Page 1 of 2 12 LastLast
Results 1 to 25 of 35
Thread: I need replacement chokes for 4850
    Aug 2007
    Exclamation I need replacement chokes for 4850
    I already posted this in the 4850/4870 thread, but I figured a new thread would get more hits.
    A friend is sending me his card. He was having some corruption after putting on an aftermarket HS, so he decided to remove it. Problem is he epoxied the RAMsinks on and he tore off two of the chokes!
    The chokes are in pretty bad shape. Does anyone have a blown card, any spare chokes, or a link to where I can get some replacements? I'm going to try to fix it for him.
    Thanks!
    Jason
    ES Q9550 E0 @ 4.0GHz (471x8.5) 1.256v
    TR-Ultra-120-X, 115CFM 120mm fan
    Maximus II Formula @ 1884MHz FSB
    Ballistix DDR2-800 (4x1GB) 1132MHz 5-5-5-5-15 4-55-8-14-11-3-8-5-4-2T
    eVGA GTX 280 @ 702c/1404s/1260m (1.175v)
    Auzentech XPlosion DTS-Interactive Vantage 'X'-6,727
    300GB Velociraptor, PC P&C 750W
    (3)120mm, (2)90mm, (1)250mm case fans in TT Armor
    27.5" LCD/Z-5500-office, 95" 720P projector/7.1ch-living room
    Logitech Driving Force Pro-Microsim Racing Pod
    Jul 2008
    SF, CA
    I haven't done any looking myself, but these are the only sites I know of that might carry what you're looking for:
    http://www.micrel.com/products.do
    http://www.intersil.com/cda/home/
    [SIGPIC][/SIGPIC]
    [PURE] AWESOME
    Aug 2007
    Thanks for the links, but I'm not getting any hits when I type in the part number: R47 811 T28.
    Jul 2008
    SF, CA
    that's probably because they don't carry the same manufacturer.
    what you'd want to look for are electrically compatible chokes by any manufacturer, as you probably won't be able to access the same fab resources as ATI through any channel.
    [SIGPIC][/SIGPIC]
    [PURE] AWESOME
    Aug 2007
    Do you have any ideas on how I can find out what is compatible?
    Aug 2007
    Anybody?
    Xtreme Guru
    Jan 2005
    Tre, Suomi Finland
    You could salvage them from virtually any motherboard/video card with four CPU phases, they don't have to be identical as long as you replace them all. Just don't take them from a board that has considerably more phases (8+).
    You were not supposed to see this.
    Aug 2007
    Quote Originally Posted by largon View Post
    Awesome news!
    One problem...I don't have any dead hardware to take advantage of atm.
    Does anyone have any dead hardware they want to donate to science? My friend will pay shipping!
    Aug 2007
    My friend managed to get a hold of some dead cards.
    2x 6800 Ultra, and a 6800GT.
    Do you think these will have the parts I need? I don't think these cards are 4-phase.
    And you mentioned that I need to replace them all, but they don't have to be identical. If that's the case then why can't I leave the 2 on there that are good, and just replace the other 2?
    Xtreme Guru
    Jan 2005
    Tre, Suomi Finland
    I meant the new parts don't have to be identical to the originals. All the replacements should be identical.
    Aug 2007
    That makes a lot more sense. I'm guessing it has to do w/ load balancing.
    So, just to make sure we're on the same page...
    I want the finished repaired card to have 4 identical chokes on it. It doesn't matter too much where they come from as long as they're identical. Correct?
    So, if the 6800Ultras have 2 chokes each I could use both of them from each card for a total of 4. Correct?
    May 2005
    jason,
    check out www.digikey.com or www.mouser.com for SMD parts... it will prolly take a lot of searching but you should be able to find a replacement that way. the downside is that some parts have a min order like 5 or 10 in order to get the part you want. i would take a DMM and measure the resistance and the capacitance. then search thru the listed sites for a choke that fits the measurements and size. Either that or call up tech support for the video card company and see if they will tell you. another option is to hit up ViperJohn on OCF, he should know about the chokes...
    Intel Pentium G3258 | ASRock Z97M OC Formula | Samsung 2x4GB DDR3-1600 | Galaxy GTX660 GC | Samsung PM840 Pro 128GB, PM830 250GB FDE |
    "I Love To Camp!"
