NEVER PRESSURE TEST YOUR RAD WITH HOUSE PRESSURE TAP WATER
2nd never use sharp items around your rad
was testing a rad / blower set up ,went to remove the temp tubing setup & was useing sissors (I know 1st dumb thing it did) to cut off the tubing on the barbs > stabbed the rad "Holey S**T " but it looked as if i missed the tubes just fin damage
SOO I ran house water thru unrestricked & counldn't tell for sure if it was leaking
SOO >>> I think >> I'll plug the outlet & then I'll know for sure . Soo I hook it all up & place a plug on the outlet hose Then I run in the house turn the water back on >> by the time i got 1/2 WAY back i could hear the fins popping ..
>>Everyone Laff now ! >>![]()
>> GTXBlkIce 480 shot to Sh**
it is now > leaking ... but NOT at the site of the damage !
pix attached
