Page 1 of 2 12 LastLast
Results 1 to 25 of 33
Thread: New Intel specs, better temp monitoring
    May 2008
    Previously undisclosed information about DTS or digital thermal sensor by Intel will be announced at IDF to provide for more accurate internal temperature monitoring of current 45nm CPUs.
    At IDF this year, Intel is expected to unveil (PDF) information that will lead to improved internal processor temperature http://www.tomshardware.com/news/IDF...ture,6154.htmlmonitoring. Intel has never previously disclosed information about the Tjunction value before of its 45nm desktop processors, a value that is needed to accurately measure the internal CPU temperature. Previously, these Tjunction values were estimated by software, but as each model and stepping of processor can potentially have a different Tjunction value, not to mention varying temperature response curves, no current method can be accurately trusted.
    Old news? Still good news
    -more-
    I know a little of everything, someone smack me when I think I know a lot
    Xtreme X.I.P.
    Jun 2002
    Tel Aviv, Israel
    Great news, and I like Anandtech's article better than Tom's. Tom's is inaccurate in several points.
    http://www.anandtech.com/weblog/showpost.aspx?i=478
    Member of Overclockers.com Folding @ Home team
    "<The_Coolest> you can't unwaste wasted CPU cycles" - Start FOLDing now!
    Main rig:
    AMD Ryzen 7 2700X / Mobo: Asrock Fatal1ty X470 / EVO 970 500GB + WD Blue 250GB + HDD / GPU: Dell RX 570 4GB / Mem: 2x16GB DDR4-3200 G.Skill 32GTZKW TridentZ - 32GB total / PSU: Seasonic Prime Ultra Gold 650W
    Secondary rigs:
    Core i7 2600K 3.4GHz @ 4.3GHz (Scythe Mugen2) / Mobo: Biostar TP67XE / 2x Inland Pro 120GB / GPU: HD5450 / Mem: 4x4GB DDR3-1600 G.Skill 8GBXL RipJawsX - 16GB total / PSU: Seasonic S12II 620W.
    Core i3 540 3.06GHz @ 4.0GHz (Freezer 7 Pro) / Mobo: MSI H55M-ED55 / GPU: Integrated / Mem: 4x2GB DDR3-1600 G.Skill 4GBRL RipJaws - 8GB total / PSU: Antec 380W.
    Core Temp - Accurate temperature monitor for Intel's Core/Core 2 and AMD64 processors
    HWiNFO Author
    Apr 2006
    /dev/null
    Finally
    But since DTS was never meant to be used for reporting of current temperature I'm wondering how will they manage the accuracy. The problem is that the sensor is most accurate only around the Tj,max (+/- 5 C accuracy) so it's suited for catching the hot point. At lower temperatures (normal usage) it's more inaccurate and the results may vary by +/- 15 C.
    May 2006
    NE Ohio
    Accurate temperature readings? Finally.
    new-old rig:
    E8600
    2x ASUS 4850
    DFI X48 board
    4 gb DDR2
    650w FSP PSU
    Working on some liquid cooling!
    old-old rig:
    Opteron 165 @ 2.610 (1.425v)
    - Prime Stable, Stock HSF
    DFI LanParty UT Expert
    2gb G. Skill Dual Channel Ram 2.5-3-3-6
    7900gt CO SuperClocked
    2x WD250gb SATA in RAID 0
    FSP Epsilon 600W
    heatware: thenrz
    Wanna look under my kilt?
    Jun 2005
    Glasgow-ish U.K.
    I hope they fix the range/interpretation so they dont coldbug through misinterpretation
    you sigged that?
    why?
    ______
    Apr 2006
    so.. this should have been disclosed why dont i read anything about it then
    Now i am become death , the destroyer of worlds.
    Xtreme X.I.P.
    Jun 2002
    Tel Aviv, Israel
    Dunno...
    Main rig:
    Secondary rigs:
    Jan 2006
    France
    The PDF is already available here : http://intel.wingateweb.com/US08/pub...TS001_100r.pdf
    Xtreme X.I.P.
