Page 1 of 2 12 LastLast
Results 1 to 25 of 45
Thread: Waterblock for 4870 X2?
    Jul 2007
    I'm gonna get a water block for my 4870 X2 card very soon.
    I think I've settled on getting one of the three EK water blocks.
    Unfortunately the store I'd like to purchase from, PerformancePC.com doesn't have the nickel water block in stock. So I could settle for the copper one for $165.
    Or I could go to Frozen CPU. All their blocks cost about $20 more, but they have the nickel one in stock for $184.
    I'm not really sure what the difference would be between the copper and nickel. Is it worth the extra $20 or more?
    If I just go with the cheaper copper ones at PerformancePC.com, are there any pros or cons with the see through acrylic cover versus the black cover on the water block?
    ▪ Intel Q9550 3.91GHz
    ▪ Gigabyte UD3P
    ▪ Patriot Viper 4x2GB DDR2-1000
    ▪ XFX 2x 6950s
    ▪ OCZ 2x Vertex 120GBs
    ▪ Seasonic M12 700 watt
    ▪ Cooler Master Cosmos S
    Aug 2008
    Arizona .USA
    copper can tarnish over time as where nickel wont . Acrylic can get get stress cracks in it. I believe this is due to the temps getting to high should be ok if your loop is cooling good
    ASUS P6T ~ Core i7 920 @3.8ghz ~ XfX HD4890~ 3x1Gb OCZ 1600Mhz ~2x150Gb WD Raptors ~ Antec 1200 ~ 37inch Jvc 1080p HDTV
    Engineering The Xtreme
    Feb 2007
    MA, USA
    Quote Originally Posted by JaVa_Az View Post
    not true, temps don't decide whether the acrylic cracks, I tend to think its mostly about luck and how good the acrylic you got on the block is
    Xtreme Cruncher
    Jun 2006
    On top of a mountain
    It's also about alcohol in the coolant miix. The tops are laser cut. Any alcohol on a previously heated piece of acrylic will destroy it.
    I must have gotten the last pair of those Nickel Blocks from PPC...sorry...
    They are so nice...let me rub it in
    I am going to brace my cards for sure.
    20 Logs on the fire for WCG: i7 920@2.8 X3220@3.0 X3220@2.4 E8400@4.05 E6600@2.4
    Apr 2005
    Tarnish doesn't hurt anything.
    Apr 2005
    Quote Originally Posted by CyberDruid View Post
    Be careful not to short your card as many others have done with the EK blocks.
    Jul 2008
    A google search will get you 10% off at frozencpu. I don't think the coupon ever expired. Ive used it 4 times now heh.
    MM H2gO - Win 7 Pro
    2 PA120.2 Thermochill
    MCP355 w/XSPC res top
    i5-2500k @ 5.0ghz w/Heatkiller 3.0
    Corsair HX850 - M IV Gene-z
    GTX 480 w/DD 480 ni/cu
    Mar 2005
    Sudbury, Suffolk UK
    I'm still waiting for nikel plated with a Acetal top. The black and chrome would go nicely with my Fuzion or a Supreme
    I guess Eddy might have an acetal top for sale on it's own
    Rig 1: Intel i7 2600K | Asus Maximus IV Extreme | 8GB Corsair Vengence 1600 C8 | Asus GTX 580 | 1x Corsair F3 240GB | 1x WD 1TB Black | Asus Xonar D2X | Silverstone TJ07 | BigNG | Corsair HX1000 | Corsair A50 |
    Rig 2: Intel QX6700 | Asus Maximus II Formula | 8GB Corsair DDR2 |HIS 4870 1GB | 3x 500GB F1 RAID0 | X-FI Fatal1ty | CM-690 II |Corsair HX750 | Corsair A50 |
    Rig 3: Intel E6850 @ 3.6GHz Fuzion V2| Asus Maximus Extreme | Full EK NB/SB/Fets | 4GB Corsair Dominator DDR3 1800| EVGA 8800GTX KO EKFC8800GTX |2x WD640GB RAID0 | Laing DDC3.2 w/Petra top | 120.2 BIX | 120.2 BIS | EK 150 Res | BigNG | X-Fi Fatal1ty | Akasa Eclipse |
    | Windows 7 Ultimate x64 SP1 on all |
    Mar 2008
    Netherlands
    Quote Originally Posted by Blkout View Post
    i ordered one of the copper-acrylic top version for my 4870x2..
    i emailed EK last week regarding what size of washers i needed but they didnt reply..
    only thing i know is that i need non-metal M3 washers.maybe this is a stupid question, but what outer diameter and thickness is needed though? can anyone elaborate on this?
