Hi i am just done with modding a HD4870X2 gfx for my mate Mathis77 and i tought i would do a little guide so here it comes.
First of the 2 Vgpu mods.
Here is the solderpad on the back of the card for the gpu at the rear of the card.
And here is my own discovery the solderpad for the other gpu in front of the card on the back i dont think that others have found it and that is because it is hidden under the laquer on the print abd you have to scratch the laquer of whit a razorblade to get to the solderpad.
Now we just have to solder some wires to the 2 solderpoints so here we are first the gpumod for the gpu at the back of the card.
And then the gpumod for the gpu at the front of the card.
And now to solder two 50 Ohms multiturns vrs on the card.
Here is the Vgpu measurring spots for both gpumods
When this is done we will flash the card with the asus top bios so we can clock the card a little further than normal.
First you have the get som files on the Inet.
http://frip.dk/riget/asus0.rar
http://frip.dk/riget/asus1.rar
The 2 Asus top bios With 900mhz core and 1000mhz mem in CCC and 790/915mhz default 3D clocks
http://www.techpowerup.com/downloads...lash_3.60.html
Atiflash for flashing the card in dos
http://dlsvr04.asus.com/pub/ASUS/vga...martDoc524.zip
Asus smartdoctor for controlling the fan and oc the card if u dont like the ATI CCC and i you want you ca use Amdgputool but then you have to set the fan after you have ocet the card
http://www.techpowerup.com/downloads/330/.html
HP tool to make your usb stick bootable
http://www.techpowerup.com/articles/...s/USBImage.zip
Boot image files for the usb stick
And a guide to flash the card
http://www.techpowerup.com/articles/...g/vidcard/34/5
atiflash -f -p 0 asus0.bin
atiflash -f -p 1 asus1.bin
what to write in atiflash to flash the card
Enjoy
"Edit" this asus bios has a more aggressive fan profile than the normal
HD4870X2
