XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme Teams > Xtreme 3D Team
Reply
Old 05-01-2008, 08:51 AM   #1
TheGoat Eater
No Look Pour™
TheGoat Eater's Avatar
Send a message via ICQ to TheGoat Eater Send a message via AIM to TheGoat Eater Send a message via MSN to TheGoat Eater Send a message via Yahoo to TheGoat Eater Send a message via Skype™ to TheGoat Eater
E8500 and PALiT 9600GT "Vanillas" - 93K '01 and 21485 '06
First the CPU
is capable of -
So my E8400 died and this is its replacement, I am so happy!
The cards clocked well in stock form - 650 core - up to 750 core and 1000 mem (900 stock)... I felt I could do better and decided to preform a vmod on both cards (figured out by largon ) and settled on 1.3v for now getting to a stable 845/2112/1000 (no mem mod)...for cooling I switched to Accelero S1 Rev2 air coolers with standard 120mm fans.
now as far as cooling goes I use Dunieks 2 piece Aluminum pot with DICE and Acetone ... got like 25-30 lbs for just freaking $10 USD
Specs
E8500
Evga 790i Ultra (testing was on P04)
PALiT 9600GTs "vanilla" in SLI
OCZ Platinum 1600 7-7-7-20 running as close to 1000MHz as possible @ 8-7-7-24 2T
dual Raptor 74GB (16MB) in RAID 0
PC P&C 750 Crossfire Edition
XP PRO
I will post some of the pics of my setup and provide ORB links here in a bit as I am swamped w/ things to be done ... not all were submitted as I didn't feel I had gotten to the best yet...
Please feel free to add any comments or tips that you would feel useful in my screenshots
-Ryan
here are the e8500 SLI results w/ DICE (2nd time doing so)
which gets me this-
Now running with the "big dogs" you think?
__________________
TheGoat Eater is online now   Reply With Quote
Old 05-01-2008, 09:10 AM   #2
gillll
gillll's Avatar
Send a message via MSN to gillll
wow ! amazing score !
__________________
Gaming PC: Still waiting for fullhd crysisable gpu
HTPC: AMD64 @ 2.7 2GB,2TB(Raid1),7800GTX,winxp
Server: P4530,2gb,1tb,2008server.
Netbook: MSI WIND U100,Atom280,2GB,160HD,win7
gillll is offline   Reply With Quote
Old 05-01-2008, 09:13 AM   #3
TheGoat Eater
No Look Pour™
this was all the first runs - will do more testing and tweaking today as the DICE will be gone soon - will load up tomorrow again for the weekend
__________________
Old 05-01-2008, 09:31 AM   #4
xwards
xwards's Avatar
nice results m8
xwards is offline   Reply With Quote
Old 05-01-2008, 10:02 AM   #5
.p4nzer
Wow...
Very impressive 33k 05... For 2 64 shader vga is awesome
Bye
__________________
Intel e8500@4000mhz@1.36v|Intel Stock Heatsink|Asus P5e3ws Professional|2*1024 OCZ PC12800 D9GTR@1600@7/6/6/x@1.92v|2x Sapphire 3870@875/1250|Stock Cooling|Maxtor s-ata 160gb|Enermax 460w|Creative Sound Blaster Audigy 4
.p4nzer is offline   Reply With Quote
Old 05-01-2008, 08:25 PM   #6
TheGoat Eater
No Look Pour™
now I am confused- when i ran PCMARK 05 I couldn't submit as there was no score at the finish...even when I pushed the button I got to ORB and - NOTHING ... anybody have any ideas?
__________________
Old 05-02-2008, 12:38 AM   #7
massman
www.hwbot.org
massman's Avatar
Send a message via MSN to massman
Have you installed everything that's needed for the benchmark? Windows media player updates, for instance.
