XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme > Xtreme Overclocking
Reply
Old 07-05-2008, 07:19 AM   #1
dinos22
...you two characters
dinos22's Avatar
Talking [Team.AU] E8500=6128MHz, Biostar P45 + Corsair PC10000 DOMINATORS 4-4-4-4 DualChannel
I know i know another Biostar thread LOL
but what can you say when this board is that good
no mods on my board and FSB limit of 611MHz for 32M SuperPi runs on CAS4 but i did do some superpi tests at 5.8GHz-5.9GHz tonight
i didn't want to kill anything so i stopped the session as condensation was really starting to get a bit much for me.....i will give me my best to make it stable at 5.9GHz for some 8M and 32M runs...i know i can do it damn it lol
Test Configuration:
Biostar TPower P45 board
***1.88vcore, 2.68vdimm, 1.69vMCH, 1.47vFSB***
Intel Core2 Duo E8500 Q740A497
2GB DDR2 PC10000 Corsair DOMINATORS (645MHz 1:1 4-4-4-8 timings)
PCI GFX Card MX200
620W Corsair PSU
Stock heatsink on NB (LN2 cooled with small pours)
kingpin F1 Extreme Edition Solid copper CPU LN2 Pot
Big mamma 35L LN2 Dewar
160GB PATA
Windows XP Pro 32bit SP3
I was FSB limited here.........and condensation kicked in when i figured out how to run 1.92vcore and -140C lol
this CPU is a monster.......i need a board that can give me stable 631MHz FSB so that i can bench it at 6GHz rofl
Validation Link: http://valid.x86-secret.com/show_oc.php?id=384946
here is my settings template i usually use and then adapt it to whatever cooling i am using....so it would be slightly different for the above run if you know what i mean
Code:
SETTINGS
M/B : BIOSTAR TP I45 (BIOS:626)
CPU : Core2 Duo E8500(Q740A497) best CPU i've EVER had :D [EDIT]...errrr maybe my Opteron 146 with 11x multi still takes the cake
CPU cooling : TTBig Typhoon
Chipset Cooling : stock with extra fan
Mem : 2GB Kit of Crucial Ballistix
2GB DDR2 PC10000 Corsair Dominator "dead" kit for CAS4 << still works eeek even it tons of errors in memtest heheh
VGA : PCI GFX Card
HDD : Samsung 160gb ide
OS : Windows XP SP3
USB wireless mouse and PS2 keyboard
[BIOS SETUP] O.N.E
Over-Clocking Navigator [Manual OverClock]
Intel(R) SpeedStep(tm) : Disabled
Ratio CMOS Setting : ×6 (change higher for benching subzero obviously)
CPU Frequency Setting : 570(boot)
Over Clock Retry Count : 2
FSB Compensation: Enabled
FSB(Bsel) To NorthBridge Latch : 1333
DRAM Frequency : DDR2-1140
DDR2 Enhance Mode : Disabled
DRAM Timing Configuration
DDR2 RCOMP Configuration : 2
Static tREAD Value : AUTO
Configure DRAM Timing by SPD : Enabled
[EDIT] this will give you CAS5 clocks and PL10 past 600MHz FSB
for PL9 past 600MHz FSB you need to manually set CAS4 timings
Clock Gen Configuration
PCIE Frequency Setting : 100
CPU Clock Skew Control : 200ps
(G)MCH Clock Skew Control : 100ps
CPU Clock Driving Control : Auto
Voltage Configuration
CPU Voltage : SET WHAT IS REQUIRED FOR STABILITY AT MHZ YOU ARE BENCHING ON
DDR Voltage : +0.600v (use more depending on RAM)
Chipset Voltage : +0.600v
FSB Voltage : +0.40v
CPU Core1 GTL Ref Voltage : 0.63*VTT
CPU Core2 GTL Ref Voltage : 0.67*VTT
MCH GTL Ref Voltage : Auto
CPU PLL Voltage : 1.5v
i also disabled Multicore Computing under CPU section for max Superpi with single core otherwise enabled for 3D benching
Originally Posted by dinos22 View Post
here is another update
32M SuperPi at 5826MHz....had a couple of runs stop at 584x and 585x so i gave up
also my hard drive must be screwed up as i am not happy with my efficiency but results are not too bad i guess
also here is a 6GHz 1M
absolutely hideous PP hehehehe
i am FSB limited by this board
this CPU has a lot more to give
with the right board...i would be expecting at least 5.9GHz 2D/3D
Josh is going to have a lot of fun with this CPU
it handles -150C plus no problems lol
update
8M SuperPi: 1m 41.9s
32M SuperPi: 8m 18.190s
__________________
Team.AU
Got tube?
