I went with an AquaExtreme MP-01 since Jab-tech had them on clearance for $36+. In the past I had an MCW-60, I just hate spending $40 then another $10 for chrome barbs (I hate plastic ones). Installation was easy on the HD4870, no issues with the shim on the HD4870, the MP-01 fit and made perfect contact with the core. I added mosfet sinks and ram sinks and have a few low speed yates blowing over the card. DDR5 does get hot and even though I can run them at 1100 (4400Mhz effective), there is enough memory bandwidth already and the extra speed equates to more heat and little performance so I've been keeping the ram about 980 - 1000mhz.
Idle runs about 32deg c load has never broken 40c yet. Big difference from 60c idle and high 80s loaded with the stock cooler. Using the TT Duo Orb idle was in the mid 40s, load in the low 70's.
Enjoy.
