Page 1 of 23 123411 ... LastLast
Results 1 to 25 of 557
Thread: 4870 Overclocking Thread
    Engineering The Xtreme
    Feb 2007
    MA, USA
    So since there wasn't one of these I figured I would start it.
    This is my first oc above 790 and I have great results. I have yet to receive my 2nd 4870 back from RMA so I will definitely have some more additions to this thread
    ORB link for comfirm and other system specs
    Note: Others to post please follow this format, you do not have to use extreme preset but you get the picture
    Aug 2007
    Could you tell me about the used softwares? I edited every clock with RBE but GPZ-U still show 750Hmz and my 3dMark score proof is. (Sapphire 4870) Should I uninstall CCC?
    Oct 2007
    Sydney, Australia
    I just installed a GeCube 4870 and would also like to know what software to use to flash this baby.
    My last bios flash was for the 8800gts 320.
    Can't wait to oc this past 790
    thanks
    ps this is my first ati card ever, since the days of wolfenstien 3d
    [SIGPIC][/SIGPIC]
    CoolerMaster Stacker 830SE|Antec Signature 850W|Gigabyte X58A-UD5 F5 slic2.1
    Intel Core i7 930 16x200@3,200Mhz|vcore 1.14|Intel Stock CPU Cooler
    GSKILL DDR3 Perfect Storm 2000 @6-6-6-16-1T 1600Mhz|ATI 5870 1024MB 850/1200
    Windows 7 Ultimate x64 bootdisk: Crucial RealSSD-C300 128GB SATA-III
    Feb 2008
    uk , bristol
    hopefully we wont have to wait long for some tools to come along ....used the gfx cooler fix atm to keep temps a bit lower
    Xtreme Mentor
    Jul 2004
    Ontario
    Hi Sniipe Dogg. Was all this on stock volts and stock cooler? Did you change thermal paste at all? What was fan speed at? Temps for idle/load at those settings?
    As well, what did you do to thoroughly test the card for stability and artifacts? Have you tried higher? How does the card respond exactly when it becomes unstable?
    Sorry for the myriad of questions, just very curious is all as I have my eyes set on this card. Thank you.
    Silverstone Temjin TJ-09BW w/ Silverstone DA750
    Asus P8P67
    2600K w/ Thermalright Venomous X Black w/ Sanyo Denki San Ace 109R1212H1011
    8GB G.Skill DDR-1600 7-8-7-24
    Gigabyte GTX 460 1G
    Modded Creative X-Fi Fatal1ty w/ Klipsch Promedia 2.1
    1 X 120GB OCZ Vertex
    1 X 300GB WD Velociraptor HLFS
    1 X Hitachi 7K1000 1TB
    Pioneer DVR-216L DVD-RW
    Windows 7 Ultimate 64
    Quote Originally Posted by alexio View Post
    From the hip and aim at the kitchen if she doesn't approve your purchases. She'll know better next time.
    Jan 2005
    Here's mine so far, have gotten it running higher but the heat's high at 870/4500...
    I don't own Vantage, so I can't post a bench of that. I have thoroughly tested the card for stability and whatnot, though. This is all on the stock cooler with no thermal paste change, 46-47c idle. Fan speed is at 37% for idle (at 49c it turns up), and 45% then, 54% at 55c, with the rest of the profile set to high temps that it doesn't reach. When it becomes unstable it just makes a kind of squarish artifact grid full-screen, for a split-second, and then the display goes black.
    Banned
    Oct 2006
    well, i'm really tempted to use rbe again but i dont want to have the card running with max volts in 2d.... its just not going to be healthy imo... i might be wrong....
    as soon as we know which clocks effect which state, i'll be pushing my cards again....
    by the way, if you've worked some of these out, let me know..... thanks in advance....
    Feb 2007
    MA, USA
    Quote Originally Posted by janos666 View Post
    you must first flash to stock bios, the uncheck ati overdrive, then flash to the OC'ed clocks and you should be all set
    Quote Originally Posted by cantankerous View Post
    Stock volts, stock cooler. MX-2 on the GPU. fan profile set through graph: low=40 high=70 minfan%=20. I am about to try higher in the next 30 mins or so. It hasnt become unstable yet so i have no idea how it responds
    Quote Originally Posted by Dragy2k View Post
    stock cooler gives me load temps of 50C
    Quote Originally Posted by purecain View Post
    the voltage never changes evwen in stock bios and 2d clocks, all your changing is a slight amount and its not like the gpu is running at load all the time so your not getting a ton of heat
    Feb 2007
    MA, USA
    here is the newest result, i will add my performance score in like 20 mins
    http://service.futuremark.com/compare?3dmv=215656
    Performance preset:
    http://service.futuremark.com/compare?3dmv=215700
    Aug 2006
    Oxford, UK
    pretty impressive.