Originally Posted by Gautam View Post
In the old days, LN2 benching was "cheating". Then LOD was "cheating". And so on and so forth...
dinos22 is offline   Reply With Quote
Old 07-05-2008, 07:40 AM   #2
eva2000
Memory Addict
eva2000's Avatar
Bloody awesome Dinos... i could feel it that you had something cooking this weekend
these E8500 Q740A479 seem to be pretty strong too
eva2000 is offline   Reply With Quote
Old 07-05-2008, 07:45 AM   #3
dinos22
dinos22's Avatar
killer CPUs man
just awesome
__________________
Team.AU
Got tube?
Old 07-05-2008, 07:49 AM   #4
ZoLKoRn
Xtreme X.I.P.
ZoLKoRn's Avatar
Send a message via MSN to ZoLKoRn
Huh... 645MHz 1:1 4-4-4-8 on dual-ch very nice
Congrats Dinos
__________________
Sorry For My English
OverclockZone Team
THAILAND
Originally Posted by hipro5 View Post
Actually there is NO NEED for 164 phases that companies put in nowadays mobos....
FOUR (4) are enough with nowadays materials and maybe SIX (6) with the upcoming Gulftowns....
The 1024 phases is a "marketing trick" nowadays....
You will buy MY mobo because I put 2048 phases in my motherboard....
ZoLKoRn is offline   Reply With Quote
Old 07-05-2008, 07:51 AM   #5
dinos22
dinos22's Avatar
Congrats Dinos
i can do 32M SuperPi on that
but the board it too weak
__________________
Team.AU
Got tube?
Old 07-05-2008, 07:55 AM   #6
ZoLKoRn
Xtreme X.I.P.
ZoLKoRn's Avatar
hehehe well that's great RAM man You know what that chip GKX or GMH ?
__________________
OverclockZone Team
THAILAND
Old 07-05-2008, 08:11 AM   #7
dinos22
dinos22's Avatar
they should be GMH
__________________
Team.AU
Got tube?
Old 07-05-2008, 08:28 AM   #8
Gautam
Captain Jinx
Gautam's Avatar
Send a message via AIM to Gautam Send a message via MSN to Gautam
P45 looks so strong...and I can't believe DDR2 is still putting out such heavy performance even today.
__________________
Originally Posted by FUGGER View Post
I put on my shoes before I put on my pants.
Gautam is offline   Reply With Quote
Old 07-05-2008, 08:33 AM   #9
dinos22
dinos22's Avatar
intel means business with this chipset lol
but i can't believe that Biostar is kicking everyone's ass
what the hell's going on here hahahah
__________________
Team.AU
Got tube?
Old 07-05-2008, 08:58 AM   #10
andre X_X
Team.ID
andre X_X's Avatar
Send a message via Yahoo to andre X_X
awsome chip there dinos...
looks like biostar already found the right formula for their bioses
anyway, where's pi?
__________________
E8600 Q820A750
DFI LanParty UT P35-T2R - Abit IX38 QuadGT - Asus P5B Deluxe - Biostar TP45 HP
Team Xtreem PC-5300 C3 2GB - Crucial 10th Anniversary 2GB - Team Xtreem PC8500 C5 2GB
Winfast 8600GT
Silverstone Olympia 1000w
andre X_X -72c CO2 Cascade
My R22/CO2 Cascade Project
andre X_X is offline   Reply With Quote
Old 07-05-2008, 09:45 AM   #11
hyunsuk
hyunsuk's Avatar
Send a message via AIM to hyunsuk Send a message via MSN to hyunsuk Send a message via Skype™ to hyunsuk
wow nice fsb~
Biostar P45 and e8500(q740a) air fsb wall??
hyunsuk is offline   Reply With Quote
Old 07-05-2008, 10:35 AM   #12
BenchZowner
One-Eyed Killing Machine
BenchZowner's Avatar
Send a message via ICQ to BenchZowner Send a message via AIM to BenchZowner Send a message via MSN to BenchZowner Send a message via Skype™ to BenchZowner
Damn Dino, you're so lucky man.
Congrats and have fun benching that beast.
Oh, and always, better be safe than sorry ( plastik spray on teh mobo ftw )
__________________
Many thanks to: Sue Wu, Yiwen Lin, Steven Kuo, Vivian Lien, Joe Chan, Sascha Krohn, Joe James, Amy Deng, Jack Peterson, Hank Peng, Mafalda Cogliani, Olivia Lee, Marta Piccoli, Oliver Baltuch, Steffen Eisentein
ASUS CAN LICK MY COJONES
BenchZowner is offline   Reply With Quote
Old 07-05-2008, 10:39 AM   #13
Yellowbeard
Corsair Rep
Yellowbeard's Avatar
Send a message via AIM to Yellowbeard
Team.AU strikes again! Nice speed there Dinos!
