to the same voltage as a 3870x2 and if so how?
Processor: Intel 2500K 4.4ghz
Motherboard:Asus Sabertooth P67
Cooling: Prolimatech Megahalem 3x120mm fans 2x Icages, 2x92 mm fans, 140mm PSU fan
Memory: Mushkin Redline (4 x 2GB) 240-Pin DDR3 SDRAM DDR3 1666 6 8 6 24 t1
Video Card:Asus Matrix GTX 580 1.5GB
Harddisk: Wester Digital Black Edition 32MB 7200 RPM 1TB SATA 3.0 ,CAVALIER SE 16MB 640GB SATA 3.0 DRIVE
CD/DVD Drive: 1 BLACK LG LIGHT-SCRIBE DVD BURNERS
CRT/LCD Model: BLACK ASUS 25 INCH MONITOR 50000 TO 1 RATIO 1920x 1080P
Case: Thermaltake Armor Series VA8003BWS Black Full Tower Case solid side panel.
Sound Card: Sound Blaster Live 24 Bit 7.1
PSU: Thermaltake Xt 850 watt SLI 140mm silent fan
Software Windows Vista Ultimate 64
Post it here, please?
dx58so
w3520@4100
4x1gb corsair ddr3-1333
gtx 295
TR ultra-x, 2 scythe ultrakaze push/pull
xclio stablepower 1000
vista ultimate
[SIGPIC][/SIGPIC]
would you crunch if you thought it would save her life?
maybe it will!
do you guys know where these can be found in the us? Have they even gone on sale yet?
As Los Alamos director J. Robert Oppenheimer watched the demonstration, he later said that a line from the Hindu scripture the Bhagavad Gita came to mind:
"I am become Death, the destroyer of worlds."
Test director Kenneth Bainbridge in turn said to Oppenheimer, "Now we are all sons of b**ches." wiki
Newegg has them for 334.99 plus a 30 rebate
I haven't really seen many reviews of this card. Asus sent me one a while back but i never got to using it. It's still wrapped in the box. I think I might use it in my shuttle![]()
I7 920 D0 4.2GHz 1.29v || EVGA Classified 760|| Crossfire ATI Radeon 5870 || G.Skill Ripjaws 12GB DDR3 2000 || Thermaltake 1.2KW PSU || Corsair 800D || Windows 7 Pro x64 ![]()
Step 1-getting ahold of your BIOS
Get a copy of your BIOS off of your VGA card, you can do this using ATiWinflash available hereStep 2-Moding your BIOS
To do so get ATiWinflash running select "Save"
Then save the BIOS as something simple like cardname_stock or oc_BIOS.rom
Now modify your BIOS thru RBE BIOS editor available here
Start by loading the image (load button is in the bottom left corner)
now you should have a screen like this:
notice how its has a checkmark in the box labeled pre-modified by RBE thats because i already modded this BIOS to 700/900 to do that select the "clock settings" tab
now if you want to improve your 3D clocks change the settings in the State 2 - mode 3 - "high 3D" column. Set this to your max stable clocks. Mine are currently 700/900 due to lack of power 2x3850s on a 500w Tt is a no go
if you want to adjust the volts and increase them for this card go to the voltages (still in the same column) now you want to set this to 1.327
Step 3-saving your BIOS
Now to save you will simply have to select save in the bottom left corner
To name it i recommend something like cardname_OC_clock speeds-volts.rom
Step 4-flashing your BIOS
To do this go back into AtiWinflash and select "load image"
select the BIOS you just modified, check to make sure the correct card is select and click program
once its done you will get this screen hit ok the click yes or no to restart
Step 5-repeat
repeat for as many cards as you have
thanks for that link crazy!
What a deal, there down to 304 after rebate!!!! (and they have the aftemarket asus heatpipe cooling)
I knew i should have held out on my 8800gts 512....
So are these just lower binned 3870x2's? (sorry for asking so many questions)
Ya know I threw this card into my backup rig (shuttle system) and it wasn't loud at all so maybe you just got a defective one.
I also contacted some of my friends at Anand, HardOcp and VR-Zone that got the card from asus also and they had no complaints about the fan noise either.
for me it was the fan engine noise. Also how could you possible fit a 10.5 inch card in a shuttle case?(not that I don't believe you) Even on the lowest setting it had a screeching buzz coming from the fan engines. It was driving me totally crazy and in a review I just read they said at neoseekers it was loud on the 3850x2 but not on the 3870x2. They were able to turn it down with smart doctor. I turned it down and it still had horrible engine noise. Also if you look on neweggs web sit the 3870x2 with that same fan has several complaints about how loud the fan is.
My bad i should've mentioned that I had to mess around and move a few things to get it to fit properly. I also cut the side panel up for the fans to get fresh air.
In regards to the loudness of the fans I guess it really comes down to everyone's POV on how loud is loud. I kinda have a high tolerance for fan noise so it can be just that.
