Results 1 to 25 of 25
Thread: ATI HD4800 GPU/MEM clock performance scaling
    Xtreme X.I.P.
    Apr 2005
    GPU clocks 600-800 MHz
    Memory clocks 2000-4000 MHz
    8 games
    Plenty of graphs
    Source
    Google translator
    Jun 2007
    above USA...below USSR
    this makes overclocking a 4850 more worth while. BTW i like your :banana::banana::banana::banana::banana: cooper
    Case-Coolermaster Cosmos S
    MoBo- ASUS Crosshair IV
    Graphics Card-XFX R9 280X [out for RMA] using HD5870
    Hard Drive-Kingston 240Gig V300 master Seagate 160Gb slave Seagate 250Gb slave Seagate 500Gb slave Western Digital 500Gb
    CPU-AMD FX-8320 5Ghz
    RAM 8Gig Corshair c8
    Logitech 5.1 Z5500 BOOST22
    300Gb of MUSICA!!
    Steam ID: alphamonkeywoman
    http://www.techpowerup.com/gpuz/933ab/
    Xtreme X.I.P.
    Apr 2005
    BTW article also contains system's power consumption tests with different gpu/mem clock speeds combinations and performance comparison of heavily overclocked 4850 Vs 4870 on default clocks.
    Huge work done here. Kudos to author
    I am Xtreme
    Jul 2007
    Austria
    hmm so stock 4870 is still a good margin faster then a heavily oced 4850. Good to know.
    Jun 2006
    Excellent comparison. It looks like the extra bandwidth of the 4870 certainly helps, but obviously comes at a cost... let's see what happens to prices after the 4870x2 launches.
    Nov 2007
    Illinois
    Quote Originally Posted by Hornet331 View Post
    Surprisingly to see how starved for bandwidth both the RV670 and RV770 cores are.
    E7200 @ 3.4 ; 7870 GHz 2 GB
    Intel's atom is a terrible chip.
    Dec 2005
    Good work
    Interesting... Very bandwidth starved core. Once you add more bandwidth, the cards bottleneck is removed allowing the GPU to really fly. this causes an big increase in power consumption aswell.
    800/4000 = 174W
    800/2000 = 121W
    Jan 2008
    Is it just me or was there no mention of the extra $$ you will need to throw into your 4850 to get it to reach 800/2500. And most 4870's seem to be able to get to 830-50 stock volts/ with stock cooler.
    just my 2 cents.
    Asus Maximus "Rampage" Formula, 0219 bios
    Q6600@3.7ghz 462x8
    2x2G Patriot ddr-800@923 5-5-5-15
    TRUE-120 /w silverstone fm-122 pushin, antec tricool pullin
    antec 900
    Jun 2008
    Incredible how at even 600 2000 the rv770 is 5-20 frames botlenecked by memory compared to 600 3500. It seems that 3600 is the sweet spot to be, because further than that there is no significant gain overall
    Xtreme Mentor
    Mar 2006
    Evje, Norway
    Wow, im impressed. Why dont we see more test like this!
    I bet 4000 and more on memory is beneficial as soon as u start Vmod the card to get 900mhz+ on it.
    Quote Originally Posted by iddqd View Post
    Not to be outdone by rival ATi, nVidia's going to offer its own drivers on EA Download Manager.
    X2 555 @ B55 @ 4050 1.4v, NB @ 2700 1.35v Fuzion V1
    Gigabyte 890gpa-ud3h v2.1
    HD6950 2GB swiftech MCW60 @ 1000mhz, 1.168v 1515mhz memory
    Corsair Vengeance 2x4GB 1866 cas 9 @ 1800 8.9.8.27.41 1T 110ns 1.605v
    C300 64GB, 2X Seagate barracuda green LP 2TB, Essence STX, Zalman ZM750-HP
    DDC 3.2/petras, PA120.3 ek-res400, Stackers STC-01,
    Dell U2412m, G110, G9x, Razer Scarab
    Jun 2006
    However, one thing that I'm not sure has been considered is memory latency. I think they have only used a 4870 with GDDR5 memory. This probably has much higher latencies than GDDR3 at 2000 or whatever which could make the results worse than expected when running GDDR5 at 2000.
