Results 1 to 21 of 21
Thread: Way to soft-volt HD 4850 without 3rd party tool! (Fan speed hack too!)
    Aug 2005
    For this, you will need an HD 4850 (4870 should work as well), and you will need CCC installed. I use the latest "HD 4800 series hotfix" from AMD themselves.
    To do this, you simply need to Enable ATI Overdrive, and save a profile. Name it anything you'd like.
    Then, go to the following directory:
    "C:\Documents and Settings\*USERNAME*\Local Settings\Application Data\ATI\ACE" - for XP/XP x64
    "C:\Users\*USERNAME*\AppData\Local\ATI\ACE" - for Vista x86/x64
    Open your saved profile XML file in a text editor (i.e. Notepad), and find this line:
    <Feature name="CoreVoltageTarget_0">
    You want to edit the value of "Want_2" for that. It seems to work in 0.003v increments. The Want_2 value is in millivolts, so 1123 = 1.123v.
    My card could not get to 700 MHz core clock (the limit in CCC) with stock volts (1.123v for mine), but it worked fine using 1.158v.
    This was discovered actually when using Auto-Tune got me a higher OC, and I noticed that it adjusted the voltage after finding that CCC profiles store voltages. I saved a profile for stock, and OC'd, and I noticed that the Core Voltages were different. Auto-Tune found "1.158v" for me.
    Also, this was probably already posted here, but recently bretware of Guru3D discovered that you can also force fan speeds of 4800 series cards in the profiles. For example, I have mine set to 50%:
    Code:
            <Feature name="FanSpeedProtocol_0">
              <Property name="FanSpeedProtocolProperty" value="Percent" />
            </Feature>
            <Feature name="FanSpeedAlgorithm_0">
              <Property name="FanSpeedAlgorithm" value="Manual" />
            </Feature>
            <Feature name="FanSpeedRPMTarget_0">
              <Property name="Want" value="0" />
            </Feature>
            <Feature name="FanSpeedPercentTarget_0">
              <Property name="Want" value="50" />
            </Feature>
    .:: Gaming PC Specs ::.
    Case: Antec Nine Hundred
    CPU: Intel Core i7-2600K @ 4.6 GHz, 1.44v (cooled by Xigmatek GAIA) [IntelBurnTest{Linpack} stable]
    GPU/Monitor: VisionTek HD 6950 @ 6970, 950 MHz/1375 MHz 1.30v + Sony BRAVIA 32EX400 1080p
    Motherboard: GIGABYTE Z68XP-UD4 F5
    Memory: 16 GB (4x 4 GB) Corsair Vengeance LP DDR3 1600
    Hard Drive: 2x Seagate 500 GB 7200.11 RAID 0 & RAID 1 (Matrix RAID) + 1x WD Caviar Black 640 GB
    Sound: Creative SB X-Fi Fatal1ty Profess1onal, Logitech X-530
    PSU: Corsair AX-1200 (1500W PSU!)
    O/S: Microsoft® Windows 7 Ultimate SP1 X64
    Jan 2007
    Stephens City,VA
    you don't have to create a profile, just edit the one called profiles.xml and restart ccc to make changes take effect
    Asus Crosshair III
    Phenom X2 550@X4
    Cooler Master V10
    2x2gb G-SKILL DDR3
    ASUS HD 4890 Top
    Antec 850w
    WD 500gb
    WD 80gb
    Aug 2005
    Quote Originally Posted by hstuehmeyer2000 View Post
    It's easier to create a profile. Just edit the profile then, and do "Activate->Profile Name", and it instantly works... no restarting anything.
    #EDIT: Oh yeah, I posted this in the wrong section I was reading in this section when I posted.
    Jan 2007
    Stephens City,VA
    Quote Originally Posted by AgentGOD View Post
    don't you have the load the profile again every time you restart?
    Asus Crosshair III
    Phenom X2 550@X4
    Cooler Master V10
    2x2gb G-SKILL DDR3
    ASUS HD 4890 Top
    Antec 850w
    WD 500gb
    WD 80gb
    Aug 2005
    No, that's the beauty. It loads the last profile you activated automatically on startup.
    However, the big downside to CCC is that your OC is limited to 700 MHz core on the HD 4850... I've been trying to figure out how to get around it (w/o flashing BIOS).
    If anyone knows, please do tell!
    Xtreme 3D Team Member
    Jun 2006
    small town in Indiana
    So why is this posted in Xtreme Bios section if it doesn't involve a bios mod?
    as for the profile changes they were posted days ago. 1.2v or so is common for most cards so a mod that give less voltage (1.158v)I don't see a point in. flashing to a MSI bios can give a little over 1.21 (according to others, I haven't tried.)
    Not that we don't all appreciate the info, just weird to see this in bios mod section.
    QX 9650 5ghz with 1.55v 4.8ghz with 1.5v 24/7 in a VAPOLI V-2000B+ Single stage phase cooling.
