4850 CF issue?
Hiya,
I've got some strange CF issues with two Club3D 4850's here. Each one runs flawless without the other attached but stick em together and nothing works. No matter what I do. Mobo is Asus Evolution with 0401 bios.
Here's what I've tried so far: (on both dirty XPSP3, clean XPSP2 and clean Vista SP1)
- put one 4850 in the top x16 slot: OK
- put the other 4850 in the top x16 slot: OK
- put one 4850 in the bottom x16 slot: OK
- put the other 4850 in the bottom x16 slot: OK
- put both 4850's in blue x16 Crossfire: either no post (out of sync lookalike) or boots and stops when loading windows
- put one 4850 in x16 and the other in x4: both cards are detected and installed, but no CF possible
- been using Catalyst 8.6 with and without hotfix
- tried giving each card its own 6-pin PCIe wiring
- tried with one and two CF connectors
Running out of ideas here..
Reason: typo xD
Oh blah?
- You may not post replies
- You may not edit your posts
Forum Rules
