so a few months ago i started hanging out here in the liquid cooling forum and i'm finally ready to go liquid! i needed a new case to fit everything in and was about to buy the tj07 but then i found out about the lian li pc-a77 which seemed pretty nice so i decided on that (had to wait over a month for it though). anyway, i havent gotten too far yet but i thought i'd start since i have questions. i dont have any previous experience with water cooling and case modding so this won't turn out anywhere near as nice as some of the awesome builds out there (especially knet's pc-a77 build), but ill do my best..
Code:SYSTEM: intel qx9650 evga 790i ultra 2x2gb gskill ddr3 1600mhz 2x evga gtx280 tagan bz1100w psu 2x wd raptor 150gb (raid 0) 1x wd caviar 500gb lian li pc-a77 avertv pcie combo tuner vista ultimate x64Code:WC PARTS: Radiator 1: Thermochill PA120.2 Radiator 2: Thermochill PA120.3 Radiator 1 Fans: 2x Yate Loon D12SM 120mm for PA120.2 Radiator 2 Fans: 3x Yate Loon D12SM 120mm for PA120.3 Pump 1: DDC3.2 12V 18w w/ XSPC Reservoir Top Pump 2: DDC3.2 12V 18w w/ XSPC Reservoir Top Res Adapter: 2x M20x1.5 to G1/4” Reservoir Fill Cap Adapter http://www.aqua-pcs.co.uk/m20x15-to-...ter-1351-p.asp CPU Block: XSPC Edge Acrylic http://www.aqua-pcs.co.uk/new-xspc-e...lic-1344-p.asp NB Block: ViperJohn 790i NB/SPP Block SB Block: EK NB/SB 6 - Acetal GPU Block: 2x D-Tek Fuzion GFX 2 w/ Unisink Barbs: All DD Fat Boy Fittings 1/2" OD Barb Adapters: McMaster G3/8 to G1/4 Adapters (for Fat Boys on radiators) http://www.mcmaster.com/nav/enter.as...657&pagenum=29 Coolant: Distilled Water + PT Nuke Tubing: Feser Tube Active UV Hose 1/2ID 3/4OD http://www.performance-pcs.com/catal...ducts_id=23370 Clamps: Breeze Miniature Hose Clamp http://www.sidewindercomputers.com/brmihocl7int1.html Fill Port: 2x Danger Den Acetal 1" http://www.sidewindercomputers.com/dadendefi.html - i was hoping to mount these at the top of the case but theres no space so i'll have to keep them inside Chilled PC - Anodised 120.3 Rad Grill with Mounting Holes (fits thermochill rads only) http://www.jab-tech.com/Chilled-PC-A...s-pr-4127.html 2x AC Ryan Twin Overboost Dual 12" CCFL Light UV http://www.performance-pcs.com/catal...ducts_id=20529a few questions i had:Code:LOOPS: loop 1: ddc->PA120.2->CPU->NB loop 2: ddc->GPU1->GPU2->PA120.3
1. given the layout below, there is only one 120mm exhaust at the back. should i make the top rad fans pull air out from the case?
2. any other suggestions/problems with the general layout?
