XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme > Xtreme Overclocking
Reply
Old 07-20-2008, 11:25 AM   #1
Fr3ak
OC Jedi
Fr3ak's Avatar
Send a message via ICQ to Fr3ak Send a message via MSN to Fr3ak
Talking A Fr3ak having fun with Biostar's Tpower I45 (xtreme pics inside)
As stated in this thread ([Fr3ak] Biostar Tpower I45), I had trouble with the Biostar Tpower I45 to get past 600 MHz FSB. I couldn't even boot at 600 MHz into Windows. I tried 4 different E8500, one of them with my single stage, but the result was always the same. Crash between 550 and 595 MHz. I posted pictures of the BIOS and the max. selectable voltages in the thread mentioned above btw.
First, lets have a look at the board first what it looks like when it comes out of the box:
More pictures of the board can be found here:
http://extreme.pcgameshardware.de/at...wer-i45-01.jpg
For the weekend, we had a "little" bench session in Germany called AOCT which stands for AwardFabrik Overclocking Treffen (Meeting). We were between 20 and 30 people doing weird things and benching all over the place.
I didn't have any time for preparations, so I decided to try to break my current personal percentage OC value, which I set last year with a E2140 at a 151.51% OC. To reach that goal, I bough 3 E1200 from 3 different shops. What can I say: One CPU was worse than the other. Couldn't even get 2 CPUs running at the 456 MHz my E2140 runs on plain aircooling.
Ok, so what can I do to spend the rest of te 24 hours? First of all, I desiced to give the E2140 a try again, because I reached the previous (personal) record on P35 without a temp probe. That E2140 kept me busy for about 5 hours. After some time, I got the idea to "insulate" the NB with Armaflex and use dry ice on the stock NB, just for the fun of it. To my surprise, the FSB wall of my CPU increased and I was able to gain another 1.5%. Wow, what an archievment for 5 hours of benching, but it has been fun:
http://valid.x86-secret.com/show_oc.php?id=391707
Here is a picture of my ghetto NB cooling with dry ice:
For whatever reason, the CPU doesn't seem to scale with voltage and temperature din't even imporess it too. I was surprised seeing 516 MHz FSB with a multiplier of 6. I ran the E2140 with 2V which moved the coldbug to -145C, which was nice, but as I said, it was of no use.
After using dry ice:
Right, after benching with the E2140, I still had plenty of time and mainly LN2 left, so I decided to see what FSB I can reach with a E8500. I knew the CPU runs at 575 MHz on air with a X38, so there was hope to get at least past 600 MHz FSB. After the good results with the dry ice and one of the guys copying my method to bench with his Tpower with dry ice too, I decided to do some improvements to my previous idea: I did a better job at insulation everything from the start. The NB was pretty much completely sealed. I then made a funnel for the NB. Being known for stupid things, I now wanted to cool the NB with liquid nitrogen, using the stock NB cooler.
Now the fun could continue:
600 MHz FSB was kind of a piece of cake. It took me some time to try all kind of different values, but running the NB at -186.6C (according to the bad blue K-type probes) and +0.7V VNB / +0,65V VFSB made it all the way up to 673 MHz FSB. I could have probably gotten a little higher than that with more finetuning. I didn't touch DRAM timings at all, which might have been a stupid thing since I had it set to semi decent bench settings.
http://valid.x86-secret.com/show_oc.php?id=391714
http://valid.x86-secret.com/show_oc.php?id=391705
Whatever, I had a lot of fun, everybody thought I am totally nuts, so mission accomplished! The low NB temperature had some side effects, that went even worse as soon as the CPU started coldbugging. If you want to know what on a mainboard is connected to the northbridge, just freeze the NB with LN2 and you will find out! Everything that starts forming ice in seconds has traces to the NB
Enough of the talking: Here are the pictures:
Surprisingly, everything was still working fine - more or less. =)
Finally, I was able to make a longer post in this section again, time is killing me, I would still be busy haveing 48 hours days =/
The NB after the LN2 madness:
__________________
オタク
"Perfection is a state you should always try to attain, yet one you can never reach." - me =)
Fr3ak is offline   Reply With Quote
Old 07-20-2008, 11:39 AM   #2
systemviper
Phazers on Stun
systemviper's Avatar
Send a message via Yahoo to systemviper
WOW you are wak, that is some krazy benching, gotta love it
__________________
HEAT
systemviper is offline   Reply With Quote
Old 07-20-2008, 11:42 AM   #3
nachthymnen
Master of nebulah frost
nachthymnen's Avatar
haha, you're crazy my friend
I love the pics and also the results!!
Really nice start with tihs awesome board!!!
