After some tests on aircooling. I'm very impressive by this mobo. Ive just tested the F2.
Picture of setup
- E8400 Q750A
- OCZ Vendicator
- GSkill Pc10666on dual mode ,single is the same thing.
- Hiper 580R
- Sunon 150CFM on the memory and NB
For beginning " full aircooling " ,after with the NB is watercooled by the Gigabyte system and 15L of water .
I use Set FSB and i obtain 656 MHz on dual with 2 coresCode:Settings - CPU Clock Ratio : 6X - CPU Host Frequency : 600 ( 635 max for windows ) - PCI Express : 100 - CPU Clock Drive : 1000mv - PCI Express Clock Drive : 700mv - CPU Clock Skew : 150ps - MCH Clock Skew : 50ps - Performance Enhance : Turbo - MCH Frequency Latch : 400 MHz - Sys Memory : 2.00D - Timings : 9-9-9-25 - Sub Timings : Command rate on 2T but it's 1T on Cpu-z and Memset others on auto ,i've no more time for trying I check with multimeter tomorrow. - Vcore : 1.29375V in Bios = 1.26V on Cpu-z. And you can look for Spi and Pifast on the screenshot :D - CPU Termination : Auto - CPU PLL : 1.50V - MCH Core :1.42V on air and 1.54V with water. 35°C in bios . - Vdimm 1.80V - Auto for others
I put water on NB : 661Mhz
I try with one core and NB watercooled : 665Mhz
The 666MHz was not validated .
I' m very happy to see that.
I run some spi and pifast. Don't watch the score ,because it's not the good OS and bad memory .
Spi 1M @650Mhz
Pifast 10M @635Mhz
I think 3D is around Pifast .
This is a good partNext with better memory and cooling.
Thx to Christophe of Gigabyte France.![]()
