Results 1 to 25 of 30
Thread: WIP : My Custom Chenbro! Mountain Mods, come get some.
Threaded View
    Dec 2007
    Vancouver
    Ok, so I managed to snag an old Chenbro case that was lying around at my workplace....I saw it had some significant potential...
    Here is the plan :
    Cut holes for 2 x MCR320 and 1 x MCR220 - DONE!
    Clean it all up, paint Hammered finish Black - Primed!
    Assemble with all my parts...
    -Parts in my Sig. Adding silverstone 3.5" USB/firewire/audio drive
    -Waiting on my 6xZalman 120mm fans, Feser UV Green 1/2 tubing, as well as some Green UV cable sleeving kits, and some UV cathodes.
    The plan is to get it all build and sized up...then measure out what I need:
    I am going to be getting custom acrylic panels made up for the Top, Front, and sides. I want a solid or Thick translucent Black for the top and front. The sides will be clear. Basically will have holes cut for fan vents, as well as for the Optical drive and USB/firewire/audio and fan controller.
Name:	New case 003_resize_resize.JPG
ID:	81615   Click image for larger version.
Name:	Primer 004_resize_resize.JPG
ID:	81616   Click image for larger version.
Name:	Primer 005_resize_resize.JPG
ID:	81617   Click image for larger version.
Name:	Primer 006_resize_resize.JPG
ID:	81618   Click image for larger version.
Name:	Primer 007_resize_resize.JPG
    Kick it oldschool
    The Vortex H20 V2.0
    Coolermaster ATCS 840 w Window panel
    EVGA SR-2 Classified
    2 x Xeon L5639 Hexcore CPUs, 3.2GHZ
    EVGA GTX 580
    24GB Mushkin Blackline DDR3 1600MHZ 9-9-9-24 1.5v
    OCZ Z-Series GOLD 850W
    2 x 90GB Corsair Force SSD RAID0
    Sharp 32" Aquos 1080p
    Benq W500 1080i Pojector.
    Watercooling:
    2 x EK Supreme HF, MCR320+Gelid Silent 12 Push/Pull, DD Pump, EK Multioption 100ml Res, XSPC GTX 580 FC block, EK Coolstream XT 220 RAD Gelid Wings Push - CM R4s Pull.