    So this is all at stock voltage? Has anyone measured the actual vGPU? It's listed as 1.263v in the BIOS.
    || 2500K @ 5GHz 1 thread, 4.8 2 threads, 4.7 3, 4.6 4 1.284V ||
    || P8P67-M Pro || 8GB @ 2133MHz ||
    || 5850 @ 1000/1225 || XFX 650W || Silverstone FT03B ||
    || 37" LCD TV || CM Hyper 212+ || Samsung 2.1 Soundbar ||
    Feb 2007
    MA, USA
    Quote Originally Posted by gurusan View Post
    pretty impressive.
    i am borrowing a very accurate multimeter (6 decimal accuracy) on monday or tuesday so i will test then
    as far as i know these are stock volts 100% I can't wait to volt mod though
    Mar 2008
    Oslo, Norway
    Is it possible to see some benchmarking from games, before and after overclock?
    I Are DuneCat
    I Controls The Spice
    I Controls The Universe
    Cooler Master ATCS 840 | Corsair HX 520W | Asus P5Q Pro | Q9550 | HD4870 | Corsair Dominator 4GB PC8500 |
    D-Tek FuZion v2 - EK RES 150 - Swiftech MCR-220/320 - Swiftech MCW-60 - DDC 3.2 + Petra's Top
    Jan 2005
    Quote Originally Posted by Zehnsucht View Post
    Check out my thread here (http://www.xtremesystems.org/forums/...d.php?t=192654) and at hardforum (http://www.hardforum.com/showthread.php?t=1319500) for some benches before/after between a couple of overclocks.
    Oct 2007
    Sydney, Australia
    [SIGPIC][/SIGPIC]
    Jul 2007
    After seeing the results here I tried my 4870 at 840mhz and it did it easily:
    Sorry, no 3Dmark results as I don't usually bother with those. I did see a nice jump in ingame framerates though, much more then I was expecting.
    I don't think I will push it much more until 3rd party OC tools and waterblocks are available though.
    Feb 2007
    MA, USA
    I strongly suggest that you all test for artifacts with ATI tool, this ram is only specced to run at 4ghz. When I run at 1050 or even 1020 I get artifacts and if your card is in fact artifacting you are slowly killing the RAM. now I am back at 1000 and I get no artifacts after 45 mins of artifact test.
    Jul 2007
    I get no artifacts on the ram at 1100 or 4400, whatever you wanna call it, I teste with ati tool for about 15 mins and no errors, I believe it is the heat that might give you artifacts on at those speeds, but this ram seems to be perfectly capable of 4400, I set my fan speed at 37% and it idles at 49-50c and never breaks 62c under load. I have it running at 840/1100 with the bios flash and fan speed edited. at 850 I did get artifacts in crysis only at very high, so now at 840 I do not get any artifacts. here is a vantage screenshot with my gpu at 840/1100, and q9450 at 3680mhz.
    lol I tried the medusa demo crack and it actually worked but half way through I started getting glitches.
    Q9450(VID 1.2375) 3.9GHX 488*8 1.32V LOADED
    Asus P5Q-E
    CRUCIAL BALLISTIX 3GB RUNNING@980MHZ 5-5-5-12
    RADEON HD 4870
    OCZ VENDETTA 2
    WINDOWS VISTA 32BIT
    average room temp 72-76c
  18. #18
    Dec 2007
    Quote Originally Posted by Solus Corvus View Post
    ...waterblocks are available for a long long time, since you can use the same as for the x19xx and HD38xx series. I find the best performance/value ist the Zalman ZM-GWB3 in combination with MX-2 thermal paste.
    _________________________________________
  19. #19
    Aug 2006
    Oxford, UK
    ^aluminum FTL!
    anyway any decent waterblock does a great job. I'm using a maze4 and get 24c Idle 32c load at 1.35v 820mhz
  20. #20
    Dec 2006
    France
    Overclock 4800 with the last version of AMDClockTool
    link : http://www.overclex.net/data/images/...cktool-9.8.rar
    credit : http://translate.google.fr/translate...&ie=ISO-8859-1
    AMD Phenom II X2 550@Phenom II X4 B50
    MSI 890GXM-G65
    Corsair CMX4GX3M2A1600C9 2x2GB
    Sapphire HD 6950 2GB
  21. #21
    Aug 2006
    Oxford, UK
    AWESOME! Thanks for that abeljemka
  22. #22
    Xtreme 3D Team Member
    Jun 2006
    small town in Indiana
    Quote Originally Posted by AbelJemka View Post
    awesome news spreading it now...
    QX 9650 5ghz with 1.55v 4.8ghz with 1.5v 24/7 in a VAPOLI V-2000B+ Single stage phase cooling.
    DFI LP LT X-38 T2R
    2X HD4850's water cooled , volt modded
    Thermaltake 1KW Psu
    4x Seagate 250GB in RAID 0
    8GB crucial ballistix ram
  23. #23
    Banned
    Oct 2006
    doesnt work on vista64...
  24. #24
    Aug 2006
    Oxford, UK
    I'm using Server 2008 64 and it works fine
  25. #25
    Jun 2006
    right click , run as administrator.
    DFI LP LT X-38 T2R
    Thermaltake 1KW Psu
Tags for this Thread