I don't see any USB key insert...why?
nachthymnen is offline   Reply With Quote
Old 07-20-2008, 12:05 PM   #4
redratamd
redratamd's Avatar
Send a message via MSN to redratamd
Pics are crazy like the guy
__________________
Pc-OverWare.be
Hwbot profil
redratamd is offline   Reply With Quote
Old 07-20-2008, 12:16 PM   #5
andre X_X
Team.ID
andre X_X's Avatar
Send a message via Yahoo to andre X_X
that is xtreme bench there
i really love the pics
__________________
E8600 Q820A750
DFI LanParty UT P35-T2R - Abit IX38 QuadGT - Asus P5B Deluxe - Biostar TP45 HP
Team Xtreem PC-5300 C3 2GB - Crucial 10th Anniversary 2GB - Team Xtreem PC8500 C5 2GB
Winfast 8600GT
Silverstone Olympia 1000w
andre X_X -72c CO2 Cascade
My R22/CO2 Cascade Project
andre X_X is offline   Reply With Quote
Old 07-20-2008, 12:38 PM   #6
Marvin_The_Martian
Banned
Love the frost pics, very much so
Want more benches to
Marvin_The_Martian is offline   Reply With Quote
Old 07-20-2008, 12:41 PM   #7
boblemagnifique
Xtreme X.I.P.
boblemagnifique's Avatar
Send a message via ICQ to boblemagnifique Send a message via AIM to boblemagnifique
It's crazy cooling Freak , congratz for your Overclocking !!!
Biostar is impressive with the little P45 !!! i like that
__________________
OCM Member / IXTREMTEK Admin !!
DDR1 2*256 BH5 Adata @324.7Mhz 1.5/2/2/5 1T at 4v @318.6Mhz Benchs
DDR2 1*512 Kingston Pc8500 @702Mhz 5/5/5/18 at 2.42v réel
DDR2 2*1024 Cell Shock Pc8000c4 @534Mhz 3/3/3/8 at 3.5v réel
Cooling : XP90C , Big Typhoon , waterchiller R507 , LN2 ....
boblemagnifique is offline   Reply With Quote
Old 07-20-2008, 01:15 PM   #8
scooter.jay
scooter.jay's Avatar
Crazy but good some nice clocks and some new ideas thanks.
__________________
scooter.jay is offline   Reply With Quote
Old 07-20-2008, 06:08 PM   #9
ZoLKoRn
Xtreme X.I.P.
ZoLKoRn's Avatar
Send a message via MSN to ZoLKoRn
Nice pics nice result Fr3ak
I really love Ice on G.SKILL picture, that 8500HK right ?
You're rock
__________________
Sorry For My English
OverclockZone Team
THAILAND
Originally Posted by hipro5 View Post
Actually there is NO NEED for 164 phases that companies put in nowadays mobos....
FOUR (4) are enough with nowadays materials and maybe SIX (6) with the upcoming Gulftowns....
The 1024 phases is a "marketing trick" nowadays....
You will buy MY mobo because I put 2048 phases in my motherboard....
ZoLKoRn is offline   Reply With Quote
Old 07-20-2008, 06:34 PM   #10
alexio
The Blue Dolphin
alexio's Avatar
Awesome fr3ak An epic OC session indeed!
__________________
Blue Dolphin Reviews & Guides
Blue Reviews:
Gigabyte G-Power PRO CPU cooler
Vantec Nexstar 3.5" external HDD enclosure
Gigabyte Poseidon 310 case
Blue Guides:
Fixing a GFX BIOS checksum yourself
98% of the internet population has a Myspace. If you're part of the 2% that isn't an emo bastard, copy and paste this into your sig.
alexio is offline   Reply With Quote
Old 07-20-2008, 11:15 PM   #11
saaya
Xtreme X.I.P.
saaya's Avatar
Send a message via MSN to saaya Send a message via Yahoo to saaya
lol, nice, so you just poured the ln2 onto the nb? didnt it run over the pcb?
i wonder if we are going to see FSB 775 on socket 775 before it dies out
__________________
Nvidia: Tesla C2050 and C2070 products (GT300) will retail for $2,499 and $3,999
JHH (Nvidia) sep 2009: The best way to always be the number1 is to have no backup plan link
Hail Voltage! The Solution to AND Source of all our Hardware Problems
saaya is offline   Reply With Quote
Old 07-20-2008, 11:39 PM   #12
Fr3ak
OC Jedi
Fr3ak's Avatar
Thanks =)
I disabled USB and I didn't want to risk the data on my USB stick =)
haha, lol, thanks!
Thank you!
I should have run 1M, as the CPU wasn't as bad as I though initially. Even though the board ain't good for 1M. I am planning to do some more benching as soon as a certain new CPU is out
Yep, I like it too. Worked like a charm, even while half of the board was frozen. All BIOS settings I tried, worked too. I had way more trouble with other P45 boards on air =)
Thanks!
You're rock
Thanks mate! I like those frozen memory pictures too. The colors seem just right. I have them in full resolution, so I am gonna make some wallpapers out of them I guess =)
It has been fun, but at some point it was just plain stupid hehe
That is why I insulated the NB completely, so it was kind of good sealed. I only poured bit by bit and not half the thermo on the NB =) The LN2 was trapped in between the fins of the NB cooler. I benched for 4-5 hours using that method, so it can't be that bad of an idea.
__________________
オタク
Old 07-20-2008, 11:56 PM   #13
[XC] gomeler
Diablo 3! Who's Excited?
