Results 1 to 24 of 24
Thread: A few words on E8600 Q820A599
    Champion
    Jan 2007
    Romania, lab501.ro
    Well....after a long, long wait I got my CPU from lolhalol (which I would personally like to thank once again for helping me out). After I received my little treasure I decided to take a few test with it before putting it under LN2 (anyway I've got no LN2 now and I have to go to Amsterdam, so that will have to wait for a few weeks) so I played a little bit with air, chilled water and a single stage....
    Air
    29 oC Room Temp
    Cooler Master Gemini II
    MSI P45 Platinum
    Crucial Ballistix PC8000
    SuperPI - 4000MHz - 1.14v
    Orthos - 4000MHz - 1.16v
    SuperPI - 4500MHz - 1.33v
    SuperPI - 5000MHz - 1.56v
    Chilled water
    Cooler Master Aquagate MAX + water + antifreeze + ice
    MSI P45 Platinum
    SuperPI 1M - 5200MHz - 1.7v / ~ -5oC
    Too much vcore here, but I just wanted to see how the CPU does with higher VCore...
    Single Stage
    Dimastech SS
    Asus Commando
    SuperPI 32M - 5200MHz - 1.6v / -40oC
    SuperPI 1M - 5500MHz - 1.6v
    Max Screen - 5760MHz - 1.78v / -35oC
    Unfortunately all my valid files >5500MHz are corrupt
    I am pretty pleased with the way this baby goes, and I can hardly wait to put it under the real cold....-100 should be a blast
    Weissbier - breakfast of champions
    May 2007
    Louisiana
    4ghz stable at 1.16... nice chip!
    E7200 @ 4.0ghz 1.29vcore
    2x 6870
    OCZ 4gb @ 5-4-4-12 846mhz
    Love will tear us apart
    Mar 2006
    wrigleyville.chi.il.us
    ^ Indeed. Looking forward to more too...
    On a side note, I wish I "had" to go to Amsterdam.
    Dark Star IV
    i5 3570K | Asrock Z77 Extreme4 | 8GB Samsung 30nm | GTX 670 FTW 4GB + XSPC Razer 680 | 128GB Samsung 830
    Apogee HD White | 140MM UT60/120MM UT45/120MM ST30 | XSPC D5 V2
    Champion
    Jan 2007
    Romania, lab501.ro
    Well...I have to..for the MSI OC Contest...they made me do it
    Xtreme XIP
    Jun 2007
    Puerto Rico
    Nice chip you got there Monstru , i like those results on low voltage. What batch and vid ?
    Champion
    Jan 2007
    Romania, lab501.ro
    Batch is written in title, Q820A599. Vid....1.23 on Commando...1.10 on MSI P45, with the same CoreTemp version ( 0.99.1)....weird
    Sep 2006
    Sydney /Australia
    You should put this in http://www.xtremesystems.org/forums/...d.php?t=197505 allready a highly active thread on the E8600
    GA-EX58-UD3R rev 1.6[/COLOR]
    6gb Patriot DDR3 @ 1333mhz
    166 QPI Core i7 920 @ 3.33ghz
    4 X 80gb Veloci Raptors in Raid 0
    Creative Xfi Fatal1ty
    2 Sapphire 4870s in Crossfire
    Dell 3007 WFP
    Cooler Master Real Power Pro 1000watt PSU
    Lian Li PC-A10B
    Air Cooled by Noctua
    Champion
    Jan 2007
    Romania, lab501.ro
    Unfortunately I saw that thread after I made this one. I posted a link there
    May 2007
    Athens - Hellas
    i cant say i`m very pleased with my Q822A...i expected ~100mhz more with that voltage...SS at -42C..this piece was very hot...25C difference from coretemp - evap temp..
    [SIGPIC][/SIGPIC]
    Champion
    Jan 2007
    Romania, lab501.ro
    It will do more with that voltage giorgos, but not with that temp
    May 2007
    Athens - Hellas
    yeah i know my friend....it was a bit dissapointing...
    [SIGPIC][/SIGPIC]
    Aug 2005
    Denmark
    I got same batch.
