Page 1 of 2 12 LastLast
Results 1 to 25 of 32
Thread: 4870 bios mod
    Jan 2008
    4870 bios mod
    I need a few questions answered before i carry out this mod.
    Iam using RBE v1.11 and winflash and usb stick. I have saved my bios file using gpu-z and its 128kb meaning i souldnt get the file corruption problem right?
    Heres a screen from RBE v1.11. What clock info section do i edit? what is max volts on stock cooler at 100% thanks for the help
    Jan 2008
    anyone?
    Xtreme 3D Team Member
    Jun 2006
    small town in Indiana
    Quote Originally Posted by dean0 View Post
    anyone?
    3,6,9. if that doesn't get the switch right also use 2,5,8 they are the med. 3-d clocks.
    QX 9650 5ghz with 1.55v 4.8ghz with 1.5v 24/7 in a VAPOLI V-2000B+ Single stage phase cooling.
    DFI LP LT X-38 T2R
    2X HD4850's water cooled , volt modded
    Thermaltake 1KW Psu
    4x Seagate 250GB in RAID 0
    8GB crucial ballistix ram
    Jan 2008
    thanks as alway jimmy, iam using winflash i have downloaded it but when i click to load it nothing happens? am i doing something wrong?
    also is the voltage for the core or memory? would it be best just to set all the clock info's to make sure?
    Jun 2006
    no, yes and yes, Vista is the culprit, I had a hell of a time getting it to start in vista. do you have an xp install(dual boot)? or another HDD with xp. or you can do the dos flash with the other flash tools. look on Techpowerup for the dos apps.
    not having a 4870 means I can only guess but I would use 9, 6 and 3 at first if it doesn't change during a fullscreen app. then mod a fresh bios to include 2&3, 5&6 and 8&9 with the desired clocks. always use a fresh copy of your original bios to perform mods with RBE.
    DFI LP LT X-38 T2R
    Thermaltake 1KW Psu
    Jan 2008
    Ive completed the flash in DOS mode succesfully.
    bios voltage; 1.3v
    Read using MM; idle; 1.273v load; 1.282v
    What is the highest voltage from bios?
    Currently core; 820 Memory; 1080 100%stable
    small problem that in 2d mode i get flickering sometimes anyone know why?
    Jun 2006
    That is about the max from bios any more still just gives the same voltage. I think the flickering is clock speed changes, I have heard several people mention it. never had it myself.
    DFI LP LT X-38 T2R
    Thermaltake 1KW Psu
    Jul 2008
    hello there my first post jimmyz i was wondering about what meant what in rbe thanks for clearing that up,but i have a question concerning clock info 0 in rbe as on the 4870 its set to 750mhz and 900 does this one also have to be changed to match your new clock or is it left alone on the current setting
    Jun 2006
    Quote Originally Posted by PoeDooM View Post
    0 is boot, just leave it as is.
    DFI LP LT X-38 T2R
    Thermaltake 1KW Psu
    Jul 2008
    thanks man having a play with it now
    Xtreme Cruncher
    Oct 2007
    It's caused by the memory clocks changing frequency.
    Aug 2004
    The Netherlands
    Quote Originally Posted by jimmyz View Post
    I heard that the flickering sometimes is being caused by a secondary display being used at the same time. Putting the system in single display config and not in dual display helped some people get rid of the flickering, myself included.
    I get flickering using the secondary output which is connected to my Sony Bravia LCD TV. When I use the dual display mode and want to watch a movie on the Sony TV, I get massive flickering and scanlines. Putting the system in single display mode helps and I can watch my movie as usual on my Sony Bravia. Seems there is a problem wih running dual display configs.
    Proc: Q9650 9x496 @ 1.440v batch L844B703
    Ram: 2x2GB OCZFlexII PC-9200 4:5 1240MHz 6-6-6-18 @ 2.12v
    Mobo: Gigabyte EP45-UD3P rev 1.0 - bios F9b
    Video: 2x Palit Dual Sonic HD4870 1GB in CF (840/4400)
    PSU: OCZ PowerStream 520W + Thermaltake VGA 450W
    HDD: 3x250Gb Barracuda 7.10 SATA2 Raid0 (ICHR10) 2x200Gb Barracuda 7.10 SATA2 Raid1 (ICHR10)
    Audio: Audigy 4
    Case: Dual Coolermaster Stacker; one for system rig and one for watercooling loop and cooling
    [SIGPIC][/SIGPIC]
    May 2004
    sounds like a driver issue. Now I have heard people had that problem from not keeping there memory for 2D and 3D the same.
