simple question really, does it work for you?
and by working i mean, all the sliders work and you can adjust whatever options it gives you, that being differant options for differant chipsets. and also not leave you with an unstable system after use, ie: corupted bios, recurring windows BSOD, you get the picture
as this is very black and white, it is either a 'yes' or 'no' option, i was going to put 'sometimes' in, but i dont see the point.
i also havent put an 'end' time for poll, we can decide urselves when the the thread dies, or we have enough info to make a decision between us, we are after all, all grown ups. ;-)
feel free to post specific problems you have found with any release form the following,
AMD OverDrive™ Utility 1.0 (2007-5-23)
AMD OverDrive™ Utility 1.1 (2007-5-31)
AMD OverDrive™ Utility 1.1 (2007-6-1)
AMD OverDrive™ Utility 1.2 (2007-6-8)
AMD OverDrive™ Utility 1.3 (2007-6-18)
AMD OverDrive™ Utility 1.4 (2007-6-20)
AMD OverDrive™ Utility 1.5 (2007-7-11)
AMD OverDrive™ Utility 1.6 (2007-7-16)
AMD OverDrive™ Utility 1.7 (2007-7-31)
AMD OverDrive™ Utility 2.0 (2007-8-10)
AMD OverDrive™ Utility 2.0.1 (2007-8-17)
AMD OverDrive™ Utility 2.0.2 (2007-8-24)
AMD OverDrive™ Utility 2.0.3 (2007-8-31)
AMD OverDrive™ Utility 2.0.4 (2007-9-14)
AMD OverDrive™ Utility 2.0.6 (2007-9-25)
AMD OverDrive™ Utility 2.0.7 (2007-9-28)
AMD OverDrive™ Utility 2.0.8 (2007-10-12)
AMD OverDrive™ Utility 2.0.9 (2007-10-23)
AMD OverDrive™ Utility 2.0.11 (2007-11-26)
AMD OverDrive™ Utility 2.0.12 (2007-12-11)
AMD OverDrive™ Utility 2.0.16 (2008-01-18)
AMD OverDrive™ Utility 2.0.17 (2008-02-26)
AMD OverDrive™ Utility 2.1.0 (2008-03-14)
AMD OverDrive™ Utility 2.1.1 Beta (2008-06-02)
AMD OverDrive Utility 2.1.2 (2008-06-11)
AMD OverDrive Utility 2.1.3 (2008-09)
