07-08-2008, 01:15 PM
#1
Biostar TPower I45 Vmods
Can some one post pics for vdrop for this MB.
Thanks in advance!
__________________
07-30-2008, 09:44 AM
#2
I'll go ahead and second that request, I can take pictures if needed.
07-31-2008, 03:46 AM
#3
IT Engineer in the making
Then what are you waiting for?
__________________
08-05-2008, 02:50 AM
#4
My board has arrived - vdroop is covered, vcore soon. Will try and get pics up later today.
ISL6334 PWM controller
Vdroop - between pins 14 and 15 I measured it to be around 18.8Kohm so I'd recommend starting with a 100Kohm variable resistor.
Vcore - you could go down the usual variable resistor between FB pin and ground but this controller does have other voltage offset capabilities. I have found that the OFS pin has been tied to ground via a resistor. If this resistor was replaced with a variable resistor and the resistance increased you can increase the output voltage. Decreasing Rref did not seen to affect output voltage.
Stay tuned
John
08-05-2008, 03:56 AM
#5
OC Jedi
The Vcore-mod is not really necessary tbh. I run up to 2.04V on the board and it can do higher than that. Vcore might be interesting if you want to fine tune the voltage, because the 0.05V steps in the BIOS are kind of huge.
__________________
オタク
"Perfection is a state you should always try to attain, yet one you can never reach." - me =)
08-05-2008, 04:21 AM
#6
I see there is an OVP mod out too with also boosts vcore - kills two birds with the one stone
08-05-2008, 10:12 AM
#7
Checkbox failure ..
do you have a link?
08-07-2008, 02:28 AM
#8
I45 OVP Mod by Hey - looks to be adjusting the VID voltages manually. Pay attention to what he says, don't short the wires
I45 Vdroop mod by me - work in progress as I still haven't found the time to do the mod. My measurements were off as the traces are so small actual resistance is more like 2.2Kohm so a 20Kohm variable resistor will suffice.
08-09-2008, 06:48 PM
#9
will this vdroop mod work for the tp45hp board to? at idle my vcore is at 1.456 and loaded it goes down to 1.42x vcore. i would like to have stable vcore so i dont have to have it so high to be stable. ill keep lookin to see if its the same.
08-11-2008, 08:20 AM
#10
Has someone measured with DMM, how big are drop and vdroop?
__________________
Vmods - what can possibly go wrong? ©
08-25-2008, 11:21 AM
#11
ANy idea how to do the mod , i really need it , sorry for bumping old thread
__________________
E8500 @(5.000  Ghz) 1.55v  24/7 (Vapo LS)
Asus P5b-e Plus (dead ) , Biostar Tpower i45 (dead) ,Asus P5Q pro
2 GIG Geil PC 6400 @ 2.1-2.3v
2 GiG OCZ Reaper 9200
4 x HDD 320 GB raid 0 .(2 Disk Dead waiting for RMA  )
HD4870 @ 1.45v ( 900/4400 Mhz) .(under water)  .
1020 W PSU
Hobie's : Overclocking .... Overclocking .... Overclocking
08-25-2008, 11:32 AM
#12
makaka, which? Here is Vdroop posted allready and should work. Just measure the resistance to be sure.
__________________
08-27-2008, 01:17 PM
#13
Thanks for reply , were this chip is located i was looking and looking and have not found it
Have it to place a resistor between the chip pin or between the two points
__________________
1020 W PSU
08-28-2008, 06:34 PM
#14
How does actually these VIDs work? Is it really OK to ground them without any resistor?
http://ceemic.pri.ee/hardware/tpower/tpower20.JPG
http://ceemic.pri.ee/hardware/tpower/tpower21.JPG
What would be Your first choice for Vcore mod? "Regular" FB->VR->GND or this OFS moding?
For Vdroop I also measured 2,19kohm resistance. I'll do the mod as soon as I have measured the real voltages and drops with DMM...
Other pics if someone interested: http://ceemic.pri.ee/hardware/tpower/
__________________
08-29-2008, 07:44 AM
#15
i am very interested in the vdroop can some explain who to do it clearly . between witch pins should i place the resistor and how much ohms ??
__________________
1020 W PSU
08-29-2008, 08:41 AM
#16
I measured real Vcore with DMM and here are results:
As You can see, Vdroop rises badly in higher Vcore. So when You want to squeeze max MHz in sub-zero cooling, Vdroop mod is a must
And as someone mentioned here before, Vcore mod is also recommended for fine tuning.
__________________
09-02-2008, 12:54 AM
#18
glad to hear it worked out Ceemic
09-02-2008, 01:19 AM
#19
Xtreme X.I.P
__________________
***** Visit us on PCWorld.fr *****
09-02-2008, 03:21 AM
#20
Johnny Bravo, tnx
Pt1t, do You have other mods for TPower also?
__________________
09-08-2008, 03:59 PM
#21
would this be the same as the tp45hp tforce board? i really need it mine droops from 1.456 idle to 1.40 to 1.41 under load.
09-08-2008, 05:08 PM
#22
Originally Posted by Pt1t
Thanks men this what i need exactly , a pencil mod , how much 400 ohm will help in the vdroop ?
__________________
1020 W PSU
09-13-2008, 07:48 AM
#23
Banned
where are the vcore measure points? anyone know? and is there a vcore mod that is working?
09-13-2008, 08:08 AM
#24
Banned
ok Pencil mod 3 posts up works. I could not get it to measure 500 ohms but measure 1.687kohms but I penciled it to 1.5kohms and now no more vdroop it stays right on exact set voltage in bios or overvolts a tad
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
