Page 1 of 5 1234 ... LastLast
Results 1 to 25 of 118
Thread: Sanded down the IHS of a Q6600 to the silicone.
    Sep 2006
    Brooklyn, New York
    I wanted to do this for a while and finally got the patience to do it. It took 6+ hours of sanding by hand and here is the result:
    As you can see the chip somehow survived. I took a screen shot in the morning and I was in a rush. My temperature before this procedure was 75-80 with both the cooler and the IHS lapped. After it will not go above 56 at 3.2 Ghz and that is with an additional +.1 to the vcore on top of the minimal needed to run 3.2 stable. this is with 1.375 at full load and I need 1.275 for that speed to be stable. I want a Solid 3.6 GHZ out of this. The Q6600 I have has a vid of 1.2875 are reported by coretemp and the cooler I'm using is the Tuniq. By the way a lot of people seem to think that the core and the IHS are soldered and this is simply not true. They use some hind of very strong silver adhesive that is no fully solid. No matter how good of a cooling system someone has, if the IHS does not have good contact between the die and the bottom of the IHS the temps will not be the best they can be. I did this ot get the most out of my gear.
    I used 100 grit wet-dry and I was lapping without water because water killed the sand paper way to early. You have to completely shave off the top part of the IHS and this will take 6+ hours. If you rub too fast it will get very hot so when it starts to heat up pause and continue. after you the the whole top of proceed with caution. When i was doing it one part of the IHS was taller than the other so i almost panicked and gave up. you can pretty much see it in the first picture that it was not leveled. Keep going with a 400 grit until all the silver paste is gone and the cpu looks roughly like the second picture. then finish it off with 800 and stop. This is not a beauty pageant so there will be scratches on the silicone. they look deep but they are nothing to worry about. The goal is to have the dies leveled with the outer part of the partly decapitated IHS so whatever will be rolling your monster will not crush them into tiny bits. You have to carefully remove the cpu clamp from the motherboard. You cannot use a pushpin cooler. In my case since 2MM disappeared from the CPU my cooler was not holding it very tight so I used washers beetween the spring and the mounting plate to give it some extra hold. I picked it up by the cooler and it was fine, I also rotated the motherboard in the air by the cooler and it did not budge. I even picked it up by the cooler while the power is on to make sure there is good contact. There will very little clearance between the the cpu socket and the bottom of the cooler after this so make sure you do not shave off more than absolutely necessary. Make sure your cooler is completely flat at the base. Proceed with caution. I will follow this up with some pics later.
    How to clean it: I used the arctic clean solution. Fill a small glass to a point where the cpu is submerged and dip the cpu and then use a toothbrush to make sure all that copper dust/paste is off of everything u can let the cpu soak in it but do not leave it there for more than 5 minutes. do not use a plastic or Styrofoam cup because the arctic clean will dissolve it and it will not be cool. After step 1 use the step 2 bottle and dunk it in, wait and wipe off. Use a hairdryer to completely dry and enjoy.
    More pics:
    1
    2
    The temps at 3.6
    Valid
    Oct 2007
    socal
    nice glad it still works
    Nov 2007
    ch
    I had the same idea, thx for testing it out for me :P
    I´m also going to attempt this method, seems much safer than using a razor blade.
    Do the brackets of the socket still hold the CPU securely in place now that most of the IHS is gone?
    Sep 2006
    Brooklyn, New York
    Quote Originally Posted by FrogBite View Post
    You have to remove the bracket because it it stands taller than the shaved off area. The cpu is held in its place by the pressure of the heat sink that is screwed on.
    Nov 2007
    ch
    ok, thx a lot.
    May 2007
    safer way to remove ihs :P?
    Gaming Rig
    Intel E6300
    Intel Mobo
    2 Gig OCZ 800 (800 5,5,5,15)
    Saphire Ati 4870
    22inch LG Flatron W2230S
    Nov 2007
    ch
    Well most people that use the razor blade method end up destroying their chip. With this method, given that you do the last bit of lapping slowly is in my opinion safer.
    Sep 2006
    Brooklyn, New York
    My thought exactly
    be very careful lapping the last of the Intel tim to not lap it to a point of the CPU latch being higher than the top of your core.
    Sep 2006
    Brooklyn, New York
    Here is an update:
    I left it to prime for 16 hours and it passed.
    I turned off the AC and close all the windows before going to work. I came back and took this screen shot. The ambient temp was 27C at the time of the screen shot.
    of the Strawhat crew.
    Mar 2008
    West TN
    What kind of cooling are you using? Sorry if you've already said it, and I've missed it somewhere.
    XtremeSystems BF3 Platoon - Any XS member is welcome.
