XtremeSystems Forums
Go Back   XtremeSystems Forums > Official Manufacturer Information & Support > Foxconn - Quantum Force > Guides, Tweaks and FAQs
Reply
Old 06-20-2008, 05:41 AM   #1
saaya
Xtreme X.I.P.
saaya's Avatar
Send a message via MSN to saaya Send a message via Yahoo to saaya
BIOS Flash Guide
In case you run into problems updating your BIOS here are some tips
There are several ways to update the BIOS, from a floppy, usb stick or from within windows.
You can download the latest BIOSes here (official) and here (beta)
You need to register and log in to be able to download from the quantum force site, registering takes only a minute and doesnt require email verification, so you can log in and download immediatly.
FLOPPY
you need to create a bootable floppy disk, id recommend you a windows 98SE boot disk.
You can get loads of different tools that format and then create a bootable floppy on www.bootdisk.com
Then place the flash tool and BIOS image onto the same or another floppy and boot the pc and then follow the flash tools instructions
USB
Backup all data from the UBS stick and then format it to FAT16 or FAT32.
Download this HP tool here to make your USB stick bootable. Put the BIOS and Award files on the USB stick and plug it in any of the USB Slots. Power on the System and select to boot from HDD (!) and then select the HDD Bootup list where your USB stick should show up now. Make sure its no1 in the list and then hit Exit and Save. The Board should now boot from the USB stick and show you the DOS command prompt. From here is the same as updating the BIOS from a floppy.
WINDOWS
updating the bios from within windows is the easiest way. Install the FOX Live Update utility from the CD that comes with the board, then update the utility if necessary and backup/flash the Main and Backup BIOS's with the file above.
Please Note: Main=BIOS1 and Backup=BIOS2 (thanks to ric9887 for pointing this out)
Please make sure you are at safe speeds when updating the BIOS, and please load the setup defaults and then save and exit the BIOS after updating it and then configure the settings.
BlackOps Notes:
The blackops has 2 BIOS chips, the default one that the board will boot from is the left one.
If you run into any problems you can change the jumpers to select to boot from the second chip.
The jumpers work like this, from left to right:
jumper position 1 slects BIOS chip 1 (left chip)
jumper position 2 slects BIOS chip 2 (right chip)
jumper position 3 slects BIOS chip 1 (left chip) by default but you can change in bios to select chip2
jumper position 4 slects BIOS chip 2 (right chip) by default but you can change in bios to select chip1
Dreadnought Notes:
The Dreadnought has 2 BIOS chips, the default one that the board will boot from is the top one.
If you run into any problems you can change the jumpers to select to boot from the second chip below the first one.
jumper position 1 slects BIOS chip 1 (top chip)
jumper position 2 slects BIOS chip 2 (bottom chip)
jumper position 3 slects BIOS chip 1 (top chip) by default but you can change in bios to select chip2
jumper position 4 slects BIOS chip 2 (bottom chip) by default but you can change in bios to select chip1
If you have any questions or comments please let me know
__________________
Nvidia: Tesla C2050 and C2070 products (GT300) will retail for $2,499 and $3,999
JHH (Nvidia) sep 2009: The best way to always be the number1 is to have no backup plan link
JHH (Nvidia) nov 2009: Tolerance for failure is important, it puts our employees in a position where they are willing to try new ideas link
Solus Corvus - maybe things would get better if people addressed the content of each others posts instead of trying to discredit each other with insults and poisoning the well. Attack the argument not the person.
Hail Voltage! The Solution to AND Source of all our Hardware Problems
saaya is offline   Reply With Quote
Old 06-20-2008, 07:26 PM   #2
MotF Bane
Xtreme Cruncher
Send a message via AIM to MotF Bane Send a message via MSN to MotF Bane
I have a bootable USB key, but what is that gbdf folder for? Is that what you use to write the new BIOS, the "Ghost" application inside?
MotF Bane is offline   Reply With Quote
Old 06-21-2008, 10:34 PM   #3
saaya
Xtreme X.I.P.
saaya's Avatar
hmmmm, sorry, i dont get what you mean
__________________
Old 06-21-2008, 10:56 PM   #4
MotF Bane
Xtreme Cruncher
Attached - folders, descending. Does Ghost write the new BIOS?
Old 06-22-2008, 12:11 AM   #5
saaya
Xtreme X.I.P.
saaya's Avatar
ahhhh, i see, no, its a part of the hp tool it seems...
i actually havent checked if its necessary to get the usb stick to boot, but id think so...
did you do a virus scan on it?
