Taipei, Taiwan, 16 June, 2008
G.Skill International Co. Ltd., a world leader in memory revolution, is unveiling today its PI-8800 with 4GB or 8GB of capacity. PI memory series especially designed for extreme speeds demander, provide stable and long-term performances. The elaborate heat spreader enables PI-8800 operating under 1.8 to 1.9 voltages. PI-8800 4GB or 8GB memories provide unique stability and long-term performance for ultimate memory users.
The Biggest Capacity of PC2-8800
The PC2-8800 PI modules are optimum for the latest cutting edge platforms and will be available in high-capacity 4GB(2GBx2) dual channel and 8GB (2GBx4) four channel kits. Not only for gaming but also for Photoshop or CAD applications, PI PC2-8800 is all you need.
Unbelievable Low voltage 1.8 to 1.9
With high performance, systems will continue spreading heats and also using over 2 voltages power. PI-8800 provides you alternative solutions but also with rock-solid performances in the market place yet.
Looks nice no ?![ P I ] G.SKILL DDR2 PC2 8800 (8 Layers PCB) 4GB/8GB kit
Specification
Main Board: intel or amd
System : Desktop
System Type : DDR2
M/B Chipset :
- Intel X48
- Intel P45
- Intel X38
- Intel P35
- nVidia n6xx I (For Intel series)
- nVidia n7xx I (For Intel series)
CAS_Latency : 5-5-5-15
Capacity : 4GB (2GB x 2), 8GB (2GB x 4)
Speed : DDR2-1100 (PC2-8800)
Test_Voltage : 1.8 ~ 1.9 Volts
PCB : 8 Layers PCB
Registered/Unbuffered : Unbuffered
Error_Checking : Non-ECC
Type : 240pin DIMM
Warranty : Lifetime
F2-8800CL5D-4GBPI
F2-8800CL5Q-8GBPI![]()
Any tests yet ?
