right E8600 E0,left E8400 C0
DRAM
CORSAIR Dominator TWIN2X2048-8888C4DF
BIOSTAR TPOWER I45
The lower left of the board
2 x PCI-E X16(Support ATI CrossFire technology, run on X8+X8 speed.)
2 x PCI-E X1
2 x PCI
1 x Floppy
The lower right:
6 X SATAII(ICH10R)
1 x IDE
Power/Reset
The upper right:
4 x DIMM DDR2,667/800/1066
24Pin
The upper left:
IO
2 x eSATA,Marvell 88SE6121
6 x USB 2.0
PCI-E Jump
P45
BIOS
O.N.E
CPU 100~800Mhz
DDR2 667/800/833/1000/1110/1333
MEMORY TEST
DRAM
Clock Gen
CPU Voltage -0.200~+1.300V
DDR Voltage +0.05~+1.850V
Chipset Voltage +0.025~+0.700V
FSB Voltage +0.025~+0.750V
CPU PLL Voltage 1.5~1.8V
CPU
Hardware Health
The test bed
CPU: INTEL Core 2 Duo E8400/E8600 & Quad Q6600/QX9650
MB: BIOSTAR TPOWER I45
DRAM: CORSAIR Dominator TWIN2X2048-8888C4DF
VGA: GAINWARD BLISS 9800GTX 512MB
HD: Seagate 7200.10 320G
POWER: Corsair HX620W Modular Power Supply
Cooler: Thermaltake BigTyp VP
TPOWER2
E8600
CPU/DRAM=>500/1200
4000Mhz,1232V,2 x SP2004
CPU/DRAM=>500/1200
4500Mhz,1.416V,2 x SUPER PI 32M
471.5X10=>4715Mhz,1.484V
SUPER PI 8M+CPUMARK99
DRAM
500/1200 CL5 5-5-15,2.320V
2 x SP2004 BLEND
DDR2 1200 CL4 4-4-9
EVEREST
DDR2 1272 CL5 5-5-15
EVEREST
E8600 E0+BIOSTAR P45 about 580~590Mhz
use E8400 for test
606Mhz SUPER PI 4M
612Mhz SUPER PI 1M
BIOSTAR TPOWER I45
Performance ★★★★★★★★★☆
Component use ★★★★★★★★☆☆
Appearance ★★★★★★★☆☆☆
C/P ratio ★★★★★★★★★☆
Update 6/16
CPU: INTEL Core 2 Duo E8400 & Quad QX9650
HD: WD 6400AAKS 640GB
E8400
618.6Mhz Super PI 8M
624.3Mhz Super PI 1M
CPU-Z 625.55Mhz
http://valid.x86-secret.com/show_oc.php?id=374787
QX9650 500Mhz 4XSuper PI 32M
517Mhz Super PI 1M
Biostar TPOWER I45 about 160~170 USD
thanks![]()
