06-10-2008, 01:10 AM
#2
Memory Addict
wow nice.. 880Mhz 7-5-4-14 1T
voltages used ?
06-10-2008, 01:16 AM
#3
k|ngp|n/Sham my brothers
My CellShock rams always works at 2.28Volts
VNorth = 1.594Volts
VFSB = 1.4Volts (real)
VPLL = 1.5Volts
06-10-2008, 01:30 AM
#4
Moderator
Wonderful settings Georgie... I always like to see timings tight as these, but you have the High FSB to bundle with it too so that is one of the nicest performance settings I've seen one run on an X48!
06-10-2008, 01:43 AM
#5
Xtreme X.I.P
very nice FSB and tight ram timings hipro
06-10-2008, 02:37 AM
#6
06-10-2008, 02:47 AM
#7
Vey nice Hipro, but the FSB looks like normal FSB for X38 or P35 boards, nothing special about that, except that it is on a BlackOPS X48 and many had problems with those. Still seems that BlackOPS is meant to be used with QX-es, not Wolfdales. However...rams are killers
Anyway, thank you for this great guide on DualCores and BlackOPS, I am sure a lot of guys will find these settings very useful and it will help a lot of people
__________________
Weissbier - breakfast of champions
06-10-2008, 02:52 AM
#8
"Xtreme pwnage"
Sorry, I have to answer the question;
Yes, I have seen tighter timings, and on DDR3
__________________
I KNOW MASSMAN!
Competition ranking;
2008; AOCM II, Minfeld/Germany #2 @ 01SE/AM3/8M
2009; AMD-OC, Viborg/Denmark #2 @ max freq Gigabyte TweaKING, Paris/France #4 @ 32M/01SE
2010: Gigabyte P55, Hamburg/Germany #6 @ wprime 1024/SPI 1M AOCM III, Minfeld/Germany #6 @ 01SE/AM3/1M/8M
06-10-2008, 02:55 AM
#9
Seems that you've found your way with this mobo
Glad to see you ain't experiencing the problems many others have had
#10
BlackOps makes steps these days, so we'd better be patience with them.....They give bioses every day with fixes and they make HUGE steps each time with them.....
This mobo HAS FSB but it lucks with the dividers (1:3 and 1:3.2)...Now we have started to see some nice things going on and I'm SURE that in the end it will be a blast for E8xxx CPUs as well....
06-10-2008, 02:56 AM
#11
a statistic
So, you reached 580MHz FSB cpu-z screen stable, and 550MHz 1M stable ... great!
But ... at what FSB is it 32M stable? Is the board completely unmodified? More importantly: could you make a similar thread that does not start with offensive words? Do you have a really good retail board, or can 50% of all boards do this? How good is that E8400 in combination with other boards?
__________________
Contact me at HWBOT forums
2008 - MOA EU #5
2009 - MOA Benelux #2 || GOOC Benelux/DACH #1 || GOOC EU #1 || GOOC WW #4 || Tweaking #1 (2/2) || AROS #QF
2010 - P55 OC Challenge EU #7 || MOA Benelux #1 || MOA EU #4 || GOOC EU #1
06-10-2008, 02:57 AM
#12
....grrrrrrr......
06-10-2008, 03:02 AM
#13
Xtreme X.I.P
For High fsb clock , did you try CPU SKEW to 150 and less VTT voltage than 1.5v ?
06-10-2008, 03:03 AM
#14
06-10-2008, 03:04 AM
#15
George....I know what you mean, and we all appreciate their effort. But you know that Wolfdale FSB is limited by X48, just like X38 did, no matter what implementation, so this is not a BlackOPS problem, but an Intel problem. However.....maybe a P45 implementation from Foxconn...a new addition to the Quantum Force series.... would solve that problem, I just hope somebody doesn't need to be hipro5 to get >620 FSB on that
*Monstru grins and pets nice monster FSB Commando*
__________________
06-10-2008, 03:05 AM
#16
VTT IS 1.4Volts REAL.....and NOT 1.5Volts as bios shows.....
06-10-2008, 03:09 AM
#17
a statistic
So, this can be reproduced by someone who's not part of (or related to) the QuantumForce group? If so, it's a step in the right direction, definitly  .
By the way, can this board do the same FSB's in combination with multiplier 9?
__________________
2008 - MOA EU #5
06-10-2008, 03:13 AM
#18
IF FOXCONN has sent me a "regular retail" mobo and not a "super dupper" one, then YES ANYONE could do this..... Rams tested though were either CellShocks PC14400 OR GSKILL PC12800 with the Micron D9GTR chips....
multi x9 I have to put it under cold to test it.....
06-10-2008, 03:16 AM
#19
a statistic
__________________
2008 - MOA EU #5
06-10-2008, 04:45 AM
#20
Yap
http://www.xtremesystems.org/forums/...&postcount=299
Nice guide, hipro.
How about 500 fsb with 1:4 266 333 or 400 ?
I cant boot with 500 ant that 1:4 ratio  .
__________________
3Dmark2006 Score Calculator
"Frequency Unlimit -Enabled'' by DFI
06-10-2008, 05:53 AM
#21
Maybe my rams are bad..
I`m using SST ProiectX, binned by MickeyMouse...
I cant boot with your settings hipro, just with 500 , and setfsb to 550  .
__________________
06-10-2008, 06:45 AM
#22
Blackops is very fast this is my configuration......
06-10-2008, 10:41 AM
#23
a statistic
Originally Posted by hipro5
.....as for the others....no comments......
By the way, I reckon you're using the new bios on this board? One that wasn't available about a week, maybe two weeks ago?
__________________
2008 - MOA EU #5
06-10-2008, 11:22 PM
#24
a statistic
No answer? I'd like to know if this 580FSB is also possible with previous bioses or if it's because of this new bios that the 580FSB is possible ...
__________________
2008 - MOA EU #5
06-11-2008, 01:22 AM
#25
OCTeamDenmark Staff
TRULY GREAT HIPR05
Im glad you took the time to show what the board can do so we dont have to listen to anybody bashing it because they are mad because they dident get one for testing purposes but had to buy one.
__________________
OCTeamDenmark.com
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
