Page 1 of 2 12 LastLast
Results 1 to 25 of 37
Thread: eXtreme Air Cooling
    Jun 2008
    eXtreme Air Cooling
    Been putting together my latest little project, full log can be found here: http://forums.overclockers.co.uk/sho...php?t=17888722
    But thought I would share a couple of vid's of my new babies with everyone
    Have recently got my hands on four Delta FFB1424UHE spec below:
    Am running a dedicated variable voltage PSU will be set at 27v in the end and two 12Amp 24v PWM units which will each control two the the fans in the end...
    Anyways they arrived today so took some quick video's (excuse the poor filiming! forgot the tri-pod in my rush to get home)...
    Anyways Video here of one fan and here with two connected up... enjoy
    Q6600 @ 4.023GHz 8Hours+ Primestable on AiR!
    Xtremely unstable
    Aug 2004
    Between Hell and Nowhere
    lol... 24v sounds like a jet taxiing Good clips, thanks.
    dx58so
    w3520@4100
    4x1gb corsair ddr3-1333
    gtx 295
    TR ultra-x, 2 scythe ultrakaze push/pull
    xclio stablepower 1000
    vista ultimate
    [SIGPIC][/SIGPIC]
    would you crunch if you thought it would save her life?
    maybe it will!
    Nerdy Powerlifter
    Jul 2007
    Down in the Bayou
    OMG WTF! Wow!
    Whenever my vacuume breaks, I can turn this on and act like I'm cleaning....
    You must [not] advance.
    Current Rig: i7 4790k @ stock (**** TIM!) , Zotac GTX 1080 WC'd 2214mhz core / 5528mhz Mem, Asus z-97 Deluxe
    Heatware
    Apr 2008
    I couldnt stand that noise, sure your getting killer cooling potential but your losing a few ear hairs as well.
    iRAQ - Apple's upcoming server racks
    May 2008
    Poland
    Damn, I'd probably need a new PSU
    E6550 2,33GHz @ 3,5 GHz || HD4850 714/1104 || 2x1GB OCZ PC-8500 @ 1000MHz
    Abit IP-35-e || Amacrox 450W PSU
    || Max. sig. size is 500x250 pix, isn't yours bigger?
    Cooled by: Apogee GT || MCW-60 || MCP655 || BW Extreme 123 rev. 2 || MCres
    Jun 2008
    Somewhere South, Great Britain.
    Quote Originally Posted by Pneumonic View Post
    Phew....right now can't find a UK supplier but IMO i'd prefer the one's I did find. As long as you can accomodate the 76.5mm depth they are only 120mmx120mm, can be run on 12v, are 1/3 quieter but I admit only shove 220CFM.
    A reviewer of these fans said holding one to your face is akin to sticking your head out the car window at 100mph complete with tears and flapping hair.
    Goodness knows what your ones would be like !!
    May 2004
    AB. Canada
    I had 4 Papst 24v fans with 280CFM @ 24 vdc
    I had them running at 8v and were quite quite.
    had them running in my rad box for a time
    link
    http://home.cogeco.ca/~hvanzyll/RadBox/
    "Great spirits have always encountered violent opposition from mediocre minds" - (Einstein)
    Jun 2008
    Quote Originally Posted by MadHacker View Post
    Yeah but at 8V you really stuffed the CFM.
    Anyone buying 24V is thinking about throughput - CFM and you bought four of them.
    But then you went and crippled them with 8v supply.
    IMHO I would of saved some bucks and bought smaller ( quieter.) fans in the first place.
    Jun 2008
    been waiting on the new ducting to arrive trying to use 80mm is just to loud! sounds like I have a wind tunnel next to me!
    So thought sod it and tonight have just got the cable ties out...
    Anyways some pictures for you guys
    Should give you an idea about how big these bad boys are thats 9600 OCZ with the full heatsink lark
    Whole thing is securly tied to a cross support had to be very careful installing the MB close to 2kg of fan and heatsink
    Xtreme Cruncher
    Jul 2007
    @ the computer
    how much cooling power are you actually getting? i would assume this follows that rule of diminishing returns
    [SIGPIC][/SIGPIC]
    Jun 2008
    to be fair I havent run them at anything above 8v yet... just got it setup is nearly 2am here and the g/f is sleeping... i value my balls and these things are louder than our vacum cleaner... at anything near 24v
    am not expert on heatsink design and that but I am not sure if its the CFM that will make the most different the pressure that these fans produce is unreal nearly 3 times that off the big 120mm model... even at 8v I can walk past the back of the setup some 8 - 10 feet away and feel the air comming out of the rear exaust.. am pretty certain given the fin density of the TRUE that the fact its pushing the air so much harder will make the most difference..