    OCTeamDenmark.Com
    Champion
    Jan 2007
    Romania, lab501.ro
    Nice one
    Memory Addict
    Aug 2002
    Brisbane, Australia
    nearly all Aussie stock is this batch even 3 weeks after they showed up in Australia!
    mine arrived yesterday
    5x E8600 are Q820A599 SLB9L 07/15/2008
    Champion
    Jan 2007
    Romania, lab501.ro
    Nice stock you have there
    Memory Addict
    Aug 2002
    Brisbane, Australia
    thanks
    1st of 5x E8600 Q820A599 installed on Gigabyte EP45 Extreme with new F6H bios. VID = 1.25v and seems to be around 0.032v vdroop on Vcore under load.
    who said E8600 were hot buggers ?
    System:
    • E8600 Q820A599 2V8 / **5146
    • CPU Cooling: Dtek Fuzion Rad Tower Box
    • Gigabyte GA-EP45 Extreme rev 1.0 F6h bios
    • 128MB Gainward FX5200 PCI
    • 2x1GB Crucial Ballistix PC2-8500 dual channel kit
    • Memory cooling: 120x25mm Thermaltake 81cfm fan
    • 74GB Western Digital Raptor OS drive
    • Pioneer 215 DVD-RW
    • 1200W Silverstone OP1200
    • WinXP Pro SP2 Nlite Fully Updated.
    Idle vs Load temps @4000Mhz 1.225v bios set vcore
    Is the first vcore I loaded windows in to test, so haven't tried any other vcore settings yet.
    Room ambient = ~20C
    Powermate Wattage Meter = 142-151 Watts under Prime95 load
    Champion
    Jan 2007
    Romania, lab501.ro
    Some more playing with SS, can't wait to get back from Amsterdam and hit this baby with LN2
    SuperPI 32M - 5400MHz - 1.62v
    Don't look at the score, no tweaks there, just testing the CPU
  18. #18
    Memory Addict
    Aug 2002
    Brisbane, Australia
    nice clocks there..
    3rd of 5x E8600 Q820A599 installed on Gigabyte EP45 Extreme with new F6H bios. VID = 1.25v is same as 1st E8600 Q820A599 **5146.
    System:
    • E8600 Q820A599 2V8 / **0537
    Finished quick tests for 3rd E8600 Q820A599 **0537 so far coolest running E8600 out of the 3 tested and highest cpuz validation and 1M pi
    Summary for quick tests at http://i4memory.com/95144-post31.html
  19. #19
    Memory Addict
    Aug 2002
    Brisbane, Australia
    Here's latest results tabulated - 4th cpu ain't as good compared to the others on H20.
  20. #20
    Jun 2008
    Earth
    Mine is Q820A670 -- very close # to Monstru's chip. VID is 1.2500V.
    I had it up to 4GHz so far. No big deal, but I am still using the crappy stock cooler until I can afford something better. It took 1.325V (in BIOS) to do this, although CPU-Z reported 1.288V, so somethig somewhere is slightly off.
    My Pi times @ 400x10 so far:
  21. #21
    Memory Addict
    Aug 2002
    Brisbane, Australia
    Just testing E8600 Q820A599 **0464
  22. #22
    Memory Addict
    Aug 2002
    Brisbane, Australia
    Different board test, I flashed to 8/29 bios before installing my E8600 Q820A599 so lucky not to have any issues with setting vcore - so much so managed 4980Mhz at 1.55v bios set with Corsair Nautilus 500 H20 cooling for 3dmark05 http://i4memory.com/showthread.php?t=9904 !
  23. #23
    Champion
    Jan 2007
    Romania, lab501.ro
    Finally some LN2 preliminary preparations
    6350MHz - SuperPI 1M - 1.84v / ~-120 oC
    Please do not look at the performance, I was just testing the CPU.
    I think it;s a promising one
  24. #24
    Xtremely unstable
    Aug 2004
    Between Hell and Nowhere
    Wow, very nice Monstru! That's some good ram kits too
    dx58so
    w3520@4100
    4x1gb corsair ddr3-1333
    gtx 295
    TR ultra-x, 2 scythe ultrakaze push/pull
    xclio stablepower 1000
    vista ultimate
    [SIGPIC][/SIGPIC]
    would you crunch if you thought it would save her life?
    maybe it will!
