Results 1 to 15 of 15
Thread: My First Watercooling Project - Asus Striker II Formula
    Jan 2008
    Slovakia (Bratislava)
    Hallo i just wanna show you how i installed my watercooling system.
    Most of my project are images couse my engglish is not very good...
    So i hope is gonna be instructive for everybody.I ve spent with that about 10 hours,is really good experience.
    I ve got unbelievable temperature. My MCP has before about 50C during the gaming 60C with two noisy coolers on passiv,now is 30C and during gaming after 3-4hours about 33C...and CPU has in everest ultimate 27C but in real temp has about 10C more.But anyway is really good.
    I tried oc on 4,4 with 1,58V and temp was about 56 after stressing cpu with everest.i would try orthos but doesn t work,i don t know why maybe couse vista 64bit... still stop running.
    i have really bad branch of CPU cause 1,58 in 4,4 GHZ is too much i think...my 24/7 is 4,2 ghz is enough for me i don t wanna break any OC record on this Forum.I m actually satisfied.My pc is silent,cooled and that s make me happy...
    So here it is :
    CPU: Intel C2D 8400 3ghz
    MB: Asus Extreme Striker II Formula
    RAM: CORSAIR DDR2 2x2048MB 1066MHz TWIN2X
    HDD: WD Raptor 150GB ; Seagate Barracuda 7200.11 500GB SATAII VGA: Asus GeForce 8800GT 512mb
    PSU: Seasonic M12 700W
    Case: Cooler Master Cosmos S LCD: Samsung 226CW
    OS: Windows Vista HP 64Bit
    Mouse: MX518 Gaming ; EXACTPAD EP-A1
    HAVE a LOOK ON MY STUFF
    HW Labs Black Ice Xtreme III Triple 120mm Radiator - Black
    Tygon R3603 7/16in. ID 5/8in. Laboratorne Hadice
    Danger Den High Flow Fittings 1/4in to 1/2in
    Swiftech MCRES-MICRO - Expanzka
    Swiftech MCP355 s Delrin DDC Pump Top
    EK-NB S-MAX - Acetal
    EK-SB Striker 2 Formula - Acetal
    EK-Backplate LGA 775
    EK-Supreme - Acetal s Extra mounting plate
    Arctic Cooling MX-2
    Thermalright HR-09S Type 2 Mosfet Cooler
    Thermalright HR-09U Type 2 Mosfet Cooler
    Feser One F1 Cooling Fluid - UV BLUE - 1 Liter
    Oct 2007
    socal
    nice im cooling my striker II as well, looks like you had the same issue. not being able to install a GFX card in the top pci-e slot
    looks pretty good
    Mar 2008
    Netherlands
    thats quite a nice setup you have there
    Intel Q6600 @ 3.6GHz
    Asus Blitz Formula SE
    OCZ ReaperX PC6400 2x2GB
    Sapphire HD4870x2
    X-Fi Elite Pro 7.1 & Logitech Z5500
    Samsung Spinpoint T166 500GB
    Samsung 226BW
    Zalman ZM1000-HP
    Watercooling
    Loop 1: DDC3.2 (XSPC Restop), Fuzion v2, BIGTX360 (6x S-Flex F)
    Loop 2: DDC3.2 (XSPC Restop), EK 4870x2, TFC X360 (3x S-Flex F)
    Loop 3: to come
    [DarthBeavis] "I am gonna try to mod one of these into my wife so can get an early warning of when she gets angry . . ."
    Jan 2008
    i m waiting on new GPU from NVIDIA and after that i m gonna buy high end card and instal that with waterblock..but i have to save some money..in europe is everything more expensive like in america... about 40%
    Banned
    Oct 2006
    Houston, Texas
    Great work. Thanks for all the pictures.
    Is it possible to rotate the radiator so that the barbs are over the CPU end of the case. It may shorten some tubing runs.
    Looks great.