    Have some time tomorrow so I will ramp up the clock and fan speeds in the morning up to 4ghz and see what sort of temps i am getting on small fft load in prime
    Xtreme Cruncher
    Jul 2007
    @ the computer
    as long as it can move air all the way through the TRUE, i don't think air pressure matters. don't quote me on this though. and since the CFM and pressure is so high, i think you won't even see a difference in temps of your case or CPU. this overkill just adds more noise, but since this is XS, overkill is good . if you have some time, do you think you can test CPU temps with 1 vs 2 fans?
    [SIGPIC][/SIGPIC]
    Jun 2008
    I so wish I had some Where did u get it from? I haven't seen any for sale.
    Jun 2008
    I got them from Delta's UK distributor (Aerco) one of the only companies I could find that sell them in single units...
    In regards to the temps I ran a quick 1 hour prime @ just over 3.9ghz earlier today before I went out and was getting load temps that were around 14-16c cooler, adjusted for ambient and on the same settings as I have prime'd 8hours stable at on my previous setup.. (52/52/49/49 @ 24c ambient for those that are interested)... so assumming that the motherboard can hold up will run a couple of hours prime tomorrow @ 4.023ghz just to get an idea of how it compairs to my best run on the old setup and then will start to push durring the day tomorrow.. maybe tomorrow night I can get a nice low ambient run at 4.075/4.1 ish assumming i can get my P5K-E stable at that sort of FSB
    Jul 2007
    California
    Crazy fans... 80 Watts? and 650 Grams!!?!!?!?, that's basically as massive as my S1283.
    1.7%
    Nov 2004
    whats the point? you cant run it cooler than ambient, and after a certain cfm the extra airflow becomes inneffective
    unlesss you're reunning a quad on 1.45v or something
    Feb 2008
    Hope your planning on building one of these:
    EVGA X58 Classified
    Intel i7 965
    Corsair Dominator 1600mhz 3x2gb
    Nvidia GTX 295
  18. #18
    Jul 2007
    California
    These fans would be the most useful not with Air Cooling, but on a dense fin Rad.
    1.7%
  19. #19
    Jun 2008
    Thx, I'm going to try to find a distributor in Australia Hmm this could be hard...
  20. #20
    Jun 2008
    Quote Originally Posted by KoHaN69 View Post
    why am I doing it? why not.. no one else seems to have and want to see what can be done!
    I have 4.023ghz, 8 hours primestable on air and want to see what more i can get... this setup is giving me another 12/14c to play with over the old so should get some more.. if only my motherboard would man up for long enough
    As to the effectivness of the extra CFM well its had to tell if its the increase in CFM or static pressure but my temps at high vcore prime95 load (1.6v etc..) are a good 12-14c less than with the 120mm, 190CFM delta's I was using before
  21. #21
    Jun 2008
    I want to see what can be done, just don't have enough money
  22. #22
    Mar 2008
    Eagan, MN
    Make sure you securly mount your case to the floor. I wouldnt want to see it sliding across the floor! Looks very cool cant wait to see how it works.
    Intel QX9650 @ 4.275 GHZ W/C
    Striker II Extreme 790i
    Corsair Dominator TWIN3X2048-1800C7DF G
    2x EVGA 9800 GTX SLI
    Raid 0 2X Western Digital RaptorX 150's
    Mountain Mods UFO Case
    Corsair HX1000w PSU
  23. #23
    Nerdy Powerlifter
    Jul 2007
    Down in the Bayou
    How do these under volt? I have to ask.
    Heatware
  24. #24
    Aug 2007
    Kent, Washington
    I demand a video!
  25. #25
    Jun 2008
    Quote Originally Posted by Synthetickiller View Post
    they are ok actually will run @ 3v min although noise wise they are ok up to about 9v.. at 8v they are spinning at around 2000RPM which from the feel of them is the same sort of airflow my old 120mm delta's produced at max RPM (3600)..
    Quote Originally Posted by cabbspapp View Post
    I demand a video!
    are links in the first post
    hehe 1.45v ? mine doesnt feel like its had a hard days work unless its seen 1.5v+ :p
    cooling wise at 8v and my Q6600 @ 3.2 (with the fans at 8v) I am getting around a 5c temp difference between idle and 2 hours of prime95 small ffts load..
    with the fans @ full and the CPU @ 3.8ish (1.464 load vcore) I am getting around a 23c difference between idle and full prime95 small ffts load..
    Am actually very please with the mounting of the heatsink as well getting 1c difference across my cores which is always nice!
    So far havent gone much higher got myself a P5Q deluxe and am still playing with the BIOS trying to get 8 hours stable @ 3.950ghz to give a solid platform to push past the 4.023ghz I had on the old setup..
