Hi, guys!
I forgot how to post new thread because I had too neglected to report my bench results.
This week I tested new P45 mobo under LN2.
I love it as much as FOXCONN BlackOps.
But this is a quick test of CPU and CrossFire sysyem.
2GPUs is almost default clock.
Next I will try more high-speed 2GPUs CF system.![]()
PS:3870X2 CFX system could not boot at all.
Setup:
M/B : BIOSTAR TP45 HP Ver.5.0 Vcore mod (BIOS:P45BA620.BST)
M/B Bed : V-TEC ARC Bed Rev.5.3
CPU : Core2 Duo E8500 Q813A227#1
CPU cooling : MaxxNeo + LN2 / Temp:-135C
Chipset Cooling : Tara-chan 1st + LN2 / Temp:-50C
Mem : Team PC2-8500 C4 1GB x2
VGA : SAPPHIRE RADEON HD2900PRO 1G DDR4 PCI-E CrossFire
VGA Cooling : Stock
HDD : Western Digital WD360ADFD
PSU : SilverStone OP1200
OS : Windows XP
[BIOS SETUP] O.N.E
Over-Clocking Navigator [Manual OverClock]
Intel(R) SpeedStep(tm) : Disabled
Ratio CMOS Setting : ×8
CPU Frequency Setting : 570
Over Clock Retry Count : 2
FSB(Bsel) To NorthBridge Latch : AUTO
DRAM Frequency : DDR2-1140
DDR2 Enhance Mode : Disabled
DRAM Timing Configuration
DDR2 RCOMP Configuration : Configuration 2 or 4
Static tREAD Value : Auto
Configure DRAM Timing by SPD : Disabled (4-4-4-10-6-28-4-4-4)
Clock Gen Configuration
PCIE Frequency Setting : 100
CPU Clock Skew Control : 200ps
(G)MCH Clock Skew Control : 100ps
CPU Clock Driving Control : Auto
Voltage Configuration
CPU Voltage : +0.6000v (Actual : 1.88V @ vcore mod)
DDR Voltage : +0.700v (Acyual : 2.66V)
Chipset Voltage : +0.400v
FSB Voltage : +0.350v
CPU Core1 GTL Ref Voltage : 0.63*VTT
CPU Core2 GTL Ref Voltage : 0.67*VTT
MCH GTL Ref Voltage : Auto
CPU PLL Voltage : 1.6v
Vcore mod
MAX FSB : 687.27MHz
3DMARK05 : 36214 CPU/GPU/Mem/PCI-E : 5900MHz/800MHz/950MHz/100MHz
