Today , i test my BlackOps with the bios G27
My Setting :
Code:
E8600 Q820A606
Foxconn BlackOps X48 Bios G27
2x1024mo DDR3 OCZ 1800 Platinium with Dimm White
Nvidia 8800GTX 768mo
WD Vélociraptor 300go 10000tr
Coolermaster RealPro 1000w
Full Aircooling : Mini-Big Typhoon + 2x120mm
Setting Boot :
CPU feature :
disabled except core multi-processing
Memory Timing Config :
ECC-disabled
Dram Timing-Manual
tCL-5/6T
tRED-5T
tRP-5T
tRAS-15T
tRFC-55T
PL-L10
tWR-18T
tWTR-15T
tRRD-6T
tRTP-6T
All prechg to refresh-Auto
Refresh Period Ratio-X1
tREF-Auto
Command Per Clock-1T
Voltages :
CPU Voltage Multi-X1.075
CPU-1.2675
CPU Vdroop-Enabled
CPU PLL-1.622025v
CPU VTT-1.425
CPU GTL's-All Default
NB Voltage-1.673v
NB GTL-Default
SB Voltage-1.575
Dram Voltage-1.955
Everything else-Default
Instant Overclocking :
CPU Clock Ratio Unlock : Enabled
CPU Clock Ratio : x 7
CPU Clock Ratio : +0.5x : Disabled
CPU Clock (FSB) : 550mhz
CPU Clock vs Memory Speed : 1 : 2.4
System Memory Speed : 1321mhz
CPU Clock Skew Control : 300ps
CPU Clock Amplitude Ctrl : 900mV
PCIx clock : 101MHz
PCI clock : 33.6
Auto detect and spread spectrum : Disabled
OC Recovery : Enabled
Max Screen Dual DDR : 595mhz
http://valid.x86-secret.com/show_oc.php?id=404270
Superpi 1mo :
Superpi 32mo :
Not optimisation for the moment , i have found the fsb max benchs with different ratio but it's the best ratio :
Ratio 1 : 2 = boot at 565mhz , max 591mhz
Ratio 1 : 2.4 = boot at 565mhz , max 595mhz
Ratio 1 : 2.665 = boot at 530mhz , max 545mhz
Ratio 1 : 3 = boot at 465mhz , max 492mhz
Ratio 1 : 3.2 = boot at 445mhz , max 460mhz
Ratio 1 : 4 Cpu 200 = Not Boot at 333Mhz
Ratio 1 : 4 Cpu 266 = boot at 333Mhz , max 365mhz
Ratio 1 : 4 Cpu 333 = boot at 480Mhz , max 510mhz
Ratio 1 : 4 Cpu 400 = boot at 470Mhz , max 500mhz
Now , I will try to tweaker the Mchbar to find the best Perf/Fsb and also tested my E8600 under LN2 (with the NB in LN2)
