XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > Intel
Reply
Old 06-21-2008, 04:18 AM   #1
SeLecT
SeLecT's Avatar
DFI LANparty DK P45-T2RS/T3RS (Intel P45) - News|Info|Results
DFI LANparty DK P45-T2RS/T3RS / Plus(Intel P45)
Content of the thread
  • General informations
  • Impressions
  • Specifications
  • The bios
  • Downloads
  • Important Informations
  • Results
  • compatible memory & coolers
  • Important links
After the P35 Board of the DK-Family, the P45 Boards is now available and this is the official thread for the board. I have this board at home and i will give you results und screens. This thread isn't final.
So guys, buy this board and test it
Impressions
(Bilder von patrock84 und meiner Wenigkeit)
Specifications
  • CPU
    • LGA 775 socket for:
      - Intel® Core2 Quad and Intel® Core2 Duo
    • Supports Intel Enhanced Memory 64 Technology (EMT64T)
    • Supports Enhanced Intel SpeedStep Technology (EIST)
    • Supports Intel Hyper-Threading Technology
    • Supports 1333/1066/800MHz FSB
  • Intel® chipset
    • Intel® chipset
      - Northbridge:
      Intel® P45 Express chipset
      Intel® Fast Memory Access technology
      - Southbridge: Intel® ICH10R
  • Memory
    • Four 240-pin DDR2 DIMM sockets
    • Supports DDR2 667/800 MHz
    • Delivers up to 12.8Gb/s bandwidth
    • Supports dual channel (128-bit wide) memory interface
    • Supports up to 8GB system memory
    • Supports unbuffered x8 and x16 DIMMs
  • Expansion Slots
    • 2 PCI Express (Gen 2) x16 slots - 2-way CrossFire: One slot operating at x16 (16-lane port) or two slots each operating at x8 (8-lane ports) bandwidth
    • 2 PCI Express x1 slots
    • 2 PCI slots
  • BIOS
    • Award BIOS
    • 8Mbit SPI flash BIOS
    • CMOS Reloaded
  • Audio
    • Realtek ALC885 High Definition audio CODEC
    • 8-channel audio output
    • DAC SNR/ADC SNR of 106dB/101dB
    • Full-rate lossless content protection technology
    • Optical S/PDIF-out and coaxial RCA S/PDIF-out interfaces
  • LAN
    • Marvell 88E8053 PCIE Gigabit LAN controller
    • Fully compliant to IEEE 802.3 (10BASE-T), 802.3u (100BASE-TX) and 802.3ab (1000BASE-T) standards
  • IDE
    • JMicron JMB368 PCI Express to PATA host controller
    • Supports up to 2 UltraDMA 33/66/100Mbps IDE devices
  • Serial ATA with RAID
    • Intel Matrix Storage technology
    • Supports up to 6 SATA devices
    • SATA speed up to 3Gb/s
    • RAID 0, RAID 1, RAID 0+1 and RAID 5
  • Rear Panel I/O Ports
    • 1 mini-DIN-6 PS/2 mouse port
    • 1 mini-DIN-6 PS/2 keyboard port
    • 1 optical S/PDIF-out port
    • 1 coaxial RCA S/PDIF-out port
    • 6 USB 2.0/1.1 ports
    • 1 RJ45 LAN port
    • Center/subwoofer, rear R/L and side R/L jacks
    • Line-in, line-out (front R/L) and mic-in jacks
  • Power Management
    • ACPI and OS Directed Power Management
    • ACPI STR (Suspend to RAM) function
    • Wake-On-PS/2 Keyboard/Mouse
    • Wake-On-USB Keyboard/Mouse
    • Wake-On-LAN
    • Wake-On-Ring
    • RTC timer to power-on the system
    • AC power failure recovery
  • Hardware Monitor
    • Monitors CPU/system/Northbridge temperature and overheat alarm
    • Monitors Vcore/Vdimm/Vnb/VCC5/12V/V5sb/Vbat voltages
    • Monitors the speed of the cooling fans
    • CPU Overheat Protection function monitors CPU temperature and fan during system boot-up - automatic shutdown upon system overheat
  • PCB
    • 4 layers, ATX form factor
    • 24.5cm (9.64") x 30.5cm (12")
The bios - !press F9 for more settings!
