun 2008
    Do you have any issues with the caddy activity lights not working? I heard it uses the SATA signaling to show HD activity and thus doesn't need any additional cables (and I don't see any on the back plane) but i also got a different version from the one I normally see (with two sets of data cables, one for SATA one for SAS) so maybe something is messed up with this model?
    Basically I only get HD activity lights on two (of the 12) caddies that are currently hooked up.
    I also didn't like the fact that port one on the case is the far right port instead of the far left =( I didn't want to rehook up all the SATA back plane cables so I will just live with that.
    The controller I am using right now is an ARC-1231ML. I was going to upgrade to the ARC-1680ix-24 but I heard from people on forums and from areca that the 1680ix-24 has issues with seagate AS series 1 TB drives so I ordered a ARC-1280ML but it wont come until next week.
    Here are some pics of my setup
    Yeah I know the cable job is not pretty/sucks but I didn't want to spend th money *just* to buy a modular power supply to save myself some cables which are in the way.
    As soon as I get the ARC-1280ML next week I will be offloading all my data to two other raid6 servers at work so I can re-create the array from 12x1TB in raid5 to 20x1TB in raid6 (18 TB useable), woot!
    Also if anyone has a cheap 1280ML they can sell me please let me know. I know the order won't be processed until after the weekend so I can cancel my order if need be since sadly the 1280ML is only $50 cheaper than the 1680ix-24 =(
    And for those curious the temps on my drives went up only slightly (1-3 C) from my old CM stacker case and my CPU temp dropped about 13C! My CPU/mobo now runs at around 37C which is very good IMHO for a 2.4 Ghz core 2 duo OC'd to 3.5.
    Supermicro SC846 Case
    Supermicro X9DR3-LN4F+
    Dual Intel Xeon E5 4650L (8 core, 2.6Ghz, 3.1 Ghz Turbo)
    EVGA Geforce gtx 670
    192GB DDR3 PC-1333 ECC Memory
    ARC-1280ML raid controller
    24x2TB Hitachi SATA (raid6)
    ARC-1880x raid controller
    30x3TB Hitachi SATA (raid6)
    - External in two SC933 Case
    Work/Home:
    Jan 2005
    Cable management generally is inversely proportional to the amount of cables that need to be managed. I've seen some cases that you dont see ANY cables cause they are tied back so well. Yet that case had 1 optical drive, 1 harddrive, no PCI accessories and maybe a video card that required 1 (or no) power cables.
    As you start getting more stuff (say...12 harddrives?) you have to start sacrificing looks for what you want. Sure you can still manage but your options get more and more limited.
    Given what you have in your case and stuff, yours turned out pretty well. Just make sure those 12 harddrives stay cool and you get air flow through your entire case!
    12 TB... you trying to digitally store the entire works of shakespear ?
    DFI Lanparty X48 T2r (Swiftech GTZ)
    Intel Q9450 (DD MPC)
    4 x 2GB OCZ DDR2 1000
    ATI Radeon 4870 512mb (EK-4870FC)
    2x 500gb SATAII RAID 0
    2x 200gb SATA RAID 1 (Back ups)
    2x 160gb SATA RAID 1 (Back ups)
    Creative X-fi Fatal1ty (Overglorified software sound in Vista...was great with XP )
    Don't Forget - The early bird catches the worm, but the second mouse gets the cheese.
    Xtreme Mentor
    May 2006
    Croatia
    D A M N nice!!
    Those back planes look pretty closed, though... how's the airflow to the hdd's?
    I mean I see all the fans but the back planes concern me...
    Quote Originally Posted by LexDiamonds View Post
    Anti-Virus software is for n00bs.
    Jun 2008
    It actually has all 20 drives in it right now it just doesn't have the last 8 hooked up to anything (ATM) since my current raid controller only supports 12 drives. I am waiting on my new raid controller I will be getting next week.