    Desktop:
    Antec 300
    Foxcon A7AD-S 790GX
    8GB Gskill PC-1066@5/5/5/12
    PII X940 BE @3.6GHZ
    Sunbeam Core Contact
    2x 640GB in Raid 0+1
    4870 512MB@800/1000
    Vista Business 64bit W/ SP1
    Jan 2006
    can RBE editor raise voltages by software on 4870? and how to do it if it is possible...or should i just wait for an unlocked bios? card is under water
    DFI 790FXB-M2RSH
    AMD Phenom II 940BE
    Crucial Ballistix 4GB 2+2 kit 800Mhz
    Thermaltake Toughpower 850W
    2x Powercolor 3870x2 CrossfireX 4GPU
    Vista 64-bit
    Jul 2007
    I have one question the new diamond card coming out XOC, do you think there is a way for them to squeeze more voltage out of just the firmware, is that possible? because I was hoping to grab that bios when the card comes out. or do you think that they will just keep the same voltage and tweak the firmware to get more voltage, because I don't know how much more voltage they can give physically given it is still on stock cooler.
    Q9450(VID 1.2375) 3.9GHX 488*8 1.32V LOADED
    Asus P5Q-E
    CRUCIAL BALLISTIX 3GB RUNNING@980MHZ 5-5-5-12
    RADEON HD 4870
    OCZ VENDETTA 2
    WINDOWS VISTA 32BIT
    average room temp 72-76c
    Aug 2004
    The Netherlands
    Quote Originally Posted by vengance_01 View Post
    Yeah I heard that also. But if it is due to the memory switching, wouldn't I have this problem on both screens, regardless of which screen is used? It only appears on one screen. I hope Ati fixes these troubles with Cat 8.7
    Audio: Audigy 4
    [SIGPIC][/SIGPIC]
    Jul 2008
    I too have a problem with RBE (1.11). It seems it won't even correctly write voltages into bios image. It's simple to test. Load original bios, don't modify enything, just save it under new name. Restart RBE, load saved bios file - there is no voltages present at all, only "---" in their place. I'm modifying Powercolor 4870 bios. Also there is no reaction to changing frequency values, after modifying them my card defaults to 750/900 always and the changes can by small like 750 to 650 for core.... The last thing is (and it's a killer for me ) any change to bios results in card defaulting to PCI-E 1.1 16X instead of 2.0 16X. X38 chipset allows for 2x 16X lines of 1.1 or 2.0 variety so it's strange for me. Also it lowers the score some. Not much but it's there. Ah, using Winflash 2.012.
    Anybody can help here? Maybe I'm doing something wrong.
  18. #18
    Aug 2006
    RBE 1.12 is out now to make your lives easier. 1.11 works tho.
    Mat9v you need to read the built in FAQ for RBE the voltages are supposed to be like that.
    Specs: Q6600 @ 3.65ghz 1.42v / Asus P5Q Deluxe / 2x2gb Mushkin DDR2@810 / PC P&C 750w / 2x ATI 4850 Crossfire @ 710/1050
  19. #19
    Jul 2008
    RBE 1.12 fixed my problems, after loading already saved bios voltages appear as saved. Info about this fix is in the changelog.
  20. #20
    Dec 2002
    flashed to 850/1000 (org vcore/no modd)
    got the flickering screens, dualset up.
    gonna try reflash setting memory at same speed.
    edit: confirmed, set the same ram frequency seems to have fixed the flickering.
    4670k 4.6ghz 1.22v watercooled CPU/GPU - Asus Z87-A - 290 1155mhz/1250mhz - Kingston Hyper Blu 8gb -crucial 128gb ssd - EyeFunity 5040x1050 120hz - CM atcs840 - Corsair 750w -sennheiser hd600 headphones - Asus essence stx - G400 and steelseries 6v2 -windows 8 Pro 64bit Best OS used - - 9500p 3dmark11 (one of the 26% that isnt confused on xtreme forums)
  21. #21
    Xtreme Mentor
    Nov 2005
    Devon
    Quote Originally Posted by flopper View Post
    Great!
