06-26-2008, 11:40 PM
#1
X.I.P
Diamond HD4870 3Dmark06 Default and OC tests
Diamond HD4870 3Dmark06 tests
Diamond HD4870 Retail Card, Nice black packaging
Front and Back of the Card. only one side have GDDR5 which mean 1GB version will have GDDR5 in BOTH side
2 slots means 2 6pin LOL
55nm RV770 and Qimonda GDDR5
3Dmark06 Default
QX9650 4G, Asus P5Q Deluxe, GSKILL DDR2 1200 4GBPI
Diamond HD4870 750/900
3Dmark06 Tweaked
3Dmark06 Tweaked + 4870 OC
Diamond HD4870 790/1100
Flash to my home made custom bios
enable to 1000/1200 overclock
running at 850MHz Core, 1100MHz Memory
3DMARK2001
3DMark03
3Dmark05
3Dmark06
06-26-2008, 11:45 PM
#2
makes me wanna do the bios thing, but i don't wanna risk killing my card.
nice results!
06-26-2008, 11:54 PM
#3
X.I.P
nice results!
that bios thing enable CCC oc to 900mhz for core and 1400mhz for mem...
06-27-2008, 01:28 AM
#4
Xtreme X.I.P.
what is the bios use please ? are you a link at give ? thank
__________________
OCM Member / IXTREMTEK Admin !!
DDR1 2*256 BH5 Adata @324.7Mhz 1.5/2/2/5 1T at 4v @318.6Mhz Benchs
DDR2 1*512 Kingston Pc8500 @702Mhz 5/5/5/18 at 2.42v réel
DDR2 2*1024 Cell Shock Pc8000c4 @534Mhz 3/3/3/8 at 3.5v réel
Cooling : XP90C , Big Typhoon , waterchiller R507 , LN2 ....
06-27-2008, 02:07 AM
#5
I am Xtreme
What did you tweak in 3D Mark 06? 1400 more points?  That is awsome,I got max 200 points from tweaking
06-27-2008, 03:14 AM
#6
Same question
pretty gfx, nice results!
06-27-2008, 03:46 AM
#7
can you run CF with HD4870 or even Quad CF ??
06-27-2008, 04:33 AM
#8
Why wouldn't he be able to run CF? All he or anyone needs is multiple HD4870's and it will work fine.
Nice scores Denny  It's too bad you killed your new toy so soon, as I would have loved to see what you were getting in 05 and 03 at those speeds
__________________
Core i7 920 D0 @ 4Ghz (H2O)
2x HD5870 Crossfire @ 1000/5400 (H2O)
GTS250 PhysX @ 800/2000/2500
EVGA X58 E758 (H2O)
6GB G.Skill 1600Mhz DDR3
Antec TPQ 850w
Windows 7 Pro
Thermaltake Xaser VI
06-27-2008, 06:47 AM
#9
damn I didn't even think you could kill a card from just clocking the memory too high. No voltmod?
06-27-2008, 06:50 AM
#10
Nice scores and results. Sorry about the card.
Tell us more about this bios plz
__________________
Cooler Master Stacker 810 WATERCOOLED
Black Ice GTX 360 // Danger Den TDX CPU WB //
Maze 4 GPU WB // D5 Pump // SwifTech Micro Res.
ASUS P5B DELUXE // E8400 @ 4250MHz 500*8.5 1.41v
2x2GB MUSHKIN ASCENT DDR2 1066
SAPPHIRE HD4870 512Mb @ 845-1050
Corsair HX1000w // SB Audigy 4
06-27-2008, 10:34 AM
#11
X.I.P
for 3Dmark06 tweak, you need to change the setting of CCC and also the LOD
i hope i have 2 cards so i can do CF.. now i don't even have 1 lol
no vmod, it just died, 1200 x4 = 4800. maybe i really overclock too high.. becareful on those GDDR5
for bios question, i am sorry i can talk about any detail of that in here
06-27-2008, 10:45 AM
#12
Xtreme X.I.P.
