Page 1 of 2 12 LastLast
Results 1 to 25 of 26
Thread: AMD X4 Phenom x64 OS Overclock Stablilty Testing/Troubleshooting
    Mar 2008
    Wherever I may roam...
    Many Phenom users are experiencing lesser overclocks and less stability on x64 OS's. This thread is being created to figure out why that is and how to fix the problem(s) so we can .
    I encourage all AMD users to post their experiences with overclocking on x64 systems as not everyone experiences the above problem problems. It is just as important to point what does works as well as what doesn't work. The idea is to get AMD, motherboard manufacturers and M$ to address the issues.
    Intel fanboys/AMD haters: this is the AMD section of the forum and we do not appreciate trolling and flaming. You can state your opinion somewhere else. This is not a vs. thread and we are only dealing with AMD and phenom here.
    I will be installing Windows Vista Ultimate x64 on my system this week and I will post my experiences.
    Thank-you.
    P.S. It would be helpful to post your board and bios, cpu, ram, and other relative hardware so we can compare systems
    Xtreme Mentor
    Apr 2005
    I guess it makes no point for me writing again that there is no "problem" here and that all 64bit AMD processors have lower O/C margin (average 200MHz) under 64bit OS!
    Adobe is working on Flash Player support for 64-bit platforms as part of our ongoing commitment to the cross-platform compatibility of Flash Player. We expect to provide native support for 64-bit platforms in an upcoming release of Flash Player following the release of Flash Player 10.1.
    Jun 2007
    Wayne NJ
    From my point of view its pretty easy to see what the problem is.
    Its most likely the higher cpu/register ALU/FPU utilization of the cores and the caches due to 64bit accsess.
    THATS WHY AMD released the highest phenom with only 2.5GHz because a manufacturer has to make sure that his product is under all circumstances stable. If AMD would have had plans to release a windows 32Bit only processor we would have seen higher clocked phenoms to be released but thats impossible as everybody knows.
    AMD Phenom II 1090T @ 4GHz Asus Crosshair IV
    HD6970
    LSI Megaraid 9260-4i 4xMomentus XT
    OCZ Vertex 3@SB850
    8 gig Patriot Viper 7-7-7-24 T1
    Swiftech Watercooling
    Filco Majestouch 2
    Zowie EC1
    Dec 2007
    I'll start. XP64, DFI LP780FX-M2R, PCPNC 610, GP9850BE, Ninja cool with 3 fans and direct airflow.
    2.78 suicide Max at 1.325V, chicken out on going higher VCore.
    2.71 ran for a while but little problems kept happening with random crashes. Did manage to fold for a while.
    2.65 ran good for longer but still noticed that occasional crash.
    2.6 did better at 1.3V, got worse below that.
    2.5 Stock but 1.29V, the occasional error right after login and a few app crashes.
    2.5 Stock at 1.3V same as above, "maybe" a little less frequent.
    I can run XP64 with a large number of apps at stock but there are these little crashes that haunt you. I looked at the log with several DCOM errors which may be server related. There was one event below that was an actual report of a system error but not much to go on but apparently XP recovers before going down in flames.
    Error code 000000000000003b, parameter1 00000000c0000005, parameter2 fffff80001287f6b, parameter3 fffffadf906222d0, parameter4 0000000000000000.
    Main Win64; Phen940BE, Sunbeam Cooled, DFI LP790FX-M2R, 2x2G Corsair, R3850XT
    Production XP; Athlon 6KBE, GByte POS mobo, 2x2G Gskill 800, R3750XT.
    Vista 64 Test; GP9500, ECS740M, 2x2G GSkill, IGP.
    Server; 4 X 8347 Opterons, 8x1G Kingston.
    XP Home Test; A5000BE X2, ECS RS485M, 2x1G Wintec, IGP.
    S&Gs Test; A5000BE X2, ECS A770M-A, A5800 X2, ECS KA3-MVP-580X, 2x1G ?
    Xtreme Mentor
    Nov 2005
    Devon
    I was the first who started this debate couple of months ago.
    It is true what Nedjo said - EVERY CPU is affected (Intel and AMD). The problem with Phenom (especially B2) is that clock disparity between x32 and x64 is very big for most samples.
    From my experience if your CPU is unstable at a certain frequency under x64 OS try to LOWER vCPU. It worked for me, but you can't gain to much out of this solution. Much better cooling might help as well.
    A lot depends on BIOS support. Gigabyte DQ-6 is a good example. None of my Phenoms could go stable beyond certain frequency and my 9850 for instance would be unstable at around 2700MHz (5 min. stable @2760MHz) on BIOSes up to F4. With new F5c BIOS I can get it absolutely stable @2760MHz default vCore!
    @xPliziT Very good point! I was thinking the same! Only future revisions can change this situation.
    Good luck guys in yours x64 adventures!!