[XC] gomeler's Avatar
Send a message via AIM to [XC] gomeler
I'm surprised the NB was stable that cold, my X48 would bug out with dry ice + acetone, had to use just dry ice pellets. I'll have to give that a shot with some P45 boards. Nice numbers there
__________________
Team PURE is about kickass pirates and unicorns defeating ninjas.
[XC] gomeler is offline   Reply With Quote
Old 07-21-2008, 12:41 AM   #14
G H Z
Champion
G H Z's Avatar
Hardcore Oliver
I'm with Zolkorn, the frozen GSkill pic rocks! Nice bench session
G H Z is offline   Reply With Quote
Old 07-21-2008, 01:18 AM   #15
marmott
I like this ghetto NB cooling !!
great scores congrats !!
__________________
marmott is offline   Reply With Quote
Old 07-21-2008, 02:10 AM   #16
overcrash
overcrash's Avatar
Send a message via ICQ to overcrash Send a message via Skype™ to overcrash
You are CRAZY m8, is that board still alive
__________________
24/7 Gigabyte EP45-UD3R|E8400 @ 4302 Mhz @1.344v|Corsair 2 x 1GB DHX @ 940 Mhz 2.06v|PNY 9800GX2 700/1750/1100|Cooler Master 690 + 3 x 140mm + 2 x 120mm|TRUE + 2 x 120mm|Chieftec 750-14C 750W
AMD makes it first, Intel makes it better
overcrash is offline   Reply With Quote
Old 07-21-2008, 02:14 AM   #17
Solarfall
Xtreme Guru
Solarfall's Avatar
Send a message via AIM to Solarfall Send a message via MSN to Solarfall
whhhhhhhhaaaaaaaaaaaaaattt awesome pics + crazy results Fr3ak..
__________________
Evga X58 sli under cascade
http://www.xtremesystems.org/forums/...d.php?t=219788
Evga X58 Sli ultimate overclocking/ overview/ discussion thread
http://www.xtremesystems.org/forums/...d.php?t=221082
proud owner of E8600 Q822A435
Solarfall is online now   Reply With Quote
Old 07-21-2008, 02:21 AM   #18
InsaneOne
InsaneOne's Avatar
is that motherboard still alive? memorys?
__________________
1. computer: Maximus formula se, E8400, HD4870 Crossfire, 4gb axeram, 2x DVD-RW, 4Tb, Corsair 1000w, vista
2. computer: DV6699EO = T5250, 8400M, 2gb, 160gb, vista
3. computer: F-S Amilo K7600, XP
4. computer: Atom 330, Intel GMA 950, 2gb 667mhz, 500gb, dvd-rw, XP
InsaneOne is offline   Reply With Quote
Old 07-21-2008, 05:16 PM   #19
Fr3ak
OC Jedi
Fr3ak's Avatar
Yes, everything is still working just fine. I was benching like this for 3 hours, then I had to heat up the board to make a better insulation. After that I was benching for another 2 hours. Board, CPU and memory haven't been damaged at all. Very little corrosion marks on the memory, but that's about it =)
__________________
オタク
Old 07-21-2008, 08:41 PM   #20
saaya
Xtreme X.I.P.
saaya's Avatar
i did almost the same thing with a vga heatsink at the oc session close to alternate above frankfurt with blackpearl and sof and other awardfabrik guys... but it kept leaking unfortunately...
so did you use armaflex or what did you use?
__________________
Old 07-22-2008, 12:47 AM   #21
Fr3ak
OC Jedi
Fr3ak's Avatar
Tissues + Armaflex. Have a look at this picture:
__________________
オタク
Old 07-22-2008, 01:15 PM   #22
hiwa
Disposable Heroes
hiwa's Avatar
very nice my friend can't found it in germany need one
hiwa is offline   Reply With Quote
Old 07-22-2008, 01:28 PM   #23
Oliver
keep pushing it
Sweet work Oliver and i love the pics of the ln2 affected G.skill stick...
Keep pushing it...
Oliver is offline   Reply With Quote
Old 07-22-2008, 01:34 PM   #24
3lfk1ng
3lfk1ng's Avatar
Sick. Looks like you had a lot of fun.
__________________
e3110 @ 4.25 GHz Q746A545 | Asus x48 Rampage Formula | 8GB G.Skill F2-8500CL5D | Sapphire 4870 512mb| OCZ GameXstream 850W | Thermalright Ultra-120 Extreme |
Auzen X-FI Prelude | Custom Thermaltake Kandalf | Crystalfontz-635 | Gateway FPD2485W 24" | Klipsch Promedia 2.1 | G7 | G15 | Black Icemat | Dual Boot XP Pro & Ultimate x64
3lfk1ng is offline   Reply With Quote
Old 07-22-2008, 01:43 PM   #25
blind_ripper
blind_ripper's Avatar
Send a message via MSN to blind_ripper
great work freak loving it
__________________
blind_ripper is offline   Reply With Quote
Reply
Tags
benching, biostar tpower i45, cpu-z, fr3ak, ln2
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
XtremeSystems