Downloads
Important nformations
Zum Non-Plus:
The nonplus version is not as good as the plus version vor overclocking. If you want to buy the DFI, then buy the plus version. Most of the overclocking results are reached on the plus version.
F9 for more memorysettings in bios
Zum DFI DK Plus:
p45 normal and p45 plus both have chipset A2 revision and A1 motherboard revision as of NOW. Difference between the normal and the plus is the additional 2 SATA ports and also the double boot after saving bios has been resolved for the P45 plus.
Results
compatible memory & coolers[/hr]
Aircooling:
Noctua U12P
TR Ultra 120 True Black / Extreme
Scythe Mine
Thermalright HR-01 Plus
Water-cooling NB-SB-Mosfets:
EK-Mosfet DFI DK - Acetal
Watercool Kühler
NB/SB by Anfitec - Pictures: Klick
Spawa by Anfitec
(Now at pc-icebox.de zu haben)
Memory:
Memory for overclocking
  • Crucial Ballistix Tracer PC8500 1066MHz BL12864AL1065.8FE5
  • takeMS Mach2 2GB PC2-8500U CL5-5-5-18 TMS1GB264C082-105EP
  • Corsair XMS2 Dominator 2GB PC2-8500U CL5-5-5-15 TWIN2X2048-8500C5D
  • OCZ Reaper HPC Edition Kit 2GB PC2-9200U CL5-5-5-18 OCZ2RPR11502GK
  • OCZ Reaper HPC Edition 2GB Kit PC2-9600 CL5-5-5-18 OCZ2RPR12002GK
  • OCZ Flex II 4GB Kit PC2-9200 CL5-5-5-18 OCZ2FXT11504GK
  • TeamGroup Xtreem Dark 4GB Kit PC2-8500U CL5-5-5-15 TXDD4096M1066HC5DC-D
  • Chaintech Apogee GT DIMM Kit 4GB PC2-8500U CL5-5-5-15
  • Kingston HyperX DIMM Kit 4GB PC2-6400U CL5-5-5-15 (DDR2-800) (KHX6400D2K2/4G)
  • Cellshock DIMM Kit 2GB PC2-8500U CL5-5-5-15 (DDR2-1066) (CS2221550)
  • G.Skill Kit 4GB PC2-8000U CL5-5-5-15 (DDR2-1000) (F2-8000CL5D-4GBPQ)
  • G.Skill Kit 4GB PC2-8800U CL5-5-5-15 (DDR2-1100) (F2-8800CL5D-4GBPI)
  • G.Skill Kit 4GB PC2-6400U CL5-5-5-15 (DDR2-800) (F2-6400CL5D-4GBPQ)
  • Chaintech Apogee GT Kit 4GB PC2-9200U CL5-5-5-15
  • Crucial Ballistix Tracer PC6400 2*1 GB BL12864AL804.16FD3
vDroop-Mod
Here the vDroop-Mod. I made it with 20 kOhm VR. I think 10 kOhm should be work too.
Results:
Without Mod, R = 2,22 kOhm: 1,395 V / 1,385 V
With Mod, R = 1,37 kOhm: 1,400 V / 1,395 V (The poti is set at ca. 4 kOhm)
Measurepoints DFI LANparty DK P45-T2RS / Plus
Messgerät : Voltcraft VC-531 Ampere Zange + Multimeter ( NP : 75 € )
Real Volt - Messung at Windows @ IDLE....with a Q9550 E0 @ FSB 500 @ 4255 Mhz
CPU PLL ( Bios 1.55v.) ......Real : 1.578v...........Droop : + ~ 0.03v.
NB Core ( Bios 1.420v.) .....Real : 1.420v...........Droop : nichts
VDIMM ( Bios 2.218v. ) .....Real : 2.245v. .........Droop : + ~ 0.03v.