    Jun 2002
    Tel Aviv, Israel
    Thanks!
    Main rig:
    Secondary rigs:
    I am Xtreme
    Jul 2007
    Austria
    nice, now we know the TJmax for the QX9650 (95°C), which means Realtemp was right.
    Xtreme X.I.P.
    Jun 2002
    Tel Aviv, Israel
    Never said it wasn't right, simply said that there is no real info from Intel to confirm this.
    His tests were mostly conducted on C2Ds which are 100C.
    Main rig:
    Secondary rigs:
    Feb 2006
    Potosi, Missouri
    Looking forward to the update of Core Temp.
    Xtreme Mentor
    Mar 2006
    Quote Originally Posted by The Coolest View Post
    Tom's is inaccurate in most of it's points for the past several years. Pathetic is a word that comes to mind.
    One hundred years from now It won't matter
    What kind of car I drove What kind of house I lived in
    How much money I had in the bank Nor what my cloths looked like.... But The world may be a little better Because, I was important In the life of a child.
    -- from "Within My Power" by Forest Witcraft
    Feb 2006
    Potosi, Missouri
    Freecableguy has updated the MBM5 plugin with the proper 45nm CPU Tjunction values.
    Motherboard Monitor 5 (MBM5) Core Temperature Plugin
    Xtreme X.I.P.
    Jun 2002
    Tel Aviv, Israel
    That was pretty quick, heh.
    It'll take me a day or two to get the time to do this for Core Temp.
    I really wish they would release info on 65nm chips and Atom CPUs as well.
    Main rig:
    Secondary rigs:
    Apr 2008
    Hopefully Coretemp or RealTemp will be updated soon.
    So did this let everyone know what the real Tjmax is and make a big difference between what we were using now?
    Aug 2004
    Manchester@UK
    Quote Originally Posted by AndrewL1950 View Post
    well, not much apart from that my temp just went up by 5C :S
    E3110@3.6Ghz || Gigabyte P45-DS3 || 2GB Cellshock 6400 || Asus HD4850||
  18. #18
    Aug 2005
    I would love to know the real Tjunction on my Q6600!
    .:: Gaming PC Specs ::.
    Case: Antec Nine Hundred
    CPU: Intel Core i7-2600K @ 4.6 GHz, 1.44v (cooled by Xigmatek GAIA) [IntelBurnTest{Linpack} stable]
    GPU/Monitor: VisionTek HD 6950 @ 6970, 950 MHz/1375 MHz 1.30v + Sony BRAVIA 32EX400 1080p
    Motherboard: GIGABYTE Z68XP-UD4 F5
    Memory: 16 GB (4x 4 GB) Corsair Vengeance LP DDR3 1600
    Hard Drive: 2x Seagate 500 GB 7200.11 RAID 0 & RAID 1 (Matrix RAID) + 1x WD Caviar Black 640 GB
    Sound: Creative SB X-Fi Fatal1ty Profess1onal, Logitech X-530
    PSU: Corsair AX-1200 (1500W PSU!)
    O/S: Microsoft® Windows 7 Ultimate SP1 X64
  19. #19
    Mar 2008
    Alberta Canada
    Interesting to see that the QX9770 has a TJmax of 85 degrees
    Current System:
    eVGA 680i SLi "A2" P30 BIOS
    intel Core 2 Quad Q6600 (currently at stock)
    OCZ ReaperX 4GB DDR2 1000 (running at DDR2 800 Speeds with cas4)
    320GB Seagate 7200.10
    XFX 8800GT XXX 512MB (stock clocks)
    auzentech X-Fi Prelude
    PC Power and Cooling Silencer 750 Quad Copper
    Win XP Pro
  20. #20
    Apr 2006
    E8000/e7000: 100°c
    Q900/q8000: 100°c
    Qx9650: 95°c
    Qx9770: 85°c
    http://www.hardwareluxx.de/story.php?id=8133
    Notice any grammar or spelling mistakes? Feel free to correct me! Thanks
  21. #21
    I am Xtreme
    Jul 2007
    Austria
    unclewebb (developr of realtemp) nailed it pretty good:
    Quote Originally Posted by unclewebb View Post
    You nailed it. This great announcement that was going to clear everything up has left a much bigger mess.