And the P.M , it's possible ?
__________________
06-27-2008, 12:12 PM
#13
I am Xtreme
Can you be more precise,~2k points is a lot
06-27-2008, 04:23 PM
#14
I would like to know the tweaks as well
__________________
24/ 7 Gigabyte EP45-UD3R| E8400 @ 4302 Mhz @1.344v| Corsair 2 x 1GB DHX @ 940 Mhz 2.06v| PNY 9800GX2 700/1750/1100|Cooler Master 690 + 3 x 140mm + 2 x 120mm| TRUE + 2 x 120mm| Chieftec 750-14C 750W
AMD makes it first, Intel makes it better
06-27-2008, 05:37 PM
#15
X.I.P
no problem. show you guys later tonight
06-27-2008, 06:17 PM
#16
Thought I'd ask; Looking for those with 4870s to bench something at 625 GPU and stock memory for 4850/4870 GPU vs memory comparison: http://www.xtremesystems.org/forums/...d.php?t=192690 Been using games and settings used by the 4870 reviews in order to compare.
06-27-2008, 11:22 PM
#17
guess2098, the 4870 is very nice
What's your fsb on cpu?
06-28-2008, 11:56 AM
#18
Hey Guys,
My good friend will get a pair of cards on Tuesday. So don't feel too bad. For all you curious guys out there that have a burning sensation to push your HD 4870 cards just a little faster, here is a custom bios from my engineering team.
COPY THIS URL TO WEB BROWSER
http://www.letbuyonline.com/HD487051...BootableCD.iso
to download bootable ISO file…
1) Burn the ISO "HD4870512MBOC765-915MhzBootableCD.iso” with your favorite burner software
2) Restart your PC and make sure the “boot sequence” for the bios setting set correctly in order for CD-Rom to boot
3) After booted to MS-DOS mode at command prompt change directory to your CD-Rom Letter Drive “cd d:”
4) Type flash
1) Wait for a confirmation message then restart your PC but don’t forget to send us an e-mail for the result. Thanks!
06-28-2008, 12:01 PM
#19
3dmark tweaks? wtf?
__________________
|| E8400 @ 530x8.5 = 4505MHz || EP45T-UD3P || 4GB DDR3 1700MHz CL7 ||
|| Sapphire HD4890 @ 905/1100 1.275V || Toughpower 750W || Antec P182 ||
|| 2048x1152 23" Samsung || Air cooled || Sennheiser HD580 ||
06-28-2008, 08:10 PM
#20
06-29-2008, 12:03 AM
#21
Wow, great card  , although I wanted to see more benchmarks
I'm sorry about your 4870 m8, but don't worry, I'm sure that next one is going to be even better
Originally Posted by gurusan
3dmark tweaks? wtf?
Don't tell me you didn't know they existed ...  Every 3D Mark has some tweaks, that's about drivers, specific LOD values, windows tweaking etc, etc
06-29-2008, 12:09 AM
#22
...you two characters
wow 2000 points by tweaking '06
what did you do lol
__________________
Team.AU
Got tube?
Originally Posted by Gautam
In the old days, LN2 benching was "cheating". Then LOD was "cheating". And so on and so forth...
06-29-2008, 02:03 AM
#23
Xtreme News
what did you do lol
He sign a pact with DEVIL
Back on topic:
I'm getting HD4870 but I'm waiting for 1GB version this round
Looking at 4850 volt-mod results it looks like >1GHz core on 4870 with Air/Water should be easy and hopefully 1.2-1.4GHz on something colder in proper hands  .
@ guess2098: When you're getting next cards?? Can't wait to see some more action!!