    Intel Q6600 @ 3.6GHz
    Asus Blitz Formula SE
    OCZ ReaperX PC6400 2x2GB
    Sapphire HD4870x2
    X-Fi Elite Pro 7.1 & Logitech Z5500
    Samsung Spinpoint T166 500GB
    Samsung 226BW
    Zalman ZM1000-HP
    Watercooling
    Loop 1: DDC3.2 (XSPC Restop), Fuzion v2, BIGTX360 (6x S-Flex F)
    Loop 2: DDC3.2 (XSPC Restop), EK 4870x2, TFC X360 (3x S-Flex F)
    Loop 3: to come
    [DarthBeavis] "I am gonna try to mod one of these into my wife so can get an early warning of when she gets angry . . ."
    Aug 2007
    Leicester England
    I was one of the first ones to find out about the shorting problem and asked eddy to post here. All I did was to use some paper washers left over from previous water blocks, doesn't have to be anything fancy just to stop the metal from touching.
    Its been fine since then.
    Intel I7 940 @4Ghz - water cooled
    Corsair Domitator 12800 12GB
    Asus Rampage II Extreme
    HIS ATI HD 4870X2 - water cooled
    Creative X-fi Xtreme Gamer Fatal1ty
    Enermax Galaxy 1000W
    3x Samsung F1 500GB HDD
    OCZ Vertex 120GB
    TJ07 Murdermod
    LG W3000H 30" Monitor
    Vista Home Premium x64
    Jan 2008
    Down Under
    Quote Originally Posted by Giannis86 View Post
    Mine were 8mm in diameter and 1 mm thick.
    Chasing After Diety
    Jan 2007
    Absolutely Speachless :O
    CD i think DD's is made nicer and a bit easier to mount.
    :T
    Lind: Dual Gainestown 3.07
    [12:37] skinnee: quit helping me procrastinate block reviews, you asshat. :p
    Its my fault.. and no im not sorry about it either.
    Jan 2008
    California
    does anyone have pics of watercooled crossfire cards? i'd like to see what fittings you're using to connect them and how they look. i know koolance makes a doubleslot fitting that would work but i'm not completely sold on it yet.
    Chasing After Diety
    Jan 2007
    RAID avoid koolance for blocks and attachements.
    Lets say i dont fully trust them yet.
    Heres how they bit me in the ass after giving them a second chance:
    The double slot fittings i have been using for a while and absolutely love them:
    I ditched Xfire and went single HD4870X2 + ARC-1680ix Controler. Dayam controller is about as long as my HD4870X2
    Chasing After Diety
    Jan 2007
    so i thought i should share this with ya guys.
    Ambients recorded at 26.5C
    Pump DDC-3.2 On EK 250 Res.
    Rad: MCR220! <--- YES IT WILL WORK
    Load Software: RTHDRIBL
    Idle Temps:
    Mar 2008
    Netherlands
    Not bad temps there naekuh..these cards do produce lots of heat but it seems to me that people are overreacting about how a triple rad is a must...
    i have the Sapphire edition of this card..i was just fiddling with rivatuner and im kind of surprised how good the stock cooler is..at stock speeds it sucks basically (idles around 75)..but when i turn it up to 50% speed it now idles at 43C
    anyway the sound it makes isnt pleasant for 24/7 though..
    my EK block should be on the way in a couple of days (waiting for some parts to come in stock first...)..i will add my results too then
    Sapphire HD4870x2
    Samsung 226BW
    Zalman ZM1000-HP
    Watercooling
    Loop 3: to come
    Feb 2007
    Vancouver, B.C.