EDIT: I checked to be sure, the file is safe, i ran several virus scans on it and it passes symantec, antivir and trendmicro
__________________
Old 06-30-2008, 08:48 PM   #6
saaya
Xtreme X.I.P.
saaya's Avatar
i updated the first post and added links to the BIOS download sections and more details about the winflash tool.
please let me know if you have any questions
__________________
Old 07-11-2008, 02:28 AM   #7
HDCHOPPER
eye havent had any problums whatsoever using the in windows live updater (knock on wood)
but every time eye go to use it .. thiers an updated version window that pops up so ya eye go to get the updated version ..and every time it fails no latest version for me
but does it matter any at all ?? the one eye have works great so far
is thier any reason to have the latest version is it important to have ?? am eye missing anything here ?
in my book if it aint broke then dont fix it
__________________
PENT E8400 batch #814A014 ...4.3 at 1.34v~4.7 at 1.45v
FOXCONN MARS
COOLIT Eliminator 7*c idle~27~38*c load $95bucks !
BUFFALO FireStix's ddr2-800 do 1200 eazy at 2.1v
OCZ 2x2 kit pc2 8500 - 1066 @1069 atm
Quattro 1000W
Radeon 2-4850's in crossfire
OCZ Vertex SSD thanks Tony!
ALL PIPED INTO HOUSE AIRCOND ;}
*QUANTUM FORCE* saaya & sham rocks !
*REAL TEMP*
At least you've got some Xtreme software now for working in Xtreme situations! "Unclewebb" rocks !
*MEMSET* Felix rocks !
*SUPER TEC MAN* UncleJimbo rocks !
OVERCLOCKERS MAG..http://www.xtremesystems.org/forums/...d.php?t=197660
HDCHOPPER is offline   Reply With Quote
Old 07-11-2008, 02:42 AM   #8
saaya
Xtreme X.I.P.
saaya's Avatar
heheh, generally yes
but if you want to tweak some more then the latest BIOS might help and give you some extra settings
latest bios for mars hmmm let me check...
and yes, theres some weird problem with some files when using the fox live update, on the blackops i wasnt able to download the new jmicron driver, it always started and then the download was aborted with an error message :/
i already contacted the china guys and will have all files hosted elsewhere until this is fixed.
as soon as its set up i will post the link to the laternative host location
__________________
Old 08-21-2008, 07:24 PM   #9
grungero
grungero's Avatar
Is there a guide to flash a bios without a flash drive or a floppy disk? I'm talking about cd-rom flashing?
__________________
Mobo: Foxconn MARS
Cpu: Wolfdale E8200 C0 @ 4ghz @1.38v w/ TRUE-120 Black
GFX: 8800GT G92 @stock
Memory: Team Extreem 2x1 5-5-5-15 1100ghz @2.11v
Hard Drive: SB 500GB
Optical Drive: LG 22x DVD/RW LS
Case: Lian-Li PC-G7B
Foxconn ROCKS!
grungero is offline   Reply With Quote
Old 09-09-2008, 04:44 AM   #10
saaya
Xtreme X.I.P.
saaya's Avatar
there will be in a few days
hang in tight!
__________________
Old 09-09-2008, 07:37 AM   #11
Xello
Xello's Avatar
Send a message via MSN to Xello
I suggest using the Fox Live Update program, it's really quick and really painless, have used it a good 5 or 6 times now
__________________
TJ07 | Corsair HX1000W | Gigabyte EX58 Extreme | i7 950 @ 4.4ghz | Ek Supreme | Thermochill PA 120.3 | Laing DDC 12v w/ mod plexi top | 3x2gb Corsair XMS3 1600mhz | GTX295 x 2 | Raid 0 300gb Velociraptor x 2 | Razer Lachesis & Lycosa | Win7 HP x64 | fluffy dice.
Xello is offline   Reply With Quote
Old 09-09-2008, 07:48 AM   #12
saaya
Xtreme X.I.P.
saaya's Avatar
yeah, that or a usb stick with a .bat file really works well too.
but i always preferred flashing from windows too...
__________________
Old 09-09-2008, 04:30 PM   #13
grungero
grungero's Avatar
What happens if flashing fails in my mars?
__________________
Mobo: Foxconn MARS
Foxconn ROCKS!