    "Comensing Shock Therapy!"
    HeatWare
    Aug 2007
    Good to see you over here Evil!
    I've ordered plenty of stuff from both those companies. I'll wait till I get the card in my hands, and then take some measurements. Thanks for the advice!
    Xtreme Guru
    Jan 2005
    Tre, Suomi Finland
    The problem with the chokes of a 6800Ultra is that the ancient GPU chomps away less than ½ of the power a RV770 does. Thus the inductors are likely rated for much lower currents than the originals on the busted HD4850.
    Aug 2007
    I was afraid of that.
    Wait a sec...half the power...half the number of chokes (assuming it has 2). It might still work, or am I thinking about it wrong?
    I'll take some measurements before doing anything stupid.
    Xtreme Guru
    Jan 2005
    Tre, Suomi Finland
    As far as I know, 6800Ultra has 3 vGPU coils.
    Aug 2007
    Doh!
  18. #18
    Aug 2007
    I got the card in my possession now along w/ some dead 6800's. Someone has told me they have a dead X1800.
    http://www.techpowerup.com/articles/...ages/front.jpg
    Will these chokes work?
  19. #19
    May 2005
    well in terms of cost in ordering mass amounts... it would make more sense they used the same PN between cards gens. just added more chokes to handle the added current, since from the basic view i see. all the chokes are in parallelfor circuit, thats makes for a higher current ablilty. now weither the same PN is used by NV to ATI is another matter.. i would go with ATI's last or 2nd to last gen card for chokes, if you cant find/get a pn to use.
    were you ever able to measure the chokes with a DMM?
    "I Love To Camp!"
    HeatWare
  20. #20
    Banned
    May 2008
    vermont, yes i like women
    I have some chokes you could have but they are taller than the chockes on the 4850's
  21. #21
    Aug 2007
    Quote Originally Posted by Evilsizer View Post
    I have my DMM, but it doesn't measure inductance or capacitance. Ohms showed up at 0.2, and of course voltage and amperage were 0.
    Quote Originally Posted by philbrown23 View Post
    Cool! Do you think they'll work...are they electrically equivalent?
  22. #22
    Xtreme Mentor
    May 2005
    Westlake Village, West Hills
    find a data sheet, and find the part and try to match it. or, get the same gauge, and just count the number of coils.
    PC Lab Qmicra V2 Case SFFi7 950 4.4GHz 200 x 22 1.36 volts
    Cooled by Swiftech GTZ - CPX-Pro - MCR420+MCR320+MCR220 | Completely Silent loads at 62c
    GTX 470 EVGA SuperClocked Plain stock
    12 Gigs OCZ Reaper DDR3 1600MHz) 8-8-8-24
    ASUS Rampage Gene II |Four OCZ Vertex 2 in RAID-0(60Gig x 4) | WD 2000Gig Storage
    Theater ::: Panasonic G20 50" Plasma | Onkyo SC5508 Processor | Emotiva XPA-5 and XPA-2 | CSi A6 Center| 2 x Polk RTi A9 Front Towers| 2 x Klipsch RW-12d
    Lian-LI HTPC | Panasonic Blu Ray 655k| APC AV J10BLK Conditioner |
  23. #23
    Aug 2007
    Quote Originally Posted by Nanometer View Post
    Here's the part number listed on the choke: R47 811 T28
    I'm not sure how to find the data sheet. Google turns up nothing.
    I might be able to further dissect one of the damaged chokes, and possibly figure out the gauge, and number of coils, though.
    Thanks!
  24. #24
    Xtreme Guru
    Jan 2005
    Tre, Suomi Finland
    Those on X1800 too are rated quite a bit lower than the originals. After all, X1800 peaks at *only* 100W.
    R47 = 0.47µH, amperage needs to around 35A - or higher, there's no actual cap in amperage just as long as inductance is an approximate match to the original.
    edit:
    I guess I was way too vague when I said "you could salvage them from virtually any motherboard/video card with four CPU phases"...
  25. #25
    Admin
    Dec 2003
    Hillsboro, OR
    I've got a dead 2900XT, I take it that could be of service?
    Is it typical for the chokes to have the inductance listed on them? I can check mine out...