    RiG1: Ryzen 7 1700 @4.0GHz 1.39V, Asus X370 Prime, G.Skill RipJaws 2x8GB 3200MHz CL14 Samsung B-die, TuL Vega 56 Stock, Samsung SS805 100GB SLC SDD (OS Drive) + 512GB Evo 850 SSD (2nd OS Drive) + 3TB Seagate + 1TB Seagate, BeQuiet PowerZone 1000W
    RiG2: HTPC AMD A10-7850K APU, 2x8GB Kingstone HyperX 2400C12, AsRock FM2A88M Extreme4+, 128GB SSD + 640GB Samsung 7200, LG Blu-ray Recorder, Thermaltake BACH, Hiper 4M880 880W PSU
    SmartPhone Samsung Galaxy S7 EDGE
    XBONE paired with 55'' Samsung LED 3D TV
    Feb 2008
    good thread...
    1. ASUS Sabertooth 990fx | FX 8320 || 2. DFI DK 790FXB-M3H5 | X4 810
    8GB Samsung 30nm DDR3-2000 9-10-10-28 || 4GB PSC DDR3-1333 6-7-6-21
    Corsair TX750W | Sapphire 6970 2GB || BeQuiet PurePower 450w | HD 4850
    EK Supreme | AC aquagratix | Laing Pro | MoRa 2 || Aircooled
    Oct 2005
    EvE-Online, Tranquility
    Quote Originally Posted by Lightman View Post
    me. This part pisses me a bit off though. How long has Phenom been around for now and why are the BIOS's still not working like they should. Such a shame.
    Ill try the lower Vcore part, however did you leave Vnb default or did you lowered it with the Vcore as well?
    Synaptic Overflow
    CPU:
    -Intel Core i7 920 3841A522
    --CPU: 4200Mhz| Vcore: +120mV| Uncore: 3200Mhz| VTT: +100mV| Turbo: On| HT: Off
    ---CPU block: EK Supreme Acetal| Radiator: TCF X-Changer 480mm
    Motherboard:
    -Foxconn Bloodrage P06
    --Blck: 200Mhz| QPI: 3600Mhz
    Graphics:
    -Sapphire Radeon HD 4870X2
    --GPU: 750Mhz| GDDR: 900Mhz
    RAM:
    -3x 2GB Mushkin XP3-12800
    --Mhz: 800Mhz| Vdimm: 1.65V| Timings: 7-8-7-20-1T
    Storage:
    -3Ware 9650SE-2LP RAID controller
    --2x Western Digital 74GB Raptor RAID 0
    PSU:
    -Enermax Revolution 85+ 1250W
    OS:
    -Windows Vista Business x64
    ORDERED: Sapphire HD 5970 OC
    LOOKING FOR: 2x G.Skill Falcon II 128GB SSD, Windows 7
    Dec 2007
    This is good to know, I hope it's true for the DQ6. I'm about ready to reawaken my DQ5.
    Are you on X86 or X64?
    D.F.I Pimp Daddy
    Jan 2007
    Still Lost At The Dead Show Parking Lot
    I think the Primary concern here should be seeing if the pattern of lowering voltage from Default 1.30vcore @Stock 2500.mhz Clocks creates issues on 64bit OS
    I can live with lower clock frequency but to be honest these chips run hot and they are still going through growing pains and I myself due to those two reasons have reservations about the 1.30vcore with these Phenoms. Even at stock something is amiss and just seems off kilter like some form of incompatibility issue of some sort at least on XP64 any how.
    SuperMicro X8SAX
    Xeon 5620
    12GB - Crucial ECC DDR3 1333
    Intel 520 180GB Cherryville
    Areca 1231ML ~ 2~ 250GB Seagate ES.2 ~ Raid 0 ~ 4~ Hitachi 5K3000 2TB ~ Raid 6 ~
    Dec 2007
    I have to stick with what I've said in other threads. The power plane is already under strain pulling over 80 watts. Running these things up increases the wattage even at similar voltages. Run the ram at higher speeds, switch banking registers 64 guns at a time apposed to 32 causes major spikes. Not only are you using 64bit pathways, you also have 64 bit instruction queues and sideband operations. This would explain why I can run all the 32bit code full t*ts to the wind and not get slammed. I may just throw a full 64bit app at it spawning 4 threads to see if it smokes.
    BTW, my 9500 is on Vista 64 at 1.200V
    Mar 2008
    no problem here either with 1.2v @ stock 2.5 on my 9850x4.
    wich comes out in cpu-z to be 1.18v. on vista64. run stock 1.3v upto 2.9ghz.
    but anything above that take a huge spike in voltage to get 3ghz.
    Mar 2007
    Quote Originally Posted by Nedjo View Post
    Not in my experience - My Brisbane 4000+ won't budge past 2.73GHz without failing prime. At this speed, it's Orthos 24h stable in Windows XP 32-bit and just as stable (mprime 24h stable) in 64-bit Linux...
    Dec 2007
    Windy 5600X2 now in my DFI, no X64 issues. Threw clock to 212x14=2968G, eased up on ram timings a little, vcor at 1.382 ZERO issues so far. I think I'll go for just under 3.2G. Unless a breakthrough occurs the 5600 will stay put until the C0 steppings come out and I see them working.