Old 09-09-2008, 05:56 PM   #14
saaya
Xtreme X.I.P.
saaya's Avatar
if its still running, try to flash it again, and dont power it off until you managed to complete it
if its not running, reset cmos and try to boot, then reflash it.
if that doesnt work, contact your local shop and ask them if you can lend a bios chip from a mars board to reflash your own chip, or ask them if they can do it. or let me know and ill send you a new bios chip with a working mars bios on it
__________________
Old 09-10-2008, 03:51 AM   #15
grungero
grungero's Avatar
You can provide that for me? Cool!
__________________
Mobo: Foxconn MARS
Foxconn ROCKS!
Old 09-14-2008, 06:23 AM   #16
saaya
Xtreme X.I.P.
saaya's Avatar
sure
so you need one?
__________________
Old 09-14-2008, 03:53 PM   #17
grungero
grungero's Avatar
sure
so you need one?
No saaya, but in case i'll have some serious trouble, that's the time.
__________________
Mobo: Foxconn MARS
Foxconn ROCKS!
Old 09-17-2008, 11:36 PM   #18
saaya
Xtreme X.I.P.
saaya's Avatar
sure thing, just let me know
__________________
Old 09-18-2008, 04:24 AM   #19
grungero
grungero's Avatar
I've updated my bios to P14 through windows. Glad it's a success!
__________________
Mobo: Foxconn MARS
Foxconn ROCKS!
Old 09-22-2008, 06:22 AM   #20
saaya
Xtreme X.I.P.
saaya's Avatar
good to hear
windows flashing always went fine for me, even at highly oced speeds, but i def recommend clocking the rig down to stable speeds to flash the bios
__________________
Old 09-22-2008, 03:31 PM   #21
grungero
grungero's Avatar
good to hear
I disabled OC for that moment. Just for safety.
__________________
Mobo: Foxconn MARS
Foxconn ROCKS!
Old 01-16-2009, 06:16 AM   #22
matttehman
I have tried the windows flashing method above several times with no luck. No I did not mess up my board or anything I was able to clear CMOS and start over again. But I do not understand why it says "flash was successful, would you like to restart your pc now?" and then when I restart I cannot get a post screen.
When I get home later I am going to try to flash the p13 instead( On p12 right now).
__________________
FragBox:
CPU: Phenom II X4 940 Black edition CACVC AC 0849APAW running at 210x18= 3780mhz.@ 1.34 v
Motherboard: Foxconn Destroyer
Memory: GskiLL Pi Black (4 X 2gb) F2-6400CL4D-4GBPI-B
Graphics: XFX GTX260 Black edition ,EVGA GTX260 SC @ 720/1500/1208
Power: Cooler Master 750w
OS: Windows Vista Ultimate x86
Case: Mountain Mods Ascension CYO
Current WC'ing Loop:
mcp355<mcr320<mcr320<Dtek Fuzion V2<gpu1<xspc restop<mcp355
matttehman is offline   Reply With Quote
Old 02-06-2009, 12:20 AM   #23
saaya
Xtreme X.I.P.
saaya's Avatar
did you select the "clear cmos" and "load setup defaults" option?
did you use the award winflash tool or the foxconn tool?
its normal that you have to clear cmos after a bios update if you dont select the "clear cmos" or "load setup defaults" switch when flashing the bios
__________________
Old 03-10-2009, 11:54 AM   #24
rwoodburn1
Can anyone tell me how to make a bootable cd for vist 64
__________________
Thermaltake Armor+
Foxconn Bloodrage
i7 965
Gskill 2000 7 8 7 2000
Evga gtx295 quad sli
Custom watercooled
Ultra 1600w psu
Velocirapror 300
Vista64
latest vantage 43200
rwoodburn1 is offline   Reply With Quote
Old 03-15-2009, 02:17 AM   #25
InfinityNX
InfinityNX's Avatar
What's the best bios for the blackops to use for overclocking? My PC specs are in my sig
__________________
Project RAE
Intel Q9550 @ 3.4GHZ | Foxconn Blackops X48 | 2x1GB Team Xtreem DDR3 1600mhz | Powercolor Radeon 4870 in Crossfire | 250GB Western Digital 16MB SATA |Corsair HX1000W Modular PSU
Watercooling:
Dtek Fuzion V1 with Quad-Core Insert
Swiftech MCW30
HWLabs GTX II 360
Feser 1/2 ID 3/4 OD UV Blue
Swiftech MCP655
Alphacool 10" Reservoir
InfinityNX is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