Good benches, I hope you're still aiming at higher speeds
massman is offline   Reply With Quote
Old 05-02-2008, 06:11 AM   #8
TheGoat Eater
No Look Pour™
hell yeah I want better speed but working on that - I will try the updates for sure
__________________
Old 05-06-2008, 06:48 PM   #9
hecktic
hecktic's Avatar
amazing cpu there... what did you do with the other one... the one that you said died out on you?
hecktic is offline   Reply With Quote
Old 05-06-2008, 06:59 PM   #10
TheGoat Eater
No Look Pour™
yeah - the replacement is being delivered tomorrow - though I am burnt out on testing...for now -I need a reliable system for daily use so the E8400 is going for that
__________________
Old 06-19-2008, 04:00 AM   #11
TheGoat Eater
No Look Pour™
with Dice - how much better temps will I get moving from the ALUMINUM pot to an atleast Copper bottom pot (alu/cu) or full Cu pot? as I need to bench GSOs next week andmay be up for one if it will at least help a bit --- I know it will but just want a bit of prodding to buy :P as I need GPU pots more
I WILL be re-benching these cards with the latest driver as I see it might be a loit better now as I lost the '01 #1 spot to a lower clocked E8500 and over 100MHz lower cards and all around lower clock I guess
__________________
Old 06-19-2008, 06:07 AM   #12
DaMulta
DaMulta's Avatar
You should hook up that rad, and the water blocks")
DaMulta is offline   Reply With Quote
Old 06-25-2008, 10:23 PM   #13
TheGoat Eater
No Look Pour™
hooled up the GTX 480 and everything (maze 5s ) and now the 9600GT (single right now) is at 901/2252/1000 rhthdrbl no prob at 33-34C and idle 28-29C this is at 1.45vcore no vmem mod (yet) so I am gonna swap out and tune the other card soon
Will edit this post with single card run results at 4.05GHz(air)
__________________
Old 06-25-2008, 10:34 PM   #14
[XC] gomeler
Diablo 3! Who's Excited?
[XC] gomeler's Avatar
Send a message via AIM to [XC] gomeler
Nice shader clocks there
__________________
Team PURE is about kickass pirates and unicorns defeating ninjas.
[XC] gomeler is offline   Reply With Quote
Old 06-25-2008, 10:47 PM   #15
TheGoat Eater
No Look Pour™
Check this - 950/2375/1000 and at load (rthdrbl) 36C - I LOVE LIFE !
Seems that OCP is a little above 1.6v will have to get a mod for that
I am currently running at 830 core on '01
Edit: back at 950/2375/1000 in '01
__________________
Old 06-25-2008, 11:17 PM   #16
[XC] gomeler
Impressive! Non-reference PCB with resistance based voltage mod? 1.45vgpu for that is impressive, wonder how high it'll scale with dry ice.
__________________
Old 06-25-2008, 11:43 PM   #17
TheGoat Eater
No Look Pour™
1.55v~ now
I do need GPU pots - the DICE run will be in the next 72 hours
testing SLI now - 900~core
Will post result for sure
__________________
Old 06-26-2008, 12:02 AM   #18
fubarswe
fubarswe's Avatar
Niiiice moves, sweet setup and nice chip u got there!.., race is on!!! :-)
fubarswe is offline   Reply With Quote
Old 06-26-2008, 12:27 AM   #19
TheGoat Eater
No Look Pour™
you got it
The race is ON!!!!!!
__________________
Old 06-26-2008, 01:26 AM   #20
TheGoat Eater
No Look Pour™
almost tweaked to the max (GPUs), well... at least for water
EDIT: 18361 in '06 same settings
__________________
Old 06-26-2008, 03:50 AM   #21
TheGoat Eater
No Look Pour™
ok - prepped for battle w/ you... are we limited to public or beta drivers for this one?
__________________
Old 06-26-2008, 04:16 AM   #22
fubarswe
fubarswe's Avatar
lets use what ever drivers out there! :-)
Old 06-26-2008, 06:26 AM   #23
TheGoat Eater
No Look Pour™
too much acetone EEK
294~~~ AQ3 but I can do better
__________________
Old 06-26-2008, 07:01 AM   #24
fubarswe
fubarswe's Avatar
.., I´m in trouble...
Old 06-26-2008, 08:05 AM   #25
TheGoat Eater
No Look Pour™
Also did 100~~~ '01 but figured I could do better with beta drivers
Picked up 35 lbs of DICE pellets for $10 usd - gotta love that -
you going down -> *tonight* because I gotta let the acetone get to room temp to get it out and get the right amount in there
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
