Page 1 of 2 12 LastLast
Results 1 to 25 of 34
Thread: Playing with Foxconn A79-S, Phenom 9950 and CrossFireX for G|C
Hybrid View
    Xtremely Bad Overclocker
    Jan 2005
    East Blue
    Hi there,
    I did not overclock AMD for a long time but preparations for Games Convention in Leipzig/Germany making me testing Phenom this week-end with CrossFireX
    Board is Foxconn A79-S wit 790FX chipset & SB750 Southbridge.
    Bios has some room for improvements but all in all it is not that hard to overclock it so far. Maybe I will try a little cold on it to see where coldbug is.
    All the pots, cards and CPUs from me for G|C - giorgio will bring at least the same amount of things and we will have a great time for sure from 21.08.-24.08. in Leipzig
    All in all I have 4x HD4850 to test but no Vista yet
    First benches on air 3260 MHZ CPU, some issues when clocking the cards just 5 MHZ higher - I am still trying to figure out how to solve that. Core 1 & 4 are good, 2 & 3 won't pass 32m with this setting. The board allows to clock the cores separately what I am going to try right now.
    regards
    SoF
    3495 MHZ 3xHD 4850 Vista SP1 81k 3D Mark03
    | '12 IvyBridge - "ticks different"... | AwardFabrik IvyBridge round I by SoF | AwardFabrik IvyBridge round II by angoholic & stummerwinter
    | '11 The SandyBridge madness... | AwardFabrik / Team LDK OC-Season 2011/2012 Opening Event
    | '10 Gulftown LaunchDay OC round up @ASUS RIIE | 3DM05 2x GPU WR LIVE @Cebit 2010 @ASUS MIIIE | SandyBridge arrived @ASUS P8P67
    | '09 Foxconn Avenger | E8600 | Foxconn A79A-S | Phenom II 940 BE | LaunchDay Phenom II OC round up
    | '08 7.438s 1m LN2 | AMD 1m WR LN2 | 2nd AOCM | Phenom II teasing
    | '07 100% E2140 | 106.5% E2160 | 100% E4500 | 103% E4400 | 5508 MHZ E6850 | 7250 MHZ P4 641 126.5% by SoF and AwardFabrik Crew all on Gigabyte DS3P c? and LN2...
    | '06 3800+ X2 Manchester 0531TPEW noHS 3201MHZ c? | 3200+ Venice noHS 3279MHZ c? | Opteron 148 0536CABYE 3405MHZ c? all on Gigabyte K8NXP-SLI compressorcooled
    | '05 3500+[NC], 3000+[W], 2x 3200+[W], 3500+[NC], 3200+[V] 0516GPDW
    Quote Originally Posted by saaya
    sof pulled a fermi on all of us !!!
    Jul 2008
    This is going to be insteresting :P
    Jan 2005
    East Blue
    I do not fully understand ACC option yet, set on auto I could pass some 3.300 MHZ benches:
    Apr 2008
    Hi
    I'am using the new foxconn a79a-s mother board also .I got my rig up and running a couple days ago for right now using 3.0 ghz at stock v (1.32v) for my 24/7 clock.
    I bump it up to 3.2 ghz last night and did a 3dmark-06 run . On my old mother i was never able to run over 2.9 ghz and and when it booted at 2.9 it would run long enought to get a 3dmark-06 run in and that was it . The new SB750 chip and ACC are just what the phenom cpu needed.
    Nov 2006
    Poland / Rypin
    SoF, have you got destroyer ?
    I saw there one
    can you test him with 9950 ?
    hmm, if you have got those all hardware you can make the the best scores in 3d on amd
    Schedule of Live Extreme Overclocking - info Thread
    Quote Originally Posted by K404 View Post
    "My Backup is bigger than Your Backup"
    Jan 2005
    East Blue
    I think I will go for some good AMD results Destroyer is going to be tested later but it does not have ACC which seems to help with OC.
    3375 MHZ 1m 23.203s 1.39Vcore
    compared to current hwbot results I am not doing too bad with the 9950 until now
    Xtreme Cruncher
    Apr 2008
    Ohio
    Glad to see more results from these chipsets.. Does that run stable at 3.3 with 1.36v?
    So are you saying I need to get another 4850 now...
    ~1~
    AMD Ryzen 9 3900X
    GigaByte X570 AORUS LITE
    Trident-Z 3200 CL14 16GB
    AMD Radeon VII
    ~2~
    AMD Ryzen ThreadRipper 2950x
    Asus Prime X399-A
    GSkill Flare-X 3200mhz, CAS14, 64GB
    AMD RX 5700 XT
    Jun 2008
    Essex, UK
    Quote Originally Posted by SoF View Post
    Hah! Thats me at the bottom.
    I snuck in quick and was no.1 for a few days.
    Anywho, that board (the first SB750 i've seen over here) is nearly £200, which i'm absolutely not willing to pay for a mid range piece of hardware.
    oooh, exciting.
    Xtreme Cruncher
    Apr 2008
    Ohio
    Quote Originally Posted by D-Cyph3r View Post
    I did a 24 sec run...
    ~1~
    AMD Ryzen 9 3900X
    AMD Radeon VII
    ~2~
    Asus Prime X399-A
    AMD RX 5700 XT
    Jan 2005
    East Blue
    3.3 seems to be quite ok stability wise. 3375 I can bench 03 on core 1&4 now but still can't go over 675 GPU clock :
    Feb 2008
    i'd say the cards become too hot with that stock cooler.. unfortunately..
