Page 1 of 2 12 LastLast
Results 1 to 25 of 47
Thread: kingduris Build Log
    Dec 2007
    Ohio
    kingduris Build Log
    Hello all!
    I've been working on my computer for about 6 months now and I decided it was time to share it I was working with a TT Armor for a while and after modding it I decided it was huge. I wanted a case that was compact and could fit my rads. I looked at Mountain Mod cases but the smallest one would require my rads to be external. The larger cases were too big for my liking. After all of this I just decided to build my own :p The whole goal is to be able to fit my PA120.3 and my PA120.2 in a small case. I ordered about 10 5052-H32 Aluminum sheets (same stuff MM uses) and a bunch of aluminum angles from here. I had been drawing the plans on paper for a long time when I was bored in school. Then I started to build it on google sketchup. I finally started working with the metal and will be updating my log here. After I finish the case part of the log I will go through the water cooling part Note, I did not copy mountain mods.. this is my own design and hard work, please don't call me a copier or I'll be sad
    Thanks for reading Lets start the build!
    Hm.. heres something to let you think while I upload all the pictures, the cases dimensions are 18"L x 12.75"W x 13.75H
    Dec 2007
    Ohio
    Heres what I'll be using for the side panels, top, bottom etc...they are 24"x24" and im using a band saw from sears with a metal blade for everything...i have a wood shop not a metal shop -_-
    Here are some angles
    This is how they will be screwed in and ill have to miter them.
    Mitered
    Everything is tapped to 6-32 threading
    Thats it for right now, more tomorrow
    6-26-08
    Time to build pump/hd rack
    MM HD Rack
    cut the fan holes off
    Drilled new fan holes
    Drive Rack time :p
    used this as a template
    drilling and a jig saw
    I would have taken a pic with a drive in but i forgot :p i can add it later if wanted
    Side Panels!
    :] 4.5" hole saw
    Front
    Right Side
    Might add this to make it more clean
    Back
    Mobo tray
    Mobo tray cut
    Left side
    Window/top
    clamped some angles to make corner brackets
    Some pics of the case together
    fan :p
    I made a bracket to rest the other end of the mobo tray on for support
    w/acrylic on
    Test fit, sexy huh
    Thats it for now, im sending all the parts of to get powder coated gloss black, before i send it tomorrow is there anything anyone wants to see? If not there will be a lot of case pics when it gets back from the pc's, o yea and here's a peek of the hardware
    Dec 2007
    Ohio
    Look what UPS brought!
    aw yeah
    Nice and shiny!
    Drive faces
    Gotta get rid of that hump
    double sided extra strength ftw
    yay
    I made an acrylic wire shelf that attaches to the mobo tray
    Lets add more parts!
    Dec 2007
    Ohio
    More parts :P
    Need some fans?
    I attched the fans to this so i could solder them together
    All fans sleeved soldered
    Some ram
    Yay
    Mobo
    More to com later
    Dec 2007
    Ohio
    Reserved,
    Oct 2007
    socal
    you really dont need all those reserves.. theres no pic limit per post..
    but looking forwards to a real update
    Dec 2007
    Ohio
    ah lol well i just saw other people doing it so i assumed i better haha
    Banned
    Jun 2006
    in a Red Rage D....
    now this i'd love to see. more pics! more pics!
    Dec 2007
    Ohio
    Update
    Banned
    May 2008
    vermont, yes i like women
    nice man cant wait to see how this turns out! sub'd!
    Never go full retard
    Feb 2008
    Vegas
    Nice...custom made is a great way to go, you can plan everything out, no surprises. Just be sure to factor in cable routing early so you can create the right spots to hide all of those cables (I keep learning this the hard way).
    Sub'd
    Oct 2007
    socal
    now thats a real update! looking good man
    Banned
    Apr 2008
    Brisbane, Australia
    Yummy.
    I would like to try the same one day. Shipping the MM case to Australia starts at $300.
    Dec 2007
    Ohio
    yay replies haha, ill add some more pics right now
    Oct 2007
    socal
    whao you cut those slots out? those look fantastic
    Dec 2007
    Ohio
    drilled a hole on both sides then cut from one to the other and then a lot of filing haha
    Dec 2007
    Ohio
    added the side panels to the pics
  18. #18
    Oct 2007
    socal
    hey those are some great looking panels man, really good job
  19. #19
    Banned
    Jun 2006
    in a Red Rage D....
    very nice updates, this should be finished in a week at the rate you're going...
  20. #20
    May 2008
    VA
    impressive work! your nuts and bolts are really clean
    [ Lian-Li V1000B // EP45-UD3P // E8400 // HD4870 ]
    [ W/C by EK, MIPS, D-tek, Bitspower, Swiftech, XSPC]
    [ Project LucentTide - WORKLOG! ]
  21. #21
    Dec 2007
    Ohio
    thanks for the comments everyone ill be updating again later today
  22. #22
    Jan 2008
    Saudi Arabia
    wow great work man cant wait to see it finished
  23. #23
    I am Xtreme
    Feb 2007
    What I REALLY love about your worklog is that you show us how you do it all including showing the tools. I don't know alot about this stuff but desparately want to learn . . .your thread delivers. Excellent cutting! I am too lazy and would just draw it up and send it to a laser/plasma/or water-cutter shop for the panels if I was doing my own build. My hats off to you talented people who can do this awesome work!!!
  24. #24
    Mar 2007
    Great job so far!
    A small suggestion, order some single-flute countersinks, that is how you can get a super smooth shiny cut on your countersunk holes, even when using a hand drill. Multi-flute countersinks are almost impossible to prevent chatter unless you are on an automatic machine.
    Don't forget to get 82 degree instead of 90 as well, they match the angle of the screw heads.
    Also, kerosene wd-40, or even household oil will greatly increase the lifetime of your taps. (I get lazy and skip cutting oil sometimes but it really gums up your taps with aluminum, reduces their lifetime, and makes an inferior hole finish)
    Quote Originally Posted by DarthBeavis View Post
    I agree, I actually do a good bit of sheetmetal fabrication as part of my day job, and although attention to detail definitely comes into play, most of ability comes from access to the correct tools, and knowledge of their use.
    Not everyone has access to some of the stuff that I do, but a lot can be done with basic hand tools, albeit not as quickly/easily.
    I will be posting a worklog for my OCN case mod comp entry here in the W/C forum on July 1st when our worklogs go public, I've done a lot of sheetmetal work on the log and will be posting pics of the tools I use, and making a list of "must-have" professional tools that are within reasonable financial reach of your average modder.
    Asus G73- i7-740QM, Mobility 5870, 6Gb DDR3-1333, OCZ Vertex II 90Gb
  25. #25
    Dec 2007
    Ohio
    Thanks for all the compliments and thank you for the tips iandh