VTT ( Bios 1.280v. ) .......Real : 1.298v. ..........Droop : + ~ 0.02v.
Heatpipe Mod :
Important links
__________________
SeLecT is offline   Reply With Quote
Old 06-21-2008, 04:19 AM   #2
SeLecT
SeLecT's Avatar
The boards works, but i have an great problem....
I could'nt reach more than FSB 400Mhz. The maximum was 430Mhz, but it wasn't stable. 500Mhz is impossilbe
Do you have some same experiences?
__________________
Old 06-21-2008, 04:22 AM   #3
Achill3uS
OCTeamHungary™
Achill3uS's Avatar
nice mobo but 4 phase design (or correct me if im blind ) is really poor nowdays im curious to the digit pwm LanParty UT edition, dont you have any info about it? btw nice thread, let's fill it
Achill3uS is offline   Reply With Quote
Old 06-21-2008, 04:23 AM   #4
Peter Burg
Peter Burg's Avatar
Send a message via ICQ to Peter Burg Send a message via MSN to Peter Burg Send a message via Skype™ to Peter Burg
Let's wait for the people to get the boards. I think you're one of the first, so be patient. And fore sure it's the first release of the BIOS
Peter Burg is offline   Reply With Quote
Old 06-21-2008, 04:31 AM   #5
patrock84
Actually i have problems with FSB above 400MHz..
CPU: E8400 or 8200 , same results..
patrock84 is offline   Reply With Quote
Old 06-21-2008, 04:35 AM   #6
Peter Burg
Peter Burg's Avatar
Let's wait for a new BIOS
Old 06-21-2008, 04:37 AM   #7
SeLecT
SeLecT's Avatar
For a dualcore it is ok i think
The UT version will have some digital pwm.
Yeah, i know. i have send a mail to DFi....
Waiting for some other people!
Originally Posted by patrock84 View Post
]http://www.abload.de/img/dfi001v85.jpg
Hmm, then is this a Biosproblem!
__________________
Old 06-21-2008, 04:41 AM   #8
Peter Burg
Peter Burg's Avatar
Du ich bin Yidaki nur es war schon vergeben :fresse:
Old 06-21-2008, 04:42 AM   #9
nzbleach
nzbleach's Avatar
nice, all the connectors are pretty much placed perfectly. No removable bios chip though -p
__________________
i7 920 | Asus Rampage II gene | 6GB ocz Blade | 4870x2
nzbleach is offline   Reply With Quote
Old 06-21-2008, 05:03 AM   #10
Kean
Kean's Avatar
There will be UT P45 ddr2?
__________________
Intel Inside
Originally Posted by AndreYang
who care winrar benchmark in the world? lol
Kean is offline   Reply With Quote
Old 06-21-2008, 05:06 AM   #11
SeLecT
SeLecT's Avatar
I think so - http://www.hpm-computer.de/product_i...-P45-T2RS.html
__________________
Old 06-21-2008, 07:51 AM   #12
Sem
i hope there is a DDR2 P45 UT
i know that shop lists it but on the DFI schedule posted in the first post there is only a DDR3 P45 UT
Sem is offline   Reply With Quote
Old 06-22-2008, 01:56 AM   #13
SeLecT
SeLecT's Avatar
Hm, you're right! Lets hope for the board!
And i hope for an new bios!
__________________
Old 06-22-2008, 02:04 AM   #14
Kean
Kean's Avatar
On schedule in first post, there isn't JR version. So, let's hope there will be UT DDR2 ver.
JR look like this:
__________________
Intel Inside
Old 06-22-2008, 03:56 AM   #15
graysky
What kind of NB Vcore and NB temps are required to run @ 400 MHz?
__________________
graysky is offline   Reply With Quote
Old 06-22-2008, 04:22 AM   #16
SeLecT
SeLecT's Avatar
I don't know, because the 400Mhz are not stable... I hope a new bios will fix all these problems! If not, i will sell this board...
PS: Bios screens added!