    The temps are definitely higher my cooler master but still not bad at all IMHO:
    Hdd#1 Temperature 39 ºC
    Hdd#2 Temperature 40 ºC
    Hdd#3 Temperature 38 ºC
    Hdd#4 Temperature 39 ºC
    Hdd#5 Temperature 40 ºC
    Hdd#6 Temperature 41 ºC
    Hdd#7 Temperature 40 ºC
    Hdd#8 Temperature 41 ºC
    Hdd#9 Temperature 39 ºC
    Hdd#10 Temperature 40 ºC
    Hdd#11 Temperature 40 ºC
    Hdd#12 Temperature 41 ºC
    That case pushes an amazing amount of air considering how quiet is (I am used to supermicro cases) and it is only slightly louder than my CM stacker was. I am definitely satisfied with the HD temps. My CPU temps went down a lot more than I expected though.
    Other than the fact the disk activity lights are only working on two caddies I am very happy/satisfied with the norco RPC-4020 case which I got for about $320 shipped.
    Work/Home:
    Xtreme Mentor
    May 2006
    Croatia
    Thats not bad temps. But I assume this is idle.
    Try and run raid initialization procedure see how far they go.
    I can run passive in my 5in3 cages but heavy disk usage such as initialization sends the drives to 50-52C. And mine are WD GP RE2 drives.
    Try it just to be on the safe side...
    Jun 2008
    Quote Originally Posted by XS Janus View Post
    I can't really test temps during initialization due to the fact that i have live data on it (from switching cases) and when I do re-initialize the volume it will be at the data center where I work which won't be a fare comparosin. For example on my server at work I get:
    CLI> hw info
    The Hardware Monitor Information
    Fan#1 Speed (RPM) : 3267
    Battery Status : Not Installed
    HDD #1 Temp. : 24
    HDD #2 Temp. : 23
    HDD #3 Temp. : 24
    HDD #4 Temp. : 27
    HDD #5 Temp. : 25
    HDD #6 Temp. : 25
    HDD #7 Temp. : 25
    HDD #8 Temp. : 26
    GuiErrMsg<0x00>: Success.
    And that is under pretty high load, and CPU/mobo/cores:
    w83627dhg-isa-0290
    Adapter: ISA adapter
    VCore: +1.13 V (min = +0.00 V, max = +1.74 V)
    in1: +12.04 V (min = +3.85 V, max = +10.14 V) ALARM
    AVCC: +3.20 V (min = +3.49 V, max = +3.66 V) ALARM
    3VCC: +3.20 V (min = +0.21 V, max = +0.54 V) ALARM
    in4: +1.24 V (min = +1.62 V, max = +1.81 V) ALARM
    in5: +1.57 V (min = +1.17 V, max = +1.11 V) ALARM
    in6: +3.94 V (min = +4.53 V, max = +5.17 V) ALARM
    VSB: +3.20 V (min = +0.24 V, max = +2.24 V) ALARM
    VBAT: +3.04 V (min = +0.94 V, max = +0.35 V) ALARM
    Case Fan: 0 RPM (min = 958 RPM, div = 128) ALARM
    CPU Fan: 6250 RPM (min = 11157 RPM, div = 1) ALARM
    Aux Fan: 6553 RPM (min = 26470 RPM, div = 1) ALARM
    fan4: 6250 RPM (min = 2033 RPM, div = 4)
    fan5: 0 RPM (min = 1757 RPM, div = 128) ALARM
    Sys Temp: +21.0°C (high = -120.0°C, hyst = -67.0°C) ALARM sensor = thermistor
    CPU Temp: +22.5°C (high = +80.0°C, hyst = +75.0°C) sensor = diode
    AUX Temp: +28.5°C (high = +80.0°C, hyst = +75.0°C) sensor = thermistor
    cpu0_vid: +1.563 V
    coretemp-isa-0000
    Core 0: +31.0°C (crit = +100.0°C)
    coretemp-isa-0001
    Core 1: +28.0°C (crit = +100.0°C)
    coretemp-isa-0002
    Core 2: +30.0°C (crit = +100.0°C)
    coretemp-isa-0003
    Core 3: +28.0°C (crit = +100.0°C)
    I did however just try to write 300GB of data to it and near the end of writing all the files temps only went up 1-2C. This of course was to the file-system so it wasn't quite as good as writing directly to the disks. I also tried reading data off it for 10 minutes and the temps went up about the same.
    Interesting enough from this little experiment I realized that it looks like the activity LEDs are working on the case its just some of them are extremely dim =( That sucks. The power LEDs are really bright too... would have been better if those were the activity ones
    Work/Home:
