05-12-2008, 09:14 AM
#1
Moderator
XFX Warranty
Sometimes there is a bit of confusion regarding our video card warranty so I wanted to come right out and clarify. If you live in the US or Canada our video cards come with a Double Lifetime Modder Friendly warranty. This basically means the video card is under warranty for as long as you own it and if you give it away or sell it, the second owner also has a lifetime warranty (helps with resell value). Modder friendly means we do not mind if you overclock the video card or change out the fan as long as the video card is not physically damaged and you keep the original hardware (in case you ever need an RMA).
05-12-2008, 09:31 AM
#2
Xtreme Cruncher
So basically you can't do electrical mods, correct?
__________________
Pray for BLUE!!!
Up:
E6300 Wolfdale @ 4000mhz == 6GB DDR2 800 == HD3850 256MB == Windows 7 Pro 64
P4 531 == 2.5GB DDR2 400 == X300 128MB PCIe == Vista HB 32
Down:
A64 3500+ == 2GB DDR2 800 == HD3200 IGP == XP Pro 32
05-12-2008, 09:39 AM
#3
I am Xtreme
Wow thats really good. Im glad i bought my XFX 8800GT now  Not so much for the double warranty but im assuming the changing heatsink and overclocking part applies to the uk aswell.
__________________
Gaming Rig
Case: Silverstone TJ-07 LCD: 32" Samsung A656 CPU: i7 920 D0 w/Swiftech Apogee GTZ Mobo: Foxconn Bloodrage RAM: 6GB OCZ Blade
GFX: HIS 4870X2 w/EK Nickel/Acetal FC Block Power Supply: Corsair HX 1000W Sound Card: Auzentech X-Fi Prelude HDD: 60GB OCZ Vertex HDD: 2x1TB Samsung F1
Media Rig
Case: Zalman HD160XT+ LCD: 40" Toshiba XF355D CPU: Q9450 w/EK Supreme LT Mobo: Asus Rampage Formula RAM: 8GB Geil Black Dragon
GFX: Gainward 8600GT SilentFX Power Supply: Corsair HX 620W Sound Card: Auzentech X-Plosion HDD: 500GB WD Caviar Black
File Server
Case: Custom Built Torture Rack CPU: E8200 w/Ultra-120 Exterme Mobo: Asus P5QL-EM Ram: 4GB OCZ Platinum
GFX: Onboard Power Supply: Corsair HX 620W HDD: 250GB Seagate HDD: 2x1TB WD Caviar HDD: 2x1TB WD Caviar
05-12-2008, 09:50 AM
#4
Moderator
No, we do not recommend any type of modifications that involve soldering. (if that is what you are getting at)
05-12-2008, 09:56 AM
#5
i heart socket 775
Well of course you don't recommend it. But other than obvious physical damage is a visible electrical mod the only thing for which you would refuse warranty service?
__________________
e8400 4.3Ghz | DFI LP UT X48-T2R | 2x2GB Dominator 8500 | MSI GTX 280 | 150GB Raptor + 300GB VR | 23" Apple Cinema HD
Apogee GTZ | Swiftech MCR220 | DD CPX-Pro | MC-AGB150 Res
05-12-2008, 09:58 AM
#6
I'm feeling BLUE!
I just had an image of some of these guys getting out the arc welder and 4/0 cable hooking it up to a dedcated nuclear reactor to bump the voltage to the cards..
Oh, welcome to Xs.
__________________
The XS WCG team needs your support.
A good project with good goals.
Come join us,get that warm fuzzy feeling that you've done something good for mankind.
Originally Posted by Frisch
If you have lost faith in humanity, then hold a newborn in your hands.
05-12-2008, 10:02 AM
#7
Moderator
Well you would be surprised what gets sent in, but to answer your question for the most part yes; visible electrical mod, physical damage or I have even seen sever liquid leakage damage video cards as well, turning components into mush.
05-12-2008, 10:09 AM
#8
i heart socket 775
Yeah plenty of examples of "When liquid cooling goes bad" isn't surprising but that people bother to send them in is another story. Obviously falls under physical damage.
Thanks for your response.
__________________
05-12-2008, 03:13 PM
#9
Administrator
What about customers outside the US and Canada?
Do they receive the same kind of warranty?
__________________
Rig #1
Gigabyte UD3P Rev. 1.0 Bios F4
E8600 @ 4400Mhz, 1.296V
2x2Gb OCZ1066 LV Blade
BFG GTX280 OC
Coba Nitrox 750W
Watercooled with HK 3.0 CU, EK-FC280GTX, PA120.3, Laing Ultra with XSPC top
Rig #2
DFI UT P35-T2R (0317 bios)
E8200 @ 4000 (1.216V) / 4100 (1.248V) / 4200 (1.296V) / 4300 (1.344V)
2x2Gb Chaintech Apogee GT PC2-8500
Powercolor 4870
Corsair 520HX
Watercooled with HK 3.0 CU, EK-FC4870, Feser tripple, Laing Ultra pump
Originally Posted by Movieman
I've got Supermicro boards that lasted longer than one of my marriages!
05-12-2008, 05:38 PM
#10
Xtreme Cruncher
 Sorry--I just had to ask. It would have happened anyways--best get it known on page 1.
Anyways--does the warranty last until literal death of XFX or is it limited to how long the card is available from XFX? For example, if I had a GeForce FX5900 die on me and I RMA'd it, would I get one back or would I get a "free upgrade", so to speak?
__________________
Pray for BLUE!!!
Up:
Down:
05-13-2008, 01:10 AM
#11
So my XFX 8800GTX that has a Thermalright cooler and is overclocked is still covered under warranty? That's crazy.
Second XFX card in a row.. Provided Nvidia doesn't screw up, I'll probably be on my third for the next build.
I too wonder if this is the case.
05-13-2008, 09:32 AM
#12
XFX Tech Support
Any card 6 series and above is covered for the life of the first and second owner. If we don't have a card in stock it is replaced with the next card up in performance. Make sure you register your products to activate the warranty.
Outside of the US and Canada the warranty is usually two years and through your retailer. It does not cover all of the customization and modification that the US and Canada warranty does but I believe they are looking into it.
Yes your card is still covered under warranty. In the case that anything turned south we would need you to put the original cooler back on the card before we could service it. We have to have the cards in original condition so always make sure you save the original cooler.
05-13-2008, 09:41 AM
#13
i heart socket 775
I always see companies say this but why?
Because of course a manufacturer still must honor a warranty even if the product were never registered. At least I am assuming they must, I know that they do because I generally don't bother to register anything.
__________________
05-13-2008, 09:45 AM
#14
Xtreme Cruncher
hmm so it's just like EVGA's lifetime warranty. only difference is there's not step up option. so does this apply for the mobos too or just the video cards?
05-13-2008, 01:06 PM
#15
i heart socket 775
^ Good question...
__________________
05-14-2008, 09:03 AM
#16
XFX Tech Support
Most manufacturers only have a one year warranty if it isn't registered soon after purchase because there is no way to track what the card has been through.
Other manufacturer's warranties only cover the first owner. When a customer buys a used card off of eBay it is common to reject the card if something is wrong. This will not happen with our warranty structure. An upgrade path is something we are looking in to but at this time there is not one in place.
05-15-2008, 10:38 AM
#17
Xtreme Cruncher
Thanks for the upfront info. I love seeing companies grow more modder/enthusiast friendly. If I go nvidia next I will be giving your cards a look
__________________
Heatware | Ebay: Crazymullen | If you are unsure what Fhqwhgads means You are REQUIRED to go HERE| Powered by Centon Ram
Originally Posted by Vapor
Isn't this the internet service where you mail them a postcard of what sites you want to browse and they send you back a cd?
Originally Posted by [XC] gomeler
Motherboards are finicky creatures lately, not like the A-XP days where you could step on the board and it'd live.
05-26-2008, 09:46 AM
#18
any plans of a "step-up" program? or having ATI gpus?
05-30-2008, 03:44 PM
#19
add the step-up to the xfx features and I will never buy from evga again lol....
05-30-2008, 03:47 PM
#20
Simon says EnJoYs a nub
When did the modder friendly thing start? I was going to rma a card with overheating issues due to the stock heatsink. I told them I switched out the stock and had put it back on to rma and they denied the RMA.
__________________
Originally Posted by 3oh6
damn you guys...am i in a three way and didn't know it again
Follow TechREACTION on Twitter
06-02-2008, 11:50 PM
#21
is necessary to send in their original packaging?
__________________
Intel core i7 920 D0
6GB Patriot 1600mhz
EVGA X58 E760
XFX ATi HD 5870
LG L246WP Widescreen
Auzun X-Fi Home Theater
Corsair HX1000w
WD 640GB Raid 0 l WD 1TB Black
Silverstone TJ07
OCGuate!
06-03-2008, 01:54 AM
#22
No, as long as it is properly protected they don't care what you send it in.
(Been there done that)
__________________
Originally Posted by Chruschef in regards to Thermaltake water cooling
you'd be better off cooling your components with a fire....
06-03-2008, 09:16 AM
#23
XFX Tech Support
Modder friendly started early last year. We only need the card in its original condition when service is needed. If you change the cooler always keep the original one just in case. We don't need the original packaging.
06-03-2008, 09:28 AM
#24
does the original cooler have to be re-attached?
06-03-2008, 09:44 AM
#25
XFX Tech Support
Yes. The card has to be in original condition.
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
