I stumbled across this ages ago probably like many others maybe when leak testing but just lately i have been doing a lot of reservoir building for other projects and on one occasion i left a res hooked up with a DDC 3.2 for a good few hours and noticed the temperature of the liquid was really warm which got me thinking about heat dump from different pumps.
I know Martin touched on this with his Danger Den CPX-Pro Pump Review, noticing at the 2 GPM mark, the DDC is consuming nearly 21 watts, where then DD CPX-Pro is only consuming about 15 watts, so the DDC at that point is consuming about 40% more power which in the end becomes added heat to the loop so i just thought i would do a simple comparison (as only i can given limited equipment) between pumps without any form of cooling, basically to see what sort of heat dump is generated from the pump alone.
Anyway, both tests were started with normal tap water which gave a reading of just slightly over 20 degrees on start up with the temp probe attached to the top of the rad then left the loop running for 3 hours.
Results after 3 hours:
DDC 18watt 3.2 = 37.9
CPX-Pro = 29.4
The results are quite amazing really from pump to pump and it would appear running a DDC 3.2 gives quite a clear disadvantage right from the get-go though admittedly i was only using an XSPC Temp Censor to monitor temps but it does give a good like for like comparison.
Now i'm not trying to cause pump wars in any way but i do however think that this needs more in depth research with better equipment as imo, 8 or 9degrees is pretty significant in the scheme of thing.
.........anyone want to take this further??
