Ok so I got the new one even though I really didn't want to buy it.. I know I know sign of a weak mind
So here we go!
Day 1 Hardware:
Intel E8600 [Q820AXXX]
Gigabyte EP45T-Extreme
Gigabyte 9600GT [Turboforce - fanless | NO VMODS]
OCZ Plat 1600EB
7200.9 160GB
Silverstone DA-1000
Benq 19" LCD
Cooling:
LN2 with Astra on CPU and Tek-9 4.0 on GPU.
OS was a little bit stripped WinXP.
Some results I would like to share:
3DM01
http://www.hwbot.org/result.do?resultId=770394
3DM03
http://www.hwbot.org/result.do?resultId=770403
3DM05
http://www.hwbot.org/result.do?resultId=770405
Aquamark 3
http://www.hwbot.org/result.do?resultId=770407
Super Pi MOD
http://www.hwbot.org/result.do?resultId=770413
CPU-Z Validation
Observation:
First the board, I think the board I have is not really friendly. I mean with E8400 it couldn't boot more then 555FSB. With E8600 I have got it going in windows @ 580. Anything high it will crash while loading.
Now the Graphic card, honestly I think if I don't run LN2 on GFX and just use chilled-liquid cooling.. I can manage same. The card is cold-bugged at -60C, hence I could not push it high enough to take the top spots:p Also I did not use the GamerHUD utility and still card worked fine till 870 for 3D01 and 860 for others. Strange thing for me was 3DM03... I mean I thought I could go higher but during GT2 @ one point before ending it would slow down drastically and that will give lower score I think 48K was possible. May be some other day and driver will make the cut.
Many thanks to Gigabyte and Silverstone for support
Harshal
TEAM THL