    Sep 2006
    Brooklyn, New York
    Quote Originally Posted by Gamekiller View Post
    A lapped Tunic
    Mar 2006
    Montreal, K-Beck
    Excellent mod! How much sandpaper did you end up using? Do you think you could use a file instead of 100 grit sandpaper?
    Chasing After Diety
    Jan 2007
    Absolutely Speachless :O
    i dont want to burst this thread.
    Its a great mod, but however you just screwed yourself on using mostly all the recient waterblocks on the market due to the bowed nature.
    :T
    Pray you never go on water.
    Quote Originally Posted by majestik View Post
    i believe your on water, so you should read my statement i just posted.
    Lind: Dual Gainestown 3.07
    [12:37] skinnee: quit helping me procrastinate block reviews, you asshat. :p
    Its my fault.. and no im not sorry about it either.
    Sep 2006
    Brooklyn, New York
    I used about 10 sheets. A file would probably work but it is more dangerous. I would try to file most of it and leave a little for the paper. you will need a file that is very well made and flat and wide enough for the whole IHS to fit on it. Make sure to keep a firm grip on it. and obviously lap any coolr that is going to sit on it FLAT
    Sep 2006
    Brooklyn, New York
    Quote Originally Posted by NaeKuh View Post
    :T
    Can you give me an example of why this wont work for water because I don't follow you.
    Jul 2004
    Finland
    Quote Originally Posted by Ruslan View Post
    I wanna know same thing.
    Xtreme Mentor
    May 2005
    Westlake Village, West Hills
    Cause you can crack the die from uneven pressure, I haven't done it, but then again I never used a bowed waterblock anyways.
    PC Lab Qmicra V2 Case SFFi7 950 4.4GHz 200 x 22 1.36 volts
    Cooled by Swiftech GTZ - CPX-Pro - MCR420+MCR320+MCR220 | Completely Silent loads at 62c
    GTX 470 EVGA SuperClocked Plain stock
    12 Gigs OCZ Reaper DDR3 1600MHz) 8-8-8-24
    ASUS Rampage Gene II |Four OCZ Vertex 2 in RAID-0(60Gig x 4) | WD 2000Gig Storage
    Theater ::: Panasonic G20 50" Plasma | Onkyo SC5508 Processor | Emotiva XPA-5 and XPA-2 | CSi A6 Center| 2 x Polk RTi A9 Front Towers| 2 x Klipsch RW-12d
    Lian-LI HTPC | Panasonic Blu Ray 655k| APC AV J10BLK Conditioner |
  18. #18
    Nov 2007
    ch
    Because "most" CPU blocks are bowed and not flat.
  19. #19
    Jul 2004
    Finland
    And after that it looked like this http://paakkis.oc-papat.com/QX6700.jpg
  20. #20
    Mar 2003
    The Netherlands
    It doesn't really matter if the cpu latch part of the ihs that remains is slightly higher than the die... because you can remove THAT with the razorblade method, and you'll have a perfect overview of where you're cutting so you won't cut any resistors that are there
    lol... This forum requires that you wait 70 seconds between posts. Please try again in 8 seconds.
    *phone rings*
    Friend: Do you have a spare PSU lying around?
    Me: No why?
    Friend: My PSU just blew up, I think the second 8800GTX might have been too much for it to handle
    Me: what PSU was that again?
    Friend: Antec 480w
    Me:........
  21. #21
    Sep 2006
    Brooklyn, New York
    This is how much you need to take off. I have a celeron that i might make a ginnypig and take it to a power tool carefully...
  22. #22
    Apr 2008
    sneakerN3T
    a review i read talked about taking the ihs off 3 cpuz and all of them failed. seems this is the way to do it if you want to take it off.
    Quote Originally Posted by paakkis View Post
    your cpu does not have the ihs copper frame and thats why its cracked. this one is different like you see in the second pic. it's kind of like the old athlon xp was with its four rubber standoffs. so there shouldn't be any problems.
  23. #23
    Mar 2006
    Montreal, K-Beck
    :T
    Good call, I guess you would need to sand the waterblock as well. Although most have very thin bases.
    And me, I don't have balls size of watermelons to sand my IHS anyways - I'm just curious
  24. #24
    Xtreme Guru adamsleath's Avatar
    Nov 2006
    Brisbane, Australia
    thats a pretty picture well done.
    although something i dont have the patience for
    i7 3610QM 1.2-3.2GHz
  25. #25
    Banned
    Jun 2006
    Durham, NC
    Pretty cool, and real time consuming. Interesting, though--I hadn't ever considered sanding the entire IHS off down to the core.
Tags for this Thread
