Results 1 to 10 of 10
Thread: E8500 max voltage
    Jun 2005
    E8500 max voltage
    Hi there ;
    After reading many post . Most people suggest to stay bellow 1.35 v as safe voltage .
    However, I don't need my chip for more than 6 months .
    What should be the voltage then ???.
    1.5 v is good enough ??
    thanks,
    2600K working in 4.8 GHZ so far
    2600k @(4600 Ghz) 1.42v : (under water)
    Asus B2 mobo
    4 GiG DDR 2400 MHZ
    GTX 570 @ 1.063v ( 910/1820/2001 Mhz) .(under water).
    1020 W PSU
    Hobie's : Overclocking .... Overclocking .... Overclocking
    Xtreme Guru
    Jun 2006
    Finland, joensuu
    well i have runned mine with almost 2.0v with a cascade so i would say if you have the cooling power go for it 1.65v with air cooling is pretty much the max i would imagine. after that most coolers loose there ability to transfer heat away from the cpu..
    Evga X58 sli under cascade
    http://www.xtremesystems.org/forums/...d.php?t=219788
    Evga X58 Sli ultimate overclocking/ overview/ discussion thread
    http://www.xtremesystems.org/forums/...d.php?t=221082
    proud owner of E8600 Q822A435
    I am Xtreme
    Sep 2006
    I would stick around 1.4-1.45 on air or water for daily use... 1.65 max for benching...
    Question : Why do some overclockers switch into d*ckmode when money is involved
    Remark : They call me Pro Asus Saaya yupp, I agree
    The Blue Dolphin
    Nov 2004
    The Netherlands
    Killing the chip will probably not happen at sub-1.55v if the chip doesn't run too hot (which is the max you'd ever want to use anyway because more yields pretty much no extra overclocking). The only thing you risk when using 1.35v is degradation in maximum overclock and a lower overclock at a specific vcore. I'd say 1.35v is pretty safe and if you encounter any degradation just up the vcore by a tad or lower the clock until it regains stability. For 6 months use I'd suggest to not hold back too much
    Blue Dolphin Reviews & Guides
    Blue Reviews:
    Gigabyte G-Power PRO CPU cooler
    Vantec Nexstar 3.5" external HDD enclosure
    Gigabyte Poseidon 310 case
    Blue Guides:
    Fixing a GFX BIOS checksum yourself
    98% of the internet population has a Myspace. If you're part of the 2% that isn't an emo bastard, copy and paste this into your sig.
    Jun 2005
    Quote Originally Posted by Solarfall View Post
    Pretty usefull . 1.65 v looks sweet
    Quote Originally Posted by Leeghoofd View Post
    so 1.4-1.45 on water will kill the chip on 6 month ????? .
    Quote Originally Posted by alexio View Post
    well well . i will go then full 1.55-1.65 v
    Asus B2 mobo
    4 GiG DDR 2400 MHZ
    1020 W PSU
    Xtreme Guru
    May 2007
    Ace Deuce, Michigan
    I would say 1.4v, maybe 1.45v with 45nm cpus, we still don't know whether they can tolerate the same voltages 65nm cpus could even though they run cooler (mainly because of high k+mg)
    Quote Originally Posted by Hans de Vries View Post
    JF-AMD posting: IPC increases!!!!!!! How many times did I tell you!!!
    terrace215 post: IPC decreases, The more I post the more it decreases.
    until (interrupt by Movieman)
    Regards, Hans
    Jun 2005
    Quote Originally Posted by AliG View Post
    do u talk about the max safe voltage range or the max voltage for 6 month run .
    Asus B2 mobo
    4 GiG DDR 2400 MHZ
    1020 W PSU
    Feb 2008
    Why does your sig say ''CRAPPY'' e8500 @ 4.7GHz with 1.45v? are you insane dude lol...
    My E8400 needs 1.38v underload just to do 4GHz stable (granted it used to do it with 1.34v, but degradation happened) i would never complain about 4.2GHz even at 1.4v underload. lol your a crazy guy
    Asus Rampage II Extreme
    Intel i7-920 @ 4.2Ghz w/ HT
    6GB G.Skill @ 1600Mhz
    eVGA / MSI GTX480 SLI
    Corsair HX1000w
    CoolerMaster HAF932 OG
    Corsair H70
    Feb 2007
    Quote Originally Posted by Furiøùs View Post
    1.38? Wow. I hope my 8500 doesn't degrade. It's doing 4GHz on 1.25 but it runs near 70C too under prime. Gotta water cool it. Until I do, I just might step things down to 3800.
    Lian Li PC-A77B, Corsair 750TX PSU | Asus Max Formula->Rampage, 1001 BIOS | E8500 @4303MHz, Xigmatek S1283 | 4GB G.Skill DDR2 1066 | HIS 4890 Turbo | Super Talent FTM32GX25H SSD (boot), WD3000GLFS, ST31500341AS, WD6400AAKS | Pioneer 112D | X-Fi Titanium Fatal1ty Pro | Klipsch ProMedia Ultra 5.1 w/upgraded parts&cooling | LG W2600H 26" monitor | Windows 7 x64
    Jun 2005
    . I forget to remove the world crappy after signature update.
    The crappy processor was An E6600 @ 3.2 Ghz (not stable @ higher frequency even with 1.8 v)
    Asus B2 mobo
    4 GiG DDR 2400 MHZ
    1020 W PSU