    Now I will reflash mine as well .
    I only hope new revisions of BIOS will fix that flashing screen issue and enhance PowerPlay capabilities.
    Also anyone tried with DMM if lowering voltages in BIOS is really changing anything?
    RiG1: Ryzen 7 1700 @4.0GHz 1.39V, Asus X370 Prime, G.Skill RipJaws 2x8GB 3200MHz CL14 Samsung B-die, TuL Vega 56 Stock, Samsung SS805 100GB SLC SDD (OS Drive) + 512GB Evo 850 SSD (2nd OS Drive) + 3TB Seagate + 1TB Seagate, BeQuiet PowerZone 1000W
    RiG2: HTPC AMD A10-7850K APU, 2x8GB Kingstone HyperX 2400C12, AsRock FM2A88M Extreme4+, 128GB SSD + 640GB Samsung 7200, LG Blu-ray Recorder, Thermaltake BACH, Hiper 4M880 880W PSU
    SmartPhone Samsung Galaxy S7 EDGE
    XBONE paired with 55'' Samsung LED 3D TV
  22. #22
    Banned
    Oct 2006
    thie problem with rbe 1.11 or 1.12 is that no one has been able to get the clock modes correct for the 4870... the 4850 seemed to be worked out pretty quickly...
    i wont use this program 'again' untill i'm absolutely sure which 'mode' is for which 'state'... that flickering you see is just unacceptable for me.. and it shows that even though you have oc'd clocks you havnt set up the bios correctly...
    i spent a good week experimenting... i must of flashed my cards a hundred times....
    nope we need to know which modes are for what.... if you can live with a dodgy bios on your new 4870 then good luck but i couldnt stand the flickering...
    ps.. it will happen while games load and when you open explorer and sometimes just move the mouse...
    one of the problems getting this info is that someone with a 4850 will post saying its 3 5 and 9 or something similar... its not... powerplay on the 4870 has a completely differant set up.... the modes are all differant....
    there is just too much guess work involved to get it right... i bet the new oc bios's wont have the flickering problem, so we should wait and load one of those up into rbe and then when we have that clock info, the sky is the limit...
    good luck everyone, hope you have better luck working those clock modes out in the meantime...
  23. #23
    Xtreme Mentor
    Nov 2006
    Spain, EU
    OK I've playing a bit with mine using RBE 1.12, now my card idles at 160MHz, UVD has a 300MHz clock, memory is fixed always at 1100 and 3D clock is at stock until I find the sweet spot. I've lowered voltages in all idle modes with no luck (1.046v), anybody knows how to lower it?
    Friends shouldn't let friends use Windows 7 until Microsoft fixes Windows Explorer (link)
    Quote Originally Posted by PerryR, on John Fruehe (JF-AMD) View Post
    Pretty much. Plus, he's here voluntarily.
  24. #24
    Jul 2007
    Quote Originally Posted by STaRGaZeR View Post
    What are the clock no to change in RBE ? Can you post a screenshot of RBE with the modified clocks/fields ?
    Q6600@3.6 GHz / GA-X48-DQ6
    2x2GB Kingston HyperX DDR2-800
    Asus HD 5870
    Corsair TX-850
    WD Velociraptor 150GB / WD Green power 500GB
    Water Cooling: EK res 250 > Swiftec MCP655 > Swiftec MCR320 > EK-FC5870 > HeatKiller 3.0 LT
  25. #25
    Xtreme Mentor
    Nov 2006
    Spain, EU
    Quote Originally Posted by r4st4m4n View Post
    You can change whatever you want. I've modified boot RAM speed because when you change it the image flickers. So now RAM is at 1000 always. I've found the sweet spot for this card, 880/1000 on stock volts. Increasing the memory speed has no effect on perfomance, I only get stability problems. Artifacts in ATITool but rock stable in games. And who cares about ATITool, this thing is flying. Maybe I'll do a pencil mod, but I doubt it will be available.
    Also I've increased UVD speed to 500MHz, at 300 some VC1 streams have artifacts. I'm on water BTW.