__________________
Old 06-22-2008, 05:08 AM   #17
alex17 GTX
alex17 GTX's Avatar
Send a message via Yahoo to alex17 GTX
Why so few Dram options? This must be an alpha beta whatever early bios... Also.. I though this board was scheduled for middle july...
__________________
E8400 Q746A| 2Gb Gskill Micron D9GMH | DFI LanParty P35 DK T2R/S | Sapphire X1950PRO | Antec Nine Hundred | Tuniq Tower |
/ E8400 @ 4752 @ 1.664v/ AIR / 9.734 spi /
/ G.Skill @ 1200 4-4-4-9 @ 2.52v /
/ G.Skill @ 900 3-3-3-3 @ 2.45v /
// Smart Guardian Skin DFI LanParty DK P35 //
alex17 GTX is offline   Reply With Quote
Old 06-22-2008, 06:02 AM   #18
SeLecT
SeLecT's Avatar
Here a biosscreen from the DK P35 - it has a little bit more dram options
http://www.abload.de/image.php?img=s...800x600c2i.jpg
__________________
Old 06-22-2008, 06:26 AM   #19
alex17 GTX
alex17 GTX's Avatar
I know that! (my rig). And that can't be true. I really hope they release a new bios fast.
__________________
Old 06-22-2008, 11:06 PM   #20
SeLecT
SeLecT's Avatar
DFI USA answered me and in the USA they don't sell this board or have an sample of it...
So a mail to Taiwan is out...
__________________
Old 06-24-2008, 08:12 AM   #21
NupSiHoVa
Hi SeLecT,
I just recieved the Mobo, might wanna hook it up tonight. I dearly hope it doesn't have the same issues as yours.....but more unlikely i think it will.
NupSiHoVa is offline   Reply With Quote
Old 06-24-2008, 08:21 AM   #22
emoners
emoners's Avatar
JR look like this:
really? i was kinda waiting for the P45 JR for my mATX rig
__________________
Project B.I.L.H.A.T.: ZOTAC® GeForce™ 9300-ITX WiFi Rev.01 (+ Noctua® NC-U6) | Intel® Core2Duo™ E7400 Wolfdale SLB9Y (+ Scythe® Shuriken™) @stock voltages | OCZ® NVidia SLI-Ready DDR2-6400 2x2Gb | PowerColor® ATI™ Radeon HD4770 | Western Digital® Caviar™ Black 1Tb | Silverstone® SG05 | Windows® 7 Ultimate 32-bit
RETIRED:
• DFI® LanParty UT P35-T2R Rev A02 (05/21 Bios) | DFI® LanParty JR P45-T2RS Rev A03 (10/07 Bios) | Intel® D945GCLF2 Little Falls-2 | Intel® Core2Duo E6850 Conroe L723A348 | Intel® Core2Duo E8400 Wolfdale Q746A446 | Intel® Core2Quad Q6600 Kentsfield L723B837 | Intel® ATOM™ 330 | XFX® NVidia GeForce 8800GTX | XFX® NVidia™ 8800GT XT Alpha Dog Edition | Creative® Sound Blaster X-Fi Fatal1ty XtremeGamer Pro
emoners is online now   Reply With Quote
Old 06-24-2008, 08:47 AM   #23
mrcape
mrcape's Avatar
DFI-LP-Jr-P45-T3RS
mrcape is offline   Reply With Quote
Old 06-24-2008, 08:52 AM   #24
CarvedInside
CarvedInside's Avatar
Been waiting for this board. I think this mobo isn't officially lauched yet. Here in Romania you can find it listed , but they don't have it in stock , so it looks like I'll have to wait a bit more. Hope by the time it gets here, dfi engineers will fix the damn bios.
Any comments on the package, build quality, northbridge cooler?
CarvedInside is offline   Reply With Quote
Old 06-24-2008, 10:17 AM   #25
SeLecT
SeLecT's Avatar
The NDA falls on 30th of june... so you are right, that the board isn't offiicial yet.
I will take some photos of the package soon.
__________________
Reply
Tags
dfi dk p45, dfi jr p45
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
