Today I recieve new product ABIT X48 GT3 support with DDR3......for while this pictureSpecial Thanks to P.T SPEKTRUM UTAMA JAKARTA INDONESIA
BIOS :
In my country this board price $245 cheaper with X48 chipset DDR3......
TEST BED :
ABIT X 48 GT3
INTEL E 8500
ASUS HD 4870 thanks to ASUS INDONESIA
PATRIOT PC 1600 LLK ( Micron D9GTR )
PSU Corsair 1000 watt
FSB 525 on E 8500....Dual SPI 4M
FSB 525 on PC Mark 05
FSB 530 on 3D Mark 01
I have still problem with this bios....some divider not perfect but I hope good result with new bios later ....
Finally, Abit! A nice looking motherboard, and a monster NB cooler, but- do you think it would interfere with some of the larger aircooled heatsinks out there? It looks like a TRUE may have problems fitting on that board, if the NB cooler is tall enough.
Main Gaming PC- Intel Desktop: "Monolith"
i7 950 @ stock (working on the OC now) -- Asus P6X58D-E
6GB G.Skill Pi DDR3 1600, 7-8-7-24 -- Corsair 1000w PSU -- Corsair 700D
Intel X25-M 120gb SSD, Windows 7 64 Ultimate -- 640gb WD -- EVGA GTX570 SC
XSPC Rasa, Heatkiller GPU-X3 hole edition, Swiftech MCR320-QP, MCP-350
AMD File Server "CyborgMind": X2 4000+, MVA-VM, 4gb RAM, 6.2TB storage, WHS 2011
Intel HTPC "Fei": Pentium 4 2.4c @ 3ghz, IC7, 1gb pc3700, 7800GS, Antec Overture II
Same board I used at Computex, you will love the lack of droop.
First time I seen "Hootfoot"
Intel 9990XE @ 5.1Ghz
ASUS Rampage VI Extreme Omega
GTX 2080 ti Galax Hall of Fame
64GB Galax Hall of Fame
Intel Optane
Platimax 1245W
Intel 3175X
Asus Dominus Extreme
GRX 1080ti Galax Hall of Fame
96GB Patriot Steel
Intel Optane 900P RAID
No droop at all.
Intel Optane
Platimax 1245W
Intel 3175X
96GB Patriot Steel
finally abit released a ddr3 mobo. am curious how it behaves under ln2.
what Vcore only 1,6v in bios ? dawn
[Core i7 4820K Ivy Bridge-E @4,7Ghz Vcore 1.28v][Asus Rampage Iv Extreme bios 4403][16Gb G-skill Ocz 2133mhz DDR3][Lian Li Pc2120 B, black Case][480Gb OCZ SSD main disk+120Gb ssd game disc][EVGA GTX Titan@900mhz Oc luft ][Os Windows 7][Telia 1000/250Mbits fiber ][24,4TB Lagring] upcoming Intel Haswell-E 8 cores/16 Threads next year Q4 2014 ?
Naw. 1.6V + whatever offset gives = should be enough (1,9 - 2,1V I'd guess).
I am more worried about that 5 phase digital PWM we all know so well. I do hope they didn't use the exact same solution as with the IX38, even though the layout seems identical.
The IX38 coudln't hold more than 80A for longer periods of time, I killed 2 of them in 2 weeks with only 1,32V Vcore but folding 24/7...
So when is abit going to get on the ball and release their X48 and P45 mobos?
Hi Hazzan,
Could you test a 40GP ( SPI 1M and 32M at 4ghz) please ?
thanks
ps: it seems that the board has hit some German shop, had to be confirmed , target price of ~175€.
P5E Deluxe x38 @ Rampage Formula (Bios 0802) || E8600 @ 4500mhz @ 1,38v || Ultra 120 Extreme + 2 Yate Loon D12sl + IFX-10 || 2 GB Cellshock PC8500 D9GMH @ 600 (2.3v) 5/5/5/15/2T || 4 x 640gb WD sata II || HD4870 @ 775 - 1000 || CM Stacker STC-01 + 4 Yarte Loon D12SL || Enermax modu82+ 625W || Audigy2 ZS || Logitech Z-5500D || Lacie Electron22BlueIV 22"
As a matter of fact, they are..
Just checked and it seems that both the IX48 GT3 and the IX48 Max are in stock all around here (not just 1 shop but like 10+).
What exactly is the difference between these 2 anyway? The Max costs only a few € more at 167€ compared to the GT3 at 161€...
That's a nice looking BIOS, a lot different than the standard AWARD Blue/White.
No, both are DDR3 and look identical![]()
looks nice simple but packs a punch, maybe I can move back to abit after so long trying to find an acceptable replacement.
It seems i have a strange board then, mine can't hold vcore at all. It jumps for +-0,02V around the set value no matter if the cpu is loaded or idle. No wonder I have stability problems.
Yes.
have same motherboard abit ix48 gt3 and its suxx on mem dividershope abit will fix this problem.
