After the Aquamark run to 6ghz under cascade i tested max cpuz screen and super pi 1M with this awesome E8600
http://www.xtremesystems.org/forums/...0&postcount=24
CPUZ 6205mhz
http://valid.x86-secret.com/show_oc.php?id=394808
Maybe DDR2 limited ^^ i was @ 2.47v for 4-4-4- ...
Super PI 1M 7.59s
Configuration
Intel Core 2 Duo E8600 es (E0)
2*1go Crucial ballistix tracer PC8500 @ 2.5v
VGA 1 X Jetway HD 4870 (880mhz GPU / 1150mhz GDDR5)
PSU Gigabyte Odin 1200w
Biostar Tpower I45 (Bios 0710)
Cascade à -103°
BIOS SETUP
__O.N.E__
Over-Clocking Navigator (Manual OverClock)
Intel(R) SpeedStep(tm) : Disabled
Ratio CMOS Setting : ×9
CPU Frequency Setting : 600
Over Clock Retry Count : 1
FSB Finetune : Enable
FSB(Bsel) To NorthBridge Latch : 1333
DRAM Frequency : DDR2-1200
DDR2 Enhance Mode : Auto
__DRAM Timing Configuration__
DDR2 RCOMP Configuration : 4
Static tREAD Value : PL9
Configure DRAM Timing by SPD : Disabled (4-4-4-12)
__Clock Gen Configuration__
PCIE Frequency Setting : 100
CPU Clock Skew Control : 200ps
(G)MCH Clock Skew Control : Auto
CPU Clock Driving Control : Auto
__Voltage Configuration__
CPU Voltage : +0.65v
DDR Voltage : +0.60v
Chipset Voltage : +0.400v
FSB Voltage : +0.35v (+0,400v linked by Chipset voltage)
CPU Core1 GTL Ref Voltage : 0.63*VTT
CPU Core2 GTL Ref Voltage : 0.67*VTT
MCH GTL Ref Voltage : Auto
CPU PLL Voltage : 1.5v
I am really tempted to get one as well but hot summer days here are just not the time for me to put hands on hardware
, nice chip!