    1. ASUS Sabertooth 990fx | FX 8320 || 2. DFI DK 790FXB-M3H5 | X4 810
    8GB Samsung 30nm DDR3-2000 9-10-10-28 || 4GB PSC DDR3-1333 6-7-6-21
    Corsair TX750W | Sapphire 6970 2GB || BeQuiet PurePower 450w | HD 4850
    EK Supreme | AC aquagratix | Laing Pro | MoRa 2 || Aircooled
    Feb 2008
    yeah its worth that for some c|q show-off but everyone else is just better off waiting or buying that cheap ASUS 780G board.. only half the cost..
    Jan 2005
    East Blue
    I am finally over 3.4 gig and sub 23s 1m Currently I try to pass 32m with it
    €dit and 32m!
    Xtreme Cruncher
    Apr 2008
    Ohio
    That's it time for a 9950 BE LOL.... I should have waited on my 9850, buying the first one on NewEgg gave me a less chance of seeing good OC., Although this SB750 board helped a lot. anyone want to buy a 9850BE???
    ~1~
    AMD Ryzen 9 3900X
    AMD Radeon VII
    ~2~
    Asus Prime X399-A
    AMD RX 5700 XT
    Dec 2002
    €dit and 32m!
    heres mine on air
    AMD 1090T@4.0ghz
    Enzotech sapphire/Mo-Ra extreme rad
    Asus Crosshair IV Formula
    ht 2400mhz / nb 2400mhz
    12gb Gskill 1300mhz
    HIS HD5970
    Enermax Evo Galaxy 1250
    case: XCLIO A380PLUS-BK
    4.61ghz water
    4.5ghz superpi 1M 15.585
    http://i271.photobucket.com/albums/j...rpi4500mhz.jpg
    25,396 06 Phenom 965@ 4.4ghz HIS 5970@960/1260
    21,893 Vantage, Phenom 965 4.2ghz HIS 5970 @960/1260
    Phenom 2 125w 965 test results
    http://futuremark.yougamers.com/foru...d.php?t=117414
    Phenom 2 140w 965 test results
    http://futuremark.yougamers.com/foru...d.php?t=109214
    Phenom 2 AM2+ 940 cold air results
    http://futuremark.yougamers.com/foru...ad.php?t=97430
    If I dont get every single drop out of my cpu I feel like someone is stealing from me
    I am Xtreme FlanK3r's Avatar
    May 2008
    Czech republic
    nice, try now on 3400MHz cinebench and wprime please...
    ROG Power PCs - Intel and AMD
    Jun 2008
    Dr Cypher I totally agree with you on the pricing.
    The GX from Foxconn is almost £100 cheaper!
  18. #18
    Nov 2006
    Poland / Rypin
    SoF, for destroyer is Aegis panel
    hmm, what about bigger mhzs?
    try to do 3500 and pi on this
  19. #19
    Nov 2007
    finaly cl4 tests again
    how much voltage do you need on ram for that?
    lower as expected then on k8?
    amd 940 @ 3.5ghz stock voltage or 3.7ghz 1,425v home made cpu block 3616 mhz and 2210mhz nb stable
    gigabyte ga-ma790fx-dq6
    sapphire hd4870 1gb @ 160-200 in idle , 750-950 load, with 2 rivatuner power profiles shortcuts.
    2x 2GB OCZ Blade 8500 ddr2 1066 @ 1.85 volt
    seagate barracuda 7200-11 1x500gb & 1x640gb (rip 1 500gb barracuda )
    seagate barracuda 7200-12 1TB , very nice hd, 5 degree colder then the 640gb
    windows xp 32
    lian li pc-a70b
    cooler master real power 850watt
  20. #20
    Jan 2005
    East Blue
    It is my new Mushkin 8500er Kit which I didn't tested a lot so far. 2.3V to be save but I think it could do with a bit lower volts.
    I am currently preparing HDD for Vista to make use of all 3 cards and run some 03 again.
  21. #21
    Nov 2006
    Poland / Rypin
    SoF, make the best 3d on amd please
  22. #22
    Jan 2005
    East Blue
    Now benching ~3.5gig with 3 cards under vista ^^ took me hours to mess around with hdd cleaning, partitioning, installing, driver issues etc...but finally it works quite OK
    too bad I can't use the 4th card yet - I am missing another 6Pin power cable ^^
  23. #23
    Xtreme Mentor
    Nov 2005
    Devon
    Very good OC SoF! Congratz!!
    Phenom at those frequencies will like some water or even cooler things .
    Also you can try to use AOD and push CPU VDDC a bit higher to help stabilize at higher frequencies. Good luck!
    BTW I'm interested in this board, what is your verdict from OC perspective?
    RiG1: Ryzen 7 1700 @4.0GHz 1.39V, Asus X370 Prime, G.Skill RipJaws 2x8GB 3200MHz CL14 Samsung B-die, TuL Vega 56 Stock, Samsung SS805 100GB SLC SDD (OS Drive) + 512GB Evo 850 SSD (2nd OS Drive) + 3TB Seagate + 1TB Seagate, BeQuiet PowerZone 1000W
    RiG2: HTPC AMD A10-7850K APU, 2x8GB Kingstone HyperX 2400C12, AsRock FM2A88M Extreme4+, 128GB SSD + 640GB Samsung 7200, LG Blu-ray Recorder, Thermaltake BACH, Hiper 4M880 880W PSU
    SmartPhone Samsung Galaxy S7 EDGE
    XBONE paired with 55'' Samsung LED 3D TV
  24. #24
    May 2008
    Czech republic
    man, try Cinebench and wprime, its better than superpi .
  25. #25
    Jan 2005
    East Blue
    wprime under vista it does 11.2s @3375MHZ (just gave it a quick try no pic yet) but a longer run isn't possible with current air cooling. I need another 6Pin urgently ^^