    In the mean time, I'll load the 9850BE into the GA780FX board on vista 32 and maybe Ubuntu 64.
    D.F.I Pimp Daddy
    Jan 2007
    Quote Originally Posted by SkullCracka View Post
    Perhaps it might be helpful if you state which OS ....XP64 or Vista64??????
    SuperMicro X8SAX
    Xeon 5620
    Feb 2008
    Quote Originally Posted by karbonkid View Post
    perhaps its dependent on which part of the cpu is limiting.. might be a part affected by 64bit os, might be not..
    too, remember to use 64bit prime versions to test under 64bit environment.. (dont know about mprime..)
    Banned
    Jan 2008
    Canada
    I've tried 3 different OS's with my current overclock, (see sig) Vista x64, WinXP x64 and Ubuntu 64bit. I had no issues or instabilities on any of them. I did have quite a bit of trouble installing XP x64 though, kept getting blue screens on install. I eventually got it stable by not using AHCI mode and using drivers from MSI's site not using ATI's drivers.
    I'm dual booting with Vista x64 and Ubuntu, everything runs beautifully. I have not had one crash, blue screen, 100% stability. I probably have a really good X4 though, but I would have been more than happy with 3Ghz.
    I don't know if some peoples problem is releated to the B2 stepping, immature BIOS etc. but I've been very very happy with my system. I would like to try running @stock frequency and lowering the CPU voltage, but BIOS 1.4 doesn't support lowering CPU voltage from stock for some reason.
    Mar 2008
    Quote Originally Posted by Oese View Post
    good thread...
    Thanks!
    Been very busy I'll post my results after this weekend hopefully on Vista Ultimate x64 on the new build.
  18. #18
    Xtreme Mentor
    Nov 2005
    Devon
    Quote Originally Posted by Rammsteiner View Post
    Yes! It's ridicules!
    Regarding vNB I'm leaving it at default because it's overclocked to 2.33GHz ATM.
    I haven't tried every possible voltage and multiplier combination yet, too many of them .
    Quote Originally Posted by AlabamaCajun View Post
    I'm only running x64 OSes. Vista Business x64 SP1 and XP Pro x64 currently. Also SuSe 10.3 x64 will be added shortly to that list.
    Somewhere in my drawer I've got HDD with Win XP MCE x32 but I'm too lazy to dig it up and do some more benchmarks at higher clocks .
    PS. What is funny is that all above OSes are fully licensed... I wouldn't expect that from me 4 years ago!
  19. #19
    Mar 2008
    Quote Originally Posted by Brother Esau View Post
    oh sry vista 64 ulti.
  20. #20
    D.F.I Pimp Daddy
    Jan 2007
    Thanks M8
    SuperMicro X8SAX
    Xeon 5620
  21. #21
    Jul 2004
    Wisconsin
    My Opteron 165's, or my 3700+ have no issue overclocking in 64bit OS (Vista, Linux)...
    The Optys and 3700+ were run on Ultra D's and an eVGA NF-41
    Just my Phenom, the best I could do is 2.7...
    ASUS Crosshair IV Formula
    AMD Phenom II 1090T Megahalems Rev. B 4ghz
    2x4gb G.Skill Ripjaws
    XFX 6950 (6970 clocks/shaders)
    2x250gb WD SATA
    1x1tb WD SATA
    750 watt PCP&C Quad Silencer
    X-Fi Titanium
    Windows 7 Pro 64bit
    Quote Originally Posted by Thomas Jefferson
    I tremble for my country when I reflect that God is just; that his justice cannot sleep forever.
  22. #22
    Xtreme Mentor
    Apr 2005
    Quote Originally Posted by Slagathor View Post
    and how much under 32bit Vista?
  23. #23
    Jul 2004
    Wisconsin
    Oops.....tee hee
    Normally run it at 2.9...
    Right now though it's 2.8, not sure the extra heat is worth the 100mhz....
    2x250gb WD SATA
    1x1tb WD SATA
    X-Fi Titanium
    Windows 7 Pro 64bit
  24. #24
    Mar 2008
    here you go. vista 64 2.9ghz @ 1.335v will boot at stock 1.3 but stable is 1.335. xpPro32 3.1ghz 1.3v will boot but same as vista 1.375 is the magic stability voltage.
    this is on air cooling. xp shows slightly higher benchmark scores but the vista 64 bit shows more fps in games and has faster speed in opening aps.
    even at the lower clock speed.
    now this could be due to more then just 32bit vs 64. since when running vista64 im using 15gb raptors in raid0 vs ide 80 for the xp.also 4gb ram in vista vs 2gb ram in xp.
    either way the vista64 set up is better all around.
    Edit: dual booting now and running both @ the 2.9 1.335 to do some further testing at the same clock speeds.
  25. #25
    D.F.I Pimp Daddy
    Jan 2007
    The relevant question here from me to you is there a issue dropping below Stock 1.3vcore even at defaults with Vist64??
    SuperMicro X8SAX
    Xeon 5620
Tags for this Thread