    Sep 2006
    Philippines
    nice build! looks good
    Jan 2008
    Quote Originally Posted by Snyxxx View Post
    Looks great.
    Many thanks to everybody...yeas is possible turn that radiator..but where you wanna put pump after anx reservoir..???...i think this is best choise how i ve made it....
    i looking foward on my new GPU..nvidia GT200 ....
    i hope will be soon avaible...
    Banned
    Oct 2006
    Houston, Texas
    One of my machines has the rad reversed as I mentioned and the pump is at the same location as yours.
    http://www.xtremesystems.org/forums/...1&d=1200373612
    Apr 2008
    Cevo-P
    I run the same coolant...
    Hey UnseenSVK, don't you wish it stayed the same color that it was when you were filling it?
    QX9770 4.0 // HD 4870's Crossfire // DFI X48-T2R // 4GB mushkin DDR2 1066 // 2X Raptor-X RAID-0 // Samsung 1TB
    E8400 4.2 // HD 4850 // XFX 780I SLI // 4GB OCZ DDR2 1066 // 2X Raptor 150 RAID-0 // Samsung 1TB //
    Jun 2007
    Melbourne, Australia
    Nice build UnSeen!
    Quote Originally Posted by HaCKs View Post
    Hey HaCKs, what do you mean by this? Has the blue changed, has it gone transparent/opaque etc? I've seen another build that used feser uv blue; his initial shots showed a bright, slightly opaque blue, but in the more recent pics it looks darker and more transparent.
    Jan 2008
    New Jersey
    When I saw HaCKs' build log, his blue when filling was a bit more cloudy and not as clear as it is in this build. I bet he liked the cloudier, less transparent dye.
    Xtreme Cruncher
    Jul 2007
    @ the computer
    did you really have to take the the mosfet sinks off? or did you just want to use aftermarket coolers for it? i'm guessing since it's attached to the main NB cooler, the SB and mosfet sinks have to come off also?
    Sep 2007
    Mesa, AZ USA
    Very nice build and I'm loving that cosmos s. One thing I did notice that kind of made me cringe.....your motherboard is sitting atop a HUGE static generator!
    The static electricity those clear bubbles produce is enough to kill or degrade sensitive electronic components. Now the pink bubbles are anti-static and ESD safe, same goes for packing peanuts, just an FYI.
    Abit AW9D-Max 975X
    Lapped E6400 @ 3.2GHz
    2gig's Corsair 6400PRO
    HD3870 512 @ 877/1251
    PC P&C Silencer 750 PSU
    Logitech G15 & G5 laser
    NZXT Lexa case
    Water Cooled
    Apr 2008
    California
    Sweet looking, very clean setup! The blue tubing looks really nice.
    I notice you're using what looks like the Noctua NF-P12 on your radiator. I was planning on getting 3 of them for my pa120 and 3 more for case airflow. How do you like them so far? Do they seem to move enough air quietly? @ $20 a pop I'd kind of like to hear from somebody that uses them before I foot the bill for them.
    Apr 2008
    Canada
    Nice build
    What are the model #s for the Mosfet coolers?
    Hor$eman
    Case:Antec 900 PSU:Antec TruePower Quattro 850
    MB:Asus Stiker II Formula CPU:E8400 Wolfdale Q740
    RAM:2 x 1 Gb Patriot Viper PC9600
    VIDEO:SLI EVGA 8800GT SC Akimbo Audio:SoundMax HD 7.1
    HDD:150 Gb WD Raptor @ 10,000 RPM HDD:500 Gb Samsung @ 7200 RPM
    OS:WinXP Pro 32 Bit
    Optical:HP LightScribe DVD 20x
    Keyboard:Logitech G15 Mouse:Razer Lachesis
    Monitor:Acer P241W 24" Widescreen (1920x1200 @ 60 Hz @ 2ms)
    Bench:3DMark06 Pro: 20,491 SuperPi 1M: 11.313s