__________________
Yes, Yellowbeard, a tall rough man with a big yellow beard
Yellowbeard is offline   Reply With Quote
Old 07-05-2008, 10:48 AM   #14
CarpeDiem
CarpeDiem's Avatar
Monster CPU indeed. Nice work Dinos
__________________
AMD Athlon XP-M @ 2500MHZ | 2x256 Corsair PC3200LL v1.1 BH-5 250 FSB 2-2-2-11| DFI Infinity NF-2 Ultra | ATI 9800 Pro | WD Caviar Blue 500GB | Antec Earthwatts 550W | Antec 1200 | Dell 2408wfp | Windows XP 32-bit
CarpeDiem is offline   Reply With Quote
Old 07-05-2008, 10:52 AM   #15
TheKarmakazi
Title is Under NDA
TheKarmakazi's Avatar
VERY nice... that cpu is monsterous!
Waiting for some really nice spi
__________________
PURE benching, teamwork, determination, skill, dedication.
TheKarmakazi is offline   Reply With Quote
Old 07-05-2008, 06:53 PM   #16
dinos22
dinos22's Avatar
anyway, where's pi?
heheh i won't post Pi until i have my final clocks and speeds with things tweaked............but i am trying to bench 8M and 32M atm.............and one is VERY close to W.R. already and the other will be not so close but a fast time indeed
Originally Posted by hyunsuk View Post
wow nice fsb~
i have a board FSB issue here......i will have to sick vtt around 1.55 or more and see what we get
Originally Posted by BenchZowner View Post
F*ck me!
i used nail polish first and then i used frost king and loads of layers plus lots of paper towels
my insulation is usually pretty good but when you throw LN2 on NB with some little contraption around the stock heatsinks and part of it is exposed you are bound to get some condesation fairly soon lol
thanks mate
thanks for hooking me up with some of that Frost king gears.....that stuff just does not exist in Australia lol
thanks mate
cheers
__________________
Team.AU
Got tube?
Old 07-05-2008, 06:57 PM   #17
Benny Lodewijk
Team ID - Indonesia
Benny Lodewijk's Avatar
Send a message via MSN to Benny Lodewijk Send a message via Yahoo to Benny Lodewijk
that nuts Dinos22 !!! Congrats m8 !
Benny Lodewijk is offline   Reply With Quote
Old 07-05-2008, 09:45 PM   #18
gbglassen
monster clocks all the way Dinos22!! 645Mhz cas4 32M would be really insane
__________________
x800xtpe
9800xt
gbglassen is offline   Reply With Quote
Old 07-05-2008, 09:48 PM   #19
dinos22
dinos22's Avatar
i would kill for a board that can do that kind of FSB hahahah and be able to handle LN2
this biostar really is the best bet ATM
here's a couple of pics
__________________
Team.AU
Got tube?
Old 07-05-2008, 10:06 PM   #20
Spacemaster
Spacemaster's Avatar
Send a message via MSN to Spacemaster
Nice setup and score my friend!
Go, go dinos22
__________________
Spacemaster is offline   Reply With Quote
Old 07-05-2008, 11:33 PM   #21
gandalfone
gandalfone's Avatar
Very nice dinos
I'm wainting spi32m
Good Luck
__________________
gandalfone is offline   Reply With Quote
Old 07-05-2008, 11:50 PM   #22
Harshal
X.I.P.
Harshal's Avatar
Send a message via MSN to Harshal
Congrats Dino!
Very nice CPU and board... we all now know how that is
__________________
p e a c e
Harshal is offline   Reply With Quote
Old 07-06-2008, 12:24 AM   #23
giraffen
giraffen's Avatar
Send a message via MSN to giraffen
what a hell´s of speed Nice insulate. Looks forward for some bench
__________________
OCTeamDenmark Crew - Cooled and sponsored by CoolerKit.dk
giraffen is offline   Reply With Quote
Old 07-06-2008, 01:01 AM   #24
massman
www.hwbot.org
massman's Avatar
Send a message via MSN to massman
Most of the time I skip these kind of threads, because most of them are just the same ... BUT this one is better!
645 4-4-4-4 DC is very, very good. Now I'm expecting so much more from your setup, speaking in PI-terms here . Looking forward to the next update!
massman is offline   Reply With Quote
Old 07-06-2008, 02:28 AM   #25
BenchZowner
You should've seen my P5K3 Deluxe "Swimming Pool" edition Dino
In one of the last ( few ) benching sessions I forgot to insulate a area which would get really cold for sure ( the reason why I forgot to insulate that area was because I was trash-talking about Aussie's cheating in SuperPi with my cousin ) and when I noticed that, there was lots of water floating around that area ( thank God I insulate nearly 100% of my boards PCB ) ) I continued benching, and left it there for a while until I managed to grab a towel
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