    So, EK finally releases a "properly built" full-covered block in 4870x2.
    I got their co-called nickel-plated FC block for my 4870 about a month ago but has nothing to write home about. It uses a bolt-on alu plate for the VRM cooling and imo it's definitely not adequate.
    While I am content with the main block, which keeps my GPU and memory in the low 40s running Furmark, the VRM temp still hovers around 100C thanks to the alu add-on plate.
  18. #18
    Dec 2002
    HB
    Quote Originally Posted by clee View Post
    That is NOT GOOD about the VRM's.
  19. #19
    Feb 2007
    MA, USA
    what more are you asking for? the VRMs are designed to run at 125C and it sounds like your temps with the EK 4870 are about 28C LOWER than people having trouble with crashes from VRM overheating....
    i just bought 2 of these nickel 4870 blocks today and from you've said it sounds like they are going to perform great
    (I dropped $1k on a new case and other parts today you guys are in for a treat come january )
  20. #20
    Apr 2008
    Canada, by the mountains
    [IMG] block "tipping" scale [/IMG]
    I just noticed, and was kinda surprised, that the EK Nickel-plated blocks weigh less than the all copper acrylic or acetal models (970 v. 920 grams.)
    The Koolance weighs in at a "trim" 794g; the DD block is 2lbs (907g.).
    Time is an illusion. Lunchtime, doubly so. Douglas Adams
    QX9650 @ 3825mhz CoolIT FZone
    2x HD3870X2 @ 845/946mhz air
    Asus Maximus Formula 0907
    2x2048mb OCZ Reaper 8500
    2x Raptor 150G Raid0; 'Cuda 1000G
    1200W Thermaltake
    xFi Extreme Gamer/ Z-5500
    Vista Ult. 64
    Cosmos 1000
    30" NEC
  21. #21
    Aug 2008
    Rockville, MD
    There is a good article on [H]ardOCP on how to adjust the fan on the 4870x2. Anyone looking to get better temps who aren't watercooling should check it out
    http://enthusiast.hardocp.com/articl...50aHVzaWFzdA==
  22. #22
    Feb 2007
    Vancouver, B.C.
    Quote Originally Posted by RealRedRaider View Post
    Contact Eddy if you have a problem...
    Nickel plated EK, All The Way ............. FTW
    No problem here, it gives great gpu temp and it gives great memory temp. It's not too restrictive and it looks good.
    My only qualm is the aluminum add-on piece.
    But hey, the block gives me eye candy in my MM case, I just refrain from running Furmark again.
    Quote Originally Posted by SNiiPE_DoGG View Post
    I bet a DD-4870 or even a Koolence FC could probably lower it by more than 50C.
    Dude, I ran the 4870 with the stock cooler for over a month before purchasing this, it's only a few degree better with the EK block when it comes down to VRMs cooling.
    But if you like it, that's all good for you , whatever floats your boat.
    Don't mean to ditch EK here. But I just don't understand why they opted for an alu add-on piece on a full block. ??
    And to the OP. Sorry to hijack your thread. I guess it's got nothing to do with the 4870X2 block. That "all-in-one-piece" block for the X2 should be fine
  23. #23
    Feb 2007
    MA, USA
    Its not really to ek's credit here, but I can see why they did the ALU plate. they only need to mill a one design copper base for the 48xx series then add the alu plate to make it 4850 or 4870
  24. #24
    Chasing After Diety
    Jan 2007
    MCR220 + DDC-3.2 + EK-Xres with silver Ingot (otherwise it would be a koolance res) + DangerDen HD4870X2.
    (oh and this is with jab-tech's Orange Low Speed Yates )
    Ambients recorded @ 26-27C
    Watercoolant temps @ 30-31C under heavy usage
    My GPU Full Load Temps:
    My VRMS are fine.
    Ack i posted the pic twice. :\
  25. #25
    Nov 2003
    Central Illinois
    Quote Originally Posted by NaeKuh View Post
    My VRMS are fine.
    Those are very impressive temps, that DD block seems like a great option.
