Results 1 to 25 of 33
Thread: Cooling BlackOps: Air & Water
Threaded View
    May 2008
    Under heavy conditions, it's a good idea watering NB with CPU:
    As a gaming rig, some fan coolers should also fit to BlackOps, thus i decided to try out some fan coolers last night. Noctua NH-U12P and Cooler Master Hyper Z600 are both fit to mobo without any issue and work prety good:
    DuOrb is another choice and helps cooling whole body; DDR3s, Phases and some other chips, but doesn't fit easy and superpositions with NB and needs to be filed:
    Rig: E8600/BlackOps/KingstonHX14400/9800GX2SC/HighPower 1000W&560W/Twkd&Tnd&Light*XP/sum watering & fan stuff...
    UPDATE for NB Fan:
    NOCTUA has just one position (not two!) without NB Fan issue:
    But NOCTUA's fan should be very close to PSU Fan. Works good...
    CoolerMaster's position without NB Fan issue:
    U can use just one NB Fan screw. Works good...
    DuOrb has just one position (not two!) without NB Fan issue:
    Works good...
    Intel DP55KG-Core i5-750-Kingston Hyperx DDR3 1800MHz-EVGA 9800GX2SC-High Power HPC 1000 G14C 1000W-HP W2448HC HDMI
    Intel DP55KG-Core i5-750-Kingston Hyperx DDR3 1800MHz-Sparkle 8800GTX-SilverStone ST1000NV 1000W-Samsung T260HD