    Using the correct TjMax will make your TjMax temps more accurate but it doesn't do anything to fix the rest of the temperature range. This has only shown me that the amount of possible sensor error in the low end is even greater than I originally imagined. I was giving these sensors more credit than they deserved.
    MBM to release a quick update so that it is using the correct TjMax is pointless. If there is 20C of sensor error in the low end, and there is, then the correct TjMax doesn't mean squat except for the very rare times when you are at TjMax. Same thing for CoreTemp, Everest, SpeedFan etc. You can set the correct TjMax but if these programs don't give you a way to compensate for sensor error then the reported temps coming from them are not accurate.
    Time to fire up Excel to see if I can come up with a better way to convert random data into some usable temperature numbers.
    But even that simple statement isn't true. Intel's graph shows that the sensor error increases linearly with the distance from TjMax. In your example, the digital sensor reading would be 30 and that reading might already have 5 degrees of error in it. So the answer is 70C +/- 5C or somewhere between 65C and 75C. This announcement hasn't solved anything. My previous assumption was that the sensors are very accurate within 30C of TjMax but the Intel graph shows that sensor error starts at TjMax and continues linearly across the entire temperature range.
    temp readings are worthless below tjmax, cause of the increasing error.
  22. #22
    Feb 2008
    Quote Originally Posted by Hornet331 View Post
    After setting tjmax to 100 my core temps mirror my motherboard reported CPU temp to within 1c.
    E8400 Q15A @ 8.5x500=4250Mhz with 1.28 vcore -- TRUE 120 with Scythe Ultra Kaze in push pull
    ASUS P5Q Deluxe 1702 Bios -- PC Power & Cooling Silencer QUAD Crossfire 750w
    2x1GB Crucial Ballistix PC6400 (16FD5) & 2x1GB Crucial Ballistix PC8500 (16FD5) @ 1000mhz 4-4-4-12 PL9 @ 2.17v real with Corsair Dominator Active Cooling
    ATI HD4870x2 Cat 9.1 - Custom modded ASUS TOP Bios 832/1000
    2 x Samsung F1 1TB + 1 x Samsung F1 320GB -- X-Fi Xtreme Music -- Logitech G15 v2 + Razer Lachesis
    Dual Boot XP 32 SP2 + Vista 64 Ultimate SP1 -- Samsung T220 22" Monitor (Samsung Panel) + Samsung LEA656 40" 1080p TV
  23. #23
    Jun 2005
    Yeah , this is my dream to see a 45 nm accurate temp , my current C0 cpu's all show crap and none of them show sub + 10 c temp
    2600K working in 4.8 GHZ so far
    2600k @(4600 Ghz) 1.42v : (under water)
    Asus B2 mobo
    4 GiG DDR 2400 MHZ
    GTX 570 @ 1.063v ( 910/1820/2001 Mhz) .(under water).
    1020 W PSU
    Hobie's : Overclocking .... Overclocking .... Overclocking
  24. #24
    HWiNFO Author
    Apr 2006
    /dev/null
    And HWiNFO32 has been updated with new Tj,max values for Penryn and Nehalem families:
    http://www.hwinfo.com/news32.html
  25. #25
    Dec 2002
    Portugal...
    this would make my e8400 5ºc hotter than realtemp shows? crap.... that would be well beyond 80ºc full load in my case. Has to be wrong. My water temp is only 30ºc
    So to know the real temperature, I have to decrease my cpu mhz and vcore to the max and take a reading. The difference between my water temp and the c2d sensor readings is the value I have to subtract to the realtemp/coretemp (adjusted to tj100) ? correct?