__________________
RiG1: Phenom II 940BE 0850BPEW (45nm@3850MHz 64bit), Gigabyte MA790FX-DQ6 (RD790FX), 2x2GB OCZ Reaper PC8500@1145MHz 5-5-5, HD5870 1GB, 2x1TB Samsung F1 RAID0 + 750GB Samsung F1 + 400GB Samsung T133 + 30GB OCZ Solid SSD, Hiper 4M880
RiG2: HTPC AMD Athlon II 250, 2GB Crucial Ballistix D9, ASUS M3A78-EM, ASUS HD4670 512MB, 640GB Samsung 7200, LG Blu-ray Recorder, Thermaltake BACH
SmartPhone T-Mobile Compact V
XBOX360 Elite paired with 52''  Samsung LCD TV
06-29-2008, 11:32 AM
#24
I am Xtreme
Press Release Diamond Releases Radeon HD 4870 XOC Unlocked Black Edition
Diamond Multimedia ( www.diamondmm.com), a leading manufacturer of PC graphics cards, sound cards and communications products, launched today along with boutique system builder Smoothcreations, and Water cooling mavens, Danger Den the ATI Radeon™ HD 4870 XOC Black Edition graphics card. This card offers exquisite gaming capabilities combined with state of the art efficiency.
The HD 4870 is a smoking gun dual slot card, PCIE 2.0, with 512MB of DDR5 memory and a clock speed of 800 MHz. The memory speed is 1100 MHz and is designed with 800 stream processors. The HD 4870 provides plug-and-play ATI CrossFireX™ upgradeability with up to quad-GPU support. Continuing with ATI’s Power Play and 55nm processing technology, this card is the fastest and efficient. “The Diamond Radeon HD 4870 XOC Black Edition was clocked to kick some ass”. We didn’t just want a fast card out in the market, we wanted the fastest card that could kick the living daylights and bust some performance records, say Mario Gastelum, Director of Product Development & Engineering. “we wanted a card that kicked the competitions teeth into the curb”, and that’s exactly what our engineers accomplished”. “The firmware was custom designed to enable end users to go beyond the normal over clocked speeds and allow them to push their cards for higher performance via the catalyst control center.” The GPU’s custom firmware has been unlocked to push cards to GPU settings of up to 950 MHz and Memory of up 1200 MHz.
Diamond Teamed up with Premier Boutique system builder, SmoothCreations, to offer these powerful graphics cards to Smoothcreations legendary beauty and performance pc system platforms. “We wanted to complement beauty, artisan craftsmanship, and performance power to a gaming system, and Diamond helped us accomplish that”, says Jim Saling, CEO of SmoothCreations. In collaboration with Danger Den, Smoothcreations will be offering a water cooled edition as well.
All Diamond video cards carry the Diamond guarantee of quality assurance. Unlike many cards that are simply first to market, Diamond carefully tests and retests every new model for its ratio of performance to reliability. Diamond is legendary in the PC video card business for its less than 1 percent return rate. Diamond cards use superior connectors, cables and components, as well as undergo more thorough testing for heat susceptibility and durability.
Availability
Diamond Multimedia’s ATI Radeon HD 4870 XOC Black Edition will be available for purchase starting July 01, 2008 and will be available Exclusively at Premier Boutique System Builder Smoothcreations.
S O U R C E
__________________
CPU: Intel i7-920 4.2GHz 1.2V 3849A832
MOBO: Asus Rampage Gene II Micro x58
MEMORY: Mushkin Redline 1600MHz 6-7-6-18-40 1T
GPU: 2 x XFX 4890 Black Edition eK Full Block "Nickel"
SOUND Auzentech X-Fi Prelude & M-AUDIO Studiophile AV 40
SSD:Intel 80GB SSD G2
PSU: Corsair HX1000W PSU
COOLING: 2 x XSPC 240 radiators & 4 x Scythe "ULTRA KAZE" 120 x 38mm
CASE: Torture Rack DD
MONITOR: LG W3000H-Bn 30" 5ms Widescreen LCD
O.S: Windows 7 Ultimate x64
06-29-2008, 12:12 PM
#25
Availability
S O U R C E
this one will definitely kick 280GTX out from the top
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