    DFI LP LT X-38 T2R
    2X HD4850's water cooled , volt modded
    Thermaltake 1KW Psu
    4x Seagate 250GB in RAID 0
    8GB crucial ballistix ram
    Aug 2005
    Quote Originally Posted by jimmyz View Post
    [/B]
    I don't think you got the point of this topic... the point is proving that soft-volt is possible and has been done on the RV770. You can adjust the voltage manually (change the 1158 to something else), and apply the profile. Voila, soft-volt done w/o third party apps.
    As for the section issue:
    Apr 2006
    Montreal
    Now, the interesting thing here is that if all we need to do is to restart CCC for the voltage changes to take effect, it should be fairly trivial to create an application that can handle everything.
    The app would check to see if in 2D, 3D or Aero mode, write changes (fan, volts, etc.) to XML when necessary, kill CCC process and restart it. Simple, really.
    Aug 2005
    If you make a separate profile, you don't even need to restart CCC, just re-activate the profile, and the voltage changes will take effect.
    Mar 2008
    Only certain values such as 1123 or 1158 or 1084 or 1046 work. The rest won't work at all, so maybe voltages are set values.
    That aside, to obtain this, just use Autotune, instead of manually editing the clocks. Using Autotune, you can achieve higher overclocks as well.
    Just to prove a point:
    Motherboard: ASUS P5Q
    CPU: Intel Core 2 Quad Q9450 @ 3.20GHz (1.07v vCore! )
    RAM: 2GB Kingston HyperX 800MHz
    GPU: MSI Radeon HD 4870 @ 780/1000 (default)
    Aug 2005
    My video RAM doesn't want to be stable at 1100 MHz (ATITool shows signs of artifacting [yellow stuff appearing]), but 1075 MHz works for me.
    You know if you can also adjust memory voltage through the profile hack as well?
    Also, anyone know how to remove the core clock limit of 700 MHz from CCC?
    Mar 2008
    Ahem... you may try editing the core clock within the profile, though if you stay barely stable at 1158, it's not really recommended. Memory volts show a flat 0 for me, so I have no idea.
    If you want to improve your overclock, try using Autotune, and wait until it cannot go any higher, then back down a bit or go up a bit, and go for a 1-hour artifact test on ATITool.
    Aug 2005
    Quote Originally Posted by RunawayPrisoner View Post
    I've already tried editing the clock... CCC will not accept the profile. It will act like nothing happened (if I put something out of CCC's range).
    Also, Auto-tune will not go above 700 MHz core as it cannot.
    Mar 2008
    Then 700 it is. If you need more, modify the BIOS, I guess. Or... edit the file called "Profiles.xml" instead of the file "profile-name.xml." My overclocking settings are stored in that file.
    Aug 2005
    Yeah, I just tried using BIOS mod (change voltage to 1.263), and anything above 710 MHz resulted in artifacting in ATITool.
    I am still on the stock cooler though. I'm thinking about putting Dual-Orbs on it.
    Mar 2008
    Be careful with voltage modding beyond 1.263v, as it can get the card to run so hot that you'll literally need two vacuums to pull the heat out and blow cold air in. Plus BIOS modding only gives 1.23v actual at stock voltage (1.237 to be more precise). If you are using an aftermarket cooler, it's necessary to have insane cooling on the VRMs. Actually, put more cooling on the VRMs than on the GPU.
    Nov 2006
    Northland, New Zealand
    bios modding it to 1.264 does not give it 1.23v, for me with my multimeter, it was 1.19v, even if u set it at 1.4v, you have to pencil mod or volt mod to get above 1.20v, my 4850 is running @ 885/1200 100% stable thru crysis, furmark and everything with 1.4v actual (tested) and 900 thru 06 and 910 thru 03
  18. #18
    Aug 2005
    Damn, I don't want to pencil my new shiny $200 card
  19. #19
    Jan 2007
    Stephens City,VA
    do you guys know you can use amd gpu tool now to oc the card?
    http://downloads.guru3d.com/AMD-GPU-...load-1985.html
    Asus Crosshair III
    Phenom X2 550@X4
    Cooler Master V10
    2x2gb G-SKILL DDR3
    ASUS HD 4890 Top
    Antec 850w
    WD 500gb
    WD 80gb
  20. #20
    Mar 2008
    Yeah, but using this tool you unable CCC profile and temperatures are back in the heaven, over 80 degrees in load. That's the main problem with this tool.
  21. #21
    Jan 2007
    Stephens City,VA
    Quote Originally Posted by h-tomek View Post
    just flash your card with the fan speed you want and then use the program to oc
    Asus Crosshair III
    Phenom X2 550@X4
    Cooler Master V10
    2x2gb G-SKILL DDR3
    ASUS HD 4890 Top
    Antec 850w
    WD 500gb
    WD 80gb