    Xtreme Mentor
    May 2008
    cleveland ohio
    Quote Originally Posted by lm358 View Post
    it's barely noticeable, still say the same about gddr4.
    looks like they need to get some samsung 6ghz gddr5 & maybe 2gbs of it on each card just for good measure.
    HAVE NO FEAR!
    "AMD fallen angel"
    Quote Originally Posted by Gamekiller View Post
    You didn't get the memo? 1 hour 'Fugger time' is equal to 12 hours of regular time.
    Xtreme Guru
    Jan 2005
    Tre, Suomi Finland
    I fail too see the point in comparing a HD4870 with underclocked memory to anything.
    HD4850 at a given freq is way faster than HD4870 at the same clock (eg. 800/2000).
    You were not supposed to see this.
    Jul 2007
    Quote Originally Posted by largon View Post
    Yup, seems that GDDR5 is about 20% slower than GDDR3 clock for clock.
    May 2006
    prospekt Veteranov, Saint-Petersburg, Russia
    it helps mostly in high-res
    Dec 2006
    Vegas ,NV
    "This map is the indisputable advantage over younger brother in the face of video DDR5 and has not yet disclosed upper potential nucleus, in the absence of specialized tools to break this accelerator. "- from end of article
    lol! this guy is serious!
    great review though, lot of effort and detail.
    Xtreme X.I.P.
    Apr 2005
    Quote Originally Posted by strange|ife View Post
    it's google translator. Original article is in Russian.
  18. #18
    Xtreme Mentor
    Nov 2006
    Spain, EU
    Latency. But we don't game at 500MHz GDDR5, do we?
    Friends shouldn't let friends use Windows 7 until Microsoft fixes Windows Explorer (link)
    Quote Originally Posted by PerryR, on John Fruehe (JF-AMD) View Post
    Pretty much. Plus, he's here voluntarily.
  19. #19
    Xtreme Guru
    Jul 2004
    Dude is that the guy from blood sport? this avatar made me piss my pants! wow! its a good one! sorry ot.
  20. #20
    Apr 2006
    City of Lights, The Netherlands
    Quote Originally Posted by STaRGaZeR View Post
    Can it even go that low on all boards? 2000 MHz. effective is a 1000 MHz. data clock...
    Although you were probably referring to the command clock, which is half of the data clock.
    "When in doubt, C-4!" -- Jamie Hyneman
    Silverstone TJ-09 Case | Seasonic X-750 PSU | Intel Core i5 750 CPU | ASUS P7P55D PRO Mobo | OCZ 4GB DDR3 RAM | ATI Radeon 5850 GPU | Intel X-25M 80GB SSD | WD 2TB HDD | Windows 7 x64 | NEC EA23WMi 23" Monitor |Auzentech X-Fi Forte Soundcard | Creative T3 2.1 Speakers | AudioTechnica AD900 Headphone |
  21. #21
    Xtreme Mentor
    Nov 2006
    Spain, EU
    Quote Originally Posted by Helmore View Post
    Yes. The value you can change in CCC, AMD GPU Clock Tool etc. is the command clock, so that's what the review is refering to.
  22. #22
    May 2008
    56°33"n.b 36°37"e.l.
    Quote Originally Posted by Cooper View Post
    and english version cooming soon, as soon as I'll get all the source.
    Now I've translated only first part, till pics.
  23. #23
    I am Xtreme
    Dec 2007
    just looking at the charts, its really helpful until they set the scale to show 90%+ instead of starting at 0%, its just annoying.
    seems the clock scaling is quite linear, and anything above 3000mhz on ram requires the core at 800 to notice much.
  24. #24
    Xtreme X.I.P.
    Nov 2002
    Shipai
    Quote Originally Posted by Monkeywoman View Post
    hmmmm quite tempted to add that to my signature
    very nice article! thanks artem!
  25. #25
    Apr 2006
    Quote Originally Posted by trans am View Post
    Bloodsport?! Is this comment a trap?
